標題: 用24C04與單片機設計電子密碼鎖 程序+Protues仿真 1602LCD顯示 [打印本頁]
作者: 13142128573    時間: 2015-7-4 17:44
進來請看
單片機程序與仿真文件下載: 用24C04與1602LCD設計電子密碼鎖.zip (26.03 KB, 下載次數: 180)
以下是源程序預覽:
  1. //-----------------------------------------------------------------
  2. //原始程序中相鄰兩位密碼不能相同.
  3. //本壓縮包中的HEX由修改后的新程序編譯生成,允許輸入任意密碼.
  4. //-----------------------------------------------------------------
  5. //實訓100例中本例內的main函數可用以下代碼替換.
  6. //改動的主要是main函數中while循環內的代碼.
  7. //-----------------------------------------------------------------
  8. // 主程序
  9. //-----------------------------------------------------------------
  10. void main()
  11. {
  12.    uchar i = 0;
  13.    uchar IIC_Password[10];
  14.    uchar IS_Valid_User = 0;
  15.    P0 = 0xFF;
  16.    P1 = 0xFF;
  17.    P2 = 0xFF;
  18.    TMOD = 0x02;                     //T0設置為8位自動重裝模式
  19.    TH0 = 175;
  20.    TL0 = 175;
  21.    TR0 = 1;                         //啟動T0
  22.    DelayMS(10);
  23.    LCD_Init();                      //初始化LCD
  24.
  25.    IIC_24C04_Init();                //初始化24C04
  26.
  27.    Display_String(Title_Text,0x00); //在第1行顯示標題
  28.
  29.    //24C04的內容已由初始化BIN文件導入
  30.    //將24C04中預先寫入的密碼讀入pass
  31.    RecString(0xa0, 0 , IIC_Password, 6);
  32.    IIC_Password[6] = '\0';
  33.    while(1)
  34.    {
  35.       P1 = 0xF0;
  36.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號KeyNo
  37.       switch ( KeyNo )
  38.       {
  39.            case 0:  case 1: case 2: case 3: case 4:
  40.            case 5:  case 6: case 7: case 8: case 9:
  41.
  42.                    if ( i<= 5 )             //密碼限制在6位以內
  43.                    {
  44.                         //如果i為0則執行一次清屏
  45.                         if (i ==0) Display_String("                ",0x40);
  46.
  47.                         UserPassword[i] = KeyNo + '0';
  48.                         UserPassword[i+1] = '\0';
  49.
  50.                         DSY_BUFFER[i] = '*';
  51.                         DSY_BUFFER[i+1] = '\0';
  52.
  53.                         Display_String(DSY_BUFFER,0x40);
  54.
  55.                         i++;
  56.                     }
  57.                     break;
  58.
  59.            case 10: //按A鍵開鎖
  60.                     if (strcmp(UserPassword,IIC_Password) == 0)
  61.                     {
  62.                        LED_OPEN = 0;  //點亮LED
  63.                        Clear_Password();
  64.                        Display_String("Unlock OK!      ",0x40);
  65.                        IS_Valid_User = 1;
  66.                     }
  67.                     else
  68.                     {
  69.                        LED_OPEN =1;   //關閉LED
  70.                        Clear_Password();
  71.                        Display_String("ERROR !         ",0x40);
  72.                        IS_Valid_User = 0;
  73.                     }
  74.                     i = 0;
  75.                     break;
  76.
  77.            case 11: //按B鍵上鎖
  78.                     LED_OPEN =1;
  79.                     Clear_Password();
  80.                     Display_String(Title_Text,0x00);
  81.                     Display_String("                ",0x40);
  82.                     i = 0;
  83.                     IS_Valid_User = 0;
  84.                     break;
  85.
  86.            case 12: //按C鍵設置新密碼
  87.                     //如果是合法用戶則提示輸入新密碼
  88.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  89.                     else
  90.                     {
  91.                        i = 0;
  92.                        Display_String("New Password:   ",0x00);
  93.                        Display_String("                ",0x40);
  94.                      }
  95.
  96.                     break;
  97.
  98.            case 13: //按D鍵保存新密碼
  99.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  100.                     else
  101.                     {
  102.                        SendString(0xa0, 0 , UserPassword, 6);
  103.
  104.                        //重新讀入剛寫的密碼
  105.                        RecString(0xa0, 0 , IIC_Password, 6);
  106.                        IIC_Password[6] = '\0';
  107.
  108.                        i = 0;
  109.                        Display_String(Title_Text,0x00);
  110.                        Display_String("Password Saved! ",0x40);
  111.                      }
  112.
  113.                     break;
  114.
  115.            case 14: //按E鍵消除所有輸入
  116.                     i = 0;
  117.                     Clear_Password();
  118.                     Display_String("                ",0x40);
  119.        }
  120.        Beep();
  121.        DelayMS(100);
  122.        P1= 0xF0;
  123.        while (P1 != 0xF0);    //如果有鍵未釋放則等待
  124.        while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
  125.    }
  126. }
作者: lst1995    時間: 2015-7-4 21:27
厲害,,,51黑有你更精彩!!
作者: 54溫海超    時間: 2015-7-18 20:01
厲害,,,,太棒了
作者: hp4876231    時間: 2015-7-18 22:01
看看思路希望能得到一些靈感,謝謝分享
作者: beautiful-life    時間: 2015-8-11 18:25
支持樓主,很不錯,學習參考下
作者: xiong9527    時間: 2015-8-12 12:28
怎么修改的密碼是錯誤的,不能保存進去?
作者: 更ty6    時間: 2015-8-27 22:18
電子密碼鎖在今后還是有更大 的發展空間的
作者: my51ming    時間: 2015-8-28 22:06
很好的東西!!!!
作者: aaaaaaaaaa    時間: 2015-9-13 11:51
感謝分享
作者: ludaijin    時間: 2015-9-18 11:12
太強了
作者: ztx    時間: 2015-9-18 21:32
51Hei(51黑)論壇有你更精彩
作者: huangpan    時間: 2015-9-25 07:23
真的很不錯
作者: ludaijin    時間: 2015-9-25 08:09
強強強強強強強強強強強強強強強
作者: 下場雨落    時間: 2015-10-5 15:43
ludaijin 發表于 2015-9-18 11:12
太強了
求兩個按鍵輸入的電子密碼鎖
作者: caigen0001    時間: 2015-10-7 00:32
太強啦,學習~
作者: linx    時間: 2015-11-25 18:11
值得來圍觀,請問有仿真和程序嗎?
作者: linx    時間: 2015-11-25 18:24
居然不公開程序,有點失望
作者: jiegemo    時間: 2015-12-5 17:22
這個程序有源代碼嗎
作者: 258456    時間: 2015-12-10 15:10
有源代碼嗎?急需啊
作者: 258456    時間: 2015-12-10 18:54
有沒有源代碼啊
作者: 無敵喚醒    時間: 2015-12-12 18:55
有沒有不用24c04的?
作者: ludaijin    時間: 2015-12-22 16:32
樓上有朋友做出來了嘛
作者: 譚雅Ayom    時間: 2016-5-15 22:14
程序是不是有錯》?除了頭文件之外還缺點什么?
作者: 故人以北    時間: 2016-12-23 16:17
有源代碼嗎?我編譯的時候出現了錯誤
作者: faridzled    時間: 2016-12-25 09:24
thanks for sharing
作者: songjingjun1314    時間: 2017-3-27 16:44
尤源代碼嗎
作者: hsbuggati    時間: 2017-3-27 17:39
很不錯,正在學習
作者: Reactor    時間: 2017-10-31 13:23
樓主,不用總線怎么寫啊
作者: yangbulasi    時間: 2017-11-3 21:33
非常不錯
作者: 青春風鈴    時間: 2017-12-6 17:30
不錯學習一下
作者: q2063304    時間: 2017-12-6 20:39
支持樓主,很不錯,學習參考下
作者: 凌玉龍    時間: 2017-12-11 15:40
厲害,,,51黑有你更精彩!!
作者: tieq1952    時間: 2017-12-11 17:42
好東西,學習了
作者: a963696    時間: 2018-3-13 10:46
厲害,,,51黑有你更精彩!!
作者: linnyshow    時間: 2018-3-13 20:55
非常好,學習了。
作者: 用戶2111153    時間: 2018-3-21 22:53
實訓想做這個   謝謝大佬的分享  對于我這種小白很有用  拿走了  就是有點貴啊  這個  傷心
作者: ztb096001    時間: 2018-3-22 08:09
感謝分享
作者: 用戶2111153    時間: 2018-3-22 09:09
大佬這個編譯了為什么會有錯啊  解釋下唄   小白一個不知道什么意思
作者: 用戶2111153    時間: 2018-3-22 10:04
看不懂啊 大佬指點下  說明意思  頭文件一直報錯
