標題: 32路搖搖棒制作資料下載 [打印本頁]
作者: zxcv1314    時間: 2015-7-31 10:54
標題: 32路搖搖棒制作資料下載
32路搖搖棒制作。
所有制作資料打包下載:
32燈搖搖棒資料.rar (7.83 MB, 下載次數: 143)
以下是部分源程序預覽:
  1. /****************************************************************************************
  2. /*硬件制作:07電氣工程 張國榮
  3. /*軟件調試:07電氣工程 付春平
  4. /*描    述: 搖搖棒程序,通過滾珠開關檢測周期,搖動時間自適應,圖像始終保持在中間。開機后每搖晃10次切換下一組字模
  5. /* 按了一下按鍵后變成了手動切換,直到回到第一組字的時候再自動切換
  6. 如有問可直接加我QQ:77554971
  7. 技術交流群:120069344
  8. 套件出售
  9. 詳細制作在里面了!
  10. 最后祝各位制作成功!學習進步!
  11. /*****************************************************************************************/
  12. #include <STC11F60XE.h>
  13. /*********外部接口定義**********/
  14. #define uchar unsigned char
  15. #define uint unsigned int    //宏定義
  16. #define out P1        //數據輸出端口
  17. sbit led1=P3^0;        //第1組LED
  18. sbit led2=P3^1;        //第2組LED
  19. sbit led3=P3^3;        //第3組LED
  20. sbit led4=P3^4;        //第4組LED
  21. sbit key1=P3^5;         //按鍵輸入
  22. sbit p3_2=P3^2;
  23. uchar KY,num;      //KY作用在后面說明
  24. uchar BUFF;                                   //緩存
  25. /*********全局變量定義**********/
  26. unsigned long int TimeCount=0;
  27. unsigned int         DelayN=80,                //延時臨時計數
  28.                                 DelayTime=80;        //每次延時的周期個數
  29. unsigned char key,keyy;
  30. /**********************************************/
  31. void delay(unsigned char n);
  32. void DelayMs(void);
  33. /*******************************************/
  34. unsigned char code text0[]={
  35. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  36. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0xB7,0xBB,0xB7,0xBB,0xB3,0xBB,0xB4,0xBB,0xB5,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"自",1*/
  37. 0xBF,0xBF,0xBE,0xDF,0x39,0xE0,0xFF,0xDF,0xEF,0xBF,0xEF,0xBF,0x6D,0xB0,0x6D,0xB7,0x6D,0xB7,0x01,0xB7,0x6E,0xB7,0x6E,0xB7,0x6E,0xB0,0xEF,0xBF,0xEF,0xBF,0xFF,0xFF,/*"適",2*/
  38. 0xFF,0xBF,0xFF,0xC7,0x03,0xF8,0xBB,0xDF,0x7B,0xDF,0xFB,0xD0,0xEB,0xDB,0xDA,0xDF,0x39,0xDC,0x7B,0xCF,0xFB,0xD3,0xFB,0xDC,0x1B,0xDF,0xBB,0xDF,0xFF,0xDF,0xFF,0xFF,/*"應",3*/
  39. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  40. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  41. 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"搖",6*/
  42. 0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"搖",7*/
  43. 0xEF,0xFC,0x2F,0xFF,0x00,0x00,0xAF,0xFF,0x6F,0xFD,0xBB,0xF5,0xAB,0xF6,0x2B,0xF5,0x8B,0xF5,0xA0,0x00,0x2B,0xF5,0xAB,0xF4,0xAB,0xF6,0xBB,0xF5,0xBF,0xFD,0xFF,0xFF,/*"棒",8*/
  44. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",9*/
  45. };
  46. unsigned char code text1[]={
  47. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  48. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
  49. 0xF7,0xFD,0xF7,0xFE,0x76,0xFF,0x31,0x00,0x57,0xFF,0xE7,0x7C,0xFF,0xBF,0x01,0xCF,0x7D,0xF0,0x7D,0xFF,0x7D,0xFF,0x7D,0x80,0x01,0x7F,0xFF,0x7F,0xFF,0x0F,0xFF,0xFF,/*"祝",2*/
  50. 0x7F,0xFF,0xBF,0xFF,0x0F,0x80,0xD3,0xFF,0xBC,0xEF,0xDF,0xF3,0x67,0xFC,0xF0,0xDE,0xF5,0xBF,0x17,0xC0,0xF7,0xFF,0x77,0xFF,0xD7,0xFC,0xE3,0xE3,0xF7,0xF7,0xFF,0xFF,/*"你",3*/
  51. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  52. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  53. 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",6*/
  54. 0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",7*/
  55. 0xBF,0xFF,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF3,0x01,0xFC,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0x01,0x80,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xBD,0xFF,0xFF,0xFF,/*"開",8*/
  56. 0xFF,0xFB,0x7F,0xFC,0xFF,0xFF,0xFF,0xFF,0x0F,0xC0,0xFF,0xBF,0xFE,0xBF,0xFD,0xBF,0xE3,0xBF,0xF7,0xBF,0xFF,0xBF,0xBF,0x87,0x7F,0xFF,0xFF,0xF8,0xFF,0xFD,0xFF,0xFF,/*"心",9*/
  57. };
  58. unsigned char code text2[]={
  59. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0x01,0x00,0x00,0x80,0x01,0x00,0x00,0x80,0xF9,0xFF,0xFF,0x9F,
  60. 0xF9,0xFF,0xFF,0x9F,0xF9,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0x01,0xFE,0xFF,
  61. 0x7F,0x00,0xF8,0xFF,0x3F,0x00,0xF0,0xFF,0x1F,0x00,0xE0,0xFF,0x0F,0x00,0xC0,0xFF,0x07,0x00,0x80,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFF,0x03,0x00,0x00,0xFE,
  62. 0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xF8,0x07,0x00,0x00,0xF0,0x0F,0x00,0x00,0xE0,0x1F,0x00,0x00,0xE0,0x3F,0x00,0x00,0xC0,0x3F,0x00,0x00,0x80,0x1F,0x00,0x00,0xC0,
  63. 0x0F,0x00,0x00,0xE0,0x07,0x00,0x00,0xF0,0x03,0x00,0x00,0xF8,0x03,0x00,0x00,0xFC,0x03,0x00,0x00,0xFE,0x03,0x00,0x00,0xFF,0x07,0x00,0x80,0xFF,0x0F,0x00,0xC0,0xFF,
  64. 0x1F,0x00,0xE0,0xFF,0x3F,0x00,0xE0,0xFF,0xFF,0x00,0xF8,0xFF,0xFF,0x01,0xFC,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  65. 0x07,0x00,0x00,0xE0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0xFF,0xFF,0xFF,0xC7,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,
  66. 0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xC7,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xC0,0x07,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xFF,/*"未命名文件",0*/
  67. };
  68. /***********n(us)延時子程序***************/
  69. void DelayUs(uint N)
  70. {
  71. uint x;
  72. for(x=0; x<=N;x++);
  73. }
  74. /******************************************/
  75. void main()
  76. {
  77.         AUXR=0x80;
  78.         CLK_DIV=1;
  79.         EX0=1;        //開放外部中斷0
  80.         IT0=1;        //中斷0為邊沿觸發方式
  81.         IP=0x02;        //設置中斷優先級
  82.         TMOD=0x02;        //定時器0方式2,8位重裝載
  83.         TH0=0x80;        //設定定時器初值
  84.         TL0=0x80;
  85.         KY=0;
  86.         EA=1;        //開放中斷
  87.         ET0=1;        //開放定時器0中斷
  88.         TR0=1;        //啟動定時器0,開始計時*/
  89.         key=0;        //初始化顯示第一組文字
  90.         keyy=0;
  91.         P1M0=0x55;        //0101 0101        /P1.0  P1 .2 P1.4 P1.6推挽輸出
  92.     P1M1=0xAA;
  93.         while(1){//等待中斷
  94.
  95.         if(key1==0){        //有鍵按下
  96.          DelayUs(50);
  97.          if(key1==0){
  98.                 key++;                                //更換下一幅圖片
  99.                 if(key>2) key=0;        //圖片循環顯示 根據顯示的組數來定義 這里有9組 所以就要keyy>9
  100.                 while(key1==0);                //等待按鍵釋放
  101.                 }
  102.                 }
  103.         if(num>10) //每中斷10次切換
  104.                 {
  105.                 keyy++;
  106.                 num=0;
  107.                 }
  108.         if(keyy>2)keyy=0;        //圖片循環顯示 根據顯示的組數來定義 這里有9組 所以就要keyy>9
  109.         }
  110. }
  111.
  112. /*********文字顯示子程序**********/
  113. void display_word(unsigned char code *text)
  114. {
  115.    unsigned        char i,j=2;                        //j為圖片起始位置 3 為第3個開始是圖片 如果要顯示高時32的大字 也屬于圖片格式
  116.     DelayUs(6400);
  117.
  118.         for(i=0;i<64;i++)
  119.         {
  120.
  121.         P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  122.             P3M1=0x1B;
  123.                 if((key>=j)||(keyy>=j))
  124.                 BUFF=(*(text+i*4+3));
  125.                 else
  126.                 BUFF=(*(text+128+i*2+1));
  127.                 led4=0;
  128.                 P1=~BUFF>>1;
  129.                 P3M0=0x10;                        //0001 0000        //P3.4推挽輸出 P3 .0 P3.3 P3.1輸入高阻
  130.             P3M1=0x0B;          //0000 1011
  131.                  delay(1);
  132.                 P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  133.             P3M1=0x1B;                         //0001 1011
  134.                 led4=1;
  135.              P1=BUFF;             //01010101  1357
  136.                 P3M0=0x10;                        //0001 0000        //P3.4推挽輸出 P3 .0 P3.3 P3.1輸入高阻
  137.             P3M1=0x0B;          //0000 1011
  138.                  delay(1);
  139.                 P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  140.             P3M1=0x1B;                         //0001 1011
  141.                 if((key>=j)||(keyy>=j))
  142.                 BUFF=(*(text+i*4+2));
  143.                 else
  144.                 BUFF=(*(text+128+i*2));
  145.                 led3=0;
  146.                 P1=~BUFF>>1;
  147.                 P3M0=0x08;                        //0000 1000        //P3.3推挽輸出 P3 .0 P3.1 P3.4輸入高阻
  148.             P3M1=0x13;          //0001 0011
  149.                 delay(1);
  150.                 P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  151.             P3M1=0x1B;                         //0001 1011
  152.                 led3=1;
  153.              P1=BUFF;             //01010101  1357
  154.                 P3M0=0x08;                        //0000 1000        //P3.3推挽輸出 P3 .0 P3.1 P3.4輸入高阻
  155.             P3M1=0x13;          //0001 0011
  156.                  delay(1);
  157.                 P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  158.             P3M1=0x1B;
  159.                 if((key>=j)||(keyy>=j))
  160.                 BUFF=(*(text+i*4+1));
  161.                 else
  162.                 BUFF=(*(text+i*2+1));
  163.                 led2=0;
  164.             P1=~BUFF>>1;
  165.                 P3M0=0x02;                        //0000 0010        //P3.1推挽輸出 P3 .0 P3.3 P3.4輸入高阻
  166.             P3M1=0x19;                        //0001 1001
  167.                 delay(1);
  168.                 P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  169.             P3M1=0x1B;                         //0001 1011
  170.                 led2=1;
  171.              P1=BUFF;            //01010101  1357
  172.                 P3M0=0x02;                        //0000 0010        //P3.1推挽輸出 P3 .0 P3.3 P3.4輸入高阻
  173.             P3M1=0x19;                        //0001 1001
  174.                  delay(1);
  175.                 P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  176.             P3M1=0x1B;                         //0001
  177.                 if((key>=j)||(keyy>=j))
  178.                 BUFF=(*(text+i*4));
  179.                 else
  180.                 BUFF=(*(text+i*2));
  181.                 led1=0;
  182.                 P1=~BUFF>>1;
  183.                 P3M0=0x01;                        //0000 0001        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  184.             P3M1=0x1A;                         //0001 1010
  185.                 delay(1);
  186.             P3M0=0x00;                        //0000 0000        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  187.             P3M1=0x1B;                         //0001 1011
  188.                 led1=1;
  189.              P1=BUFF;            //01010101  1357
  190.                 P3M0=0x01;                        //0000 0001        //P3.0推挽輸出 P3 .1 P3.3 P3.4輸入高阻
  191.             P3M1=0x1A;                         //0001 1010
  192.                  delay(1);
  193. } }
  194. /*********顯示內容選擇子程序**********/
  195. void display(unsigned char t)
  196. {        keyy=0;
  197.         switch (t){                //通過按鍵選擇顯示內容
  198.                 case 0:        {display_word(text0);}break;
  199.                 case 1:        {display_word(text1);}break;
  200.                 case 2:        {display_word(text2);}break;
  201. //                case 3:        {display_word(text3);}break;
  202. //                case 4:        {display_word(text4);}break;
  203. //                case 5:        {display_word(text5);}break;
  204. //                case 6:        {display_word(text6);}break;
  205. //                case 7:        {display_word(text7);}break;
  206.         //        case 8:        {display_word(text8);}break;
  207.         //        case 9:        {display_word(text9);}break;
  208.         //        case 10:{display_word(text10);}break;
  209.                 //default:{display_word(text1);}
  210.
  211.
  212.                 }}
  213. /*****************************************/
  214. void display1(unsigned char y)
  215. {
  216.         switch (y){                //通過按鍵選擇顯示內容
  217.                 case 0:        {display_word(text0);}break;
  218.                 case 1:        {display_word(text1);}break;
  219.                 case 2:        {display_word(text2);}break;
  220. //                case 3:        {display_word(text3);}break;
  221. //                case 4:        {display_word(text4);}break;
  222. //                case 5:        {display_word(text5);}break;
  223. //                case 6:        {display_word(text6);}break;
  224. //                case 7:        {display_word(text7);}break;
  225.         //        case 8:        {display_word(text8);}break;
  226.         //        case 9:        {display_word(text9);}break;
  227.         //        case 10:{display_word(text10);}break;
  228.                 }
  229.                 }
  230. /***************************************/
  231. /*********延時子程序**********/
  232. void delay(unsigned char n)
  233. {
  234.         for(;n>0;n--){
  235.                 DelayN=DelayTime;
  236.                 while (DelayN);
  237.         }
  238. }
  239. /*********中斷子程序**********/
  240. void int0() interrupt 0        //使用外部中斷0
  241. {
  242. KY=~KY;
  243. if(KY==0)
  244. {
  245.         DelayTime=TimeCount/1580;
  246.         TimeCount=0;        //延時周期計數清零
  247.         if(key==0)
  248.         {
  249.          num++;
  250.          display1(keyy);        //根據按鍵選擇循環顯示文字
  251.         }
  252.         else
  253.         {
  254.         display(key);        //根據按鍵選擇循環顯示文字
  255.         }
  256. }
  257. }
  258. void timer0() interrupt 1                //定時器0中斷子程序
  259. {
  260.         TimeCount++;
  261.         if (DelayN!=0)
  262.         DelayN--;
  263. }
作者: zhou961291176    時間: 2015-7-31 14:46
好東西,下來看看
作者: XXXHHHLLL    時間: 2016-12-13 19:23
謝謝樓主的分享,正需要,謝謝
作者: xiaozhong1314    時間: 2019-8-7 18:14
資料很全,很好
