stm32定時器TIM4的3通道CH3輸出占空比為25%的PWM波
geige
2015-7-26 02:19
//使用定時器TIM4的3通道CH3輸出占空比為25%的PWM波
#include "stm32f10x.h"
int main(void)
// SystemInit();
//配置IO口
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE,ENABLE);//IO口使能設置
GPIO_InitTypeDefGPIO_InitStructure; //定義結構體
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM3的CH3連接PB8管腳
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;//復用推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOB,&GPIO_InitStructure);
//定時器2
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);//配置時鐘
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_TimeBaseStructure.TIM_Period=10000; //1s
TIM_TimeBaseStructure.TIM_Prescaler=7199; //720分頻
TIM_TimeBaseStructure.TIM_ClockDivision=0;
TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;//向上計數
TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM1;//PWM1模式1
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable;//比較輸出使能
TIM_OCInitStructure.TIM_Pulse = 2500; //設置占空比
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出比較極性高
TIM_OC3Init(TIM4, & TIM_OCInitStructure);//初始化TIM4的CH3通道
TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);//使能TIM4在CH3通道CCR3上的預裝載寄存器
TIM_ARRPreloadConfig(TIM4,ENABLE);//使能TIM4在CH3通道ARR3上的預裝載寄存器
TIM_Cmd(TIM4,ENABLE);//使能定時器4
while(1);
//以下是報錯函數
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file,uint32_t line)
#endif
stewart_leung
2015-8-11 10:05
好亂,為何出現GPIOD和E的時鐘,你有用到?為何有出現TIM2,你不是用TIM4?
