標(biāo)題: 51單片機(jī)lcd12864半屏顯示程序詳解 [打印本頁(yè)]
作者: hongniu    時(shí)間: 2015-6-23 18:48
哎!這些日子發(fā)生了很多事,很多人讓我改變看法,也許我也是有點(diǎn)。。。。
真是很郁悶,真的還好有它---------給我挑戰(zhàn),給我動(dòng)力,加油!努力!
這是我一貫的,用笨法子編程,管他那,能用就行 啊!
128*64的半屏和刷屏程序!
#include<reg51.h>
#define uint unsigned int;
#define uchar unsigned char;
sbit rs=P1^0;//并行模式下為指令數(shù)據(jù)選擇信H/L=指令/數(shù)據(jù)
雖然并不是什么圖,只是很多點(diǎn),但是我知道他意味這什么,
第一幅是在PC上顯示的圖,第二幅是在12864液晶上顯示的圖,也就是如果我ROM足夠大,我可以做視屏,這一點(diǎn)我堅(jiān)信!只是現(xiàn)在我的ROM存儲(chǔ)到?jīng)]有了,所以ROM空間放不下了,我才用了半屏。現(xiàn)在要大ROM也是很簡(jiǎn)單的,16K的,64K的,多了,只要有錢!呵呵
  1. sbit rw=P1^1;//并行的讀寫信號(hào)H/L=讀/寫
  2. sbit e=P1^2; //并行下的使能信號(hào)
  3. sbit reset=P1^5;
  4.    uchar x,y;//坐標(biāo)
  5.    uchar datetabal;
  6. uchar d1,d2;//數(shù)據(jù)緩沖
  7. uchar k=0,h=0;
  8. unsigned int i,j;
  9. uchar code tab[]={/*--  調(diào)入了一幅圖像:C:\Users\lenovo\Desktop\100001313985056.bmp  --*/
  10. /*--  寬度x高度=128x32  --*/
  11. 0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  12. 0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  13. 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  14. 0x00,0x00,0x00,0x00,0x00,0x00,0xE1,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  15. 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  16. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  17. 0x00,0x00,0x00,0x00,0x00,0x00,0xC7,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  18. 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  19. 0x00,0x00,0x00,0x00,0x66,0x4A,0xFC,0xEF,0xF5,0x92,0x00,0x00,0x00,0x00,0x00,0x00,
  20. 0x00,0x00,0x00,0x00,0xC6,0x0F,0x99,0x49,0x9D,0x5F,0x00,0x00,0x00,0x00,0x00,0x00,
  21. 0x00,0x00,0x00,0x00,0x8D,0xFD,0x66,0x79,0x67,0x4D,0x00,0x00,0x00,0x00,0x00,0x00,
  22. 0x00,0x00,0x00,0x00,0x19,0x3E,0x96,0x8F,0xCB,0xA9,0x00,0x00,0x00,0x00,0x00,0x00,
  23. 0x00,0x00,0x00,0x00,0x33,0xE9,0xF2,0x60,0xB6,0xFB,0x00,0x00,0x00,0x00,0x00,0x00,
  24. 0x00,0x00,0x00,0x00,0xE7,0xD3,0xFF,0x33,0xED,0xC6,0x00,0x00,0x00,0x00,0x00,0x00,
  25. 0x00,0x00,0x00,0x00,0x4F,0x4E,0x33,0x93,0x33,0x64,0x00,0x00,0x00,0x00,0x00,0x00,
  26. 0x00,0x00,0x00,0x00,0x7E,0xA6,0xCC,0xD8,0x42,0xAD,0x00,0x00,0x00,0x00,0x00,0x00,
  27. 0x00,0x00,0x00,0x00,0x4C,0x34,0x48,0x46,0x00,0x2A,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x00,0x00,0x93,0x7E,0x36,0xE9,0xFF,0x64,0x00,0x00,0x00,0x00,0x00,0x00,
  29. 0x00,0x00,0x00,0x00,0x57,0xFF,0xCA,0x26,0x00,0xBB,0x00,0x00,0x00,0x00,0x00,0x00,
  30. 0x00,0x00,0x00,0x00,0xBF,0x4D,0xF1,0x78,0x00,0x2D,0x00,0x00,0x00,0x00,0x00,0x00,
  31. 0x00,0x00,0x00,0x00,0x38,0x05,0xAC,0x73,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,
  32. 0x00,0x00,0x00,0x00,0xFD,0xB4,0xBE,0xBE,0x00,0x29,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x00,0x00,0x00,0x00,0x32,0xB6,0x4F,0xF5,0xFF,0x6C,0x00,0x00,0x00,0x00,0x00,0x00,
  34. 0x00,0x00,0x00,0x00,0xF6,0x0A,0x6B,0xAA,0x00,0x52,0x00,0x00,0x00,0x00,0x00,0x00,
  35. 0x00,0x00,0x00,0x00,0x7D,0x4A,0x3E,0x6D,0x9B,0xD5,0x8A,0x45,0x00,0x00,0x00,0x00,
  36. 0x00,0x00,0x00,0x00,0xBF,0xAF,0xCC,0xF6,0x50,0x6C,0x77,0xA8,0x00,0x00,0x00,0x00,
  37. 0x00,0x00,0x00,0x00,0x76,0x15,0xAF,0x7A,0xAB,0xA7,0x6A,0x13,0x00,0x00,0x00,0x00,
  38. 0x00,0x00,0x00,0x00,0x5D,0xAA,0x7F,0xFE,0x5D,0xFF,0x4D,0xD4,0x00,0x00,0x00,0x00,
  39. 0x00,0x00,0x00,0x00,0xEC,0x25,0xB3,0xB8,0x5B,0xCF,0xEC,0x2D,0x00,0x00,0x00,0x00,
  40. 0x00,0x00,0x00,0x00,0x6F,0xDE,0xB6,0x65,0xFF,0x27,0xF7,0xFC,0x00,0x00,0x00,0x00,
  41. 0x00,0x00,0x00,0x00,0xAB,0x2D,0x73,0x7A,0x3E,0x51,0x29,0x9B,0x00,0x00,0x00,0x00,
  42. 0x00,0x00,0x00,0x00,0x4B,0xC5,0x5D,0xF3,0xFD,0x4D,0xFC,0xCE,0x00,0x00,0x00,0x00,
  43. };
  44. void delay40ms(void)   //誤差 -0.000000000009us
  45. {
  46.     unsigned char ad,bd,cd;
  47.     for(cd=11;cd>0;cd--)
  48.         for(bd=124;bd>0;bd--)
  49.             for(ad=12;ad>0;ad--);
  50. }
  51. void delay4_6ms()//
  52. {
  53. unsigned char av,bv;
  54.     for(bv=12;bv>0;bv--)
  55.         for(av=175;av>0;av--);
  56. }
  57. void delay(void)
  58. {
  59.      ;;;
  60. }
  61. void writedate(unsigned char a)//寫數(shù)據(jù)
  62. {
  63.
  64.    delay4_6ms();
  65.       rs=1;
  66.     delay();
  67.     rw=0;
  68.    delay();
  69.    e=1;
  70.    delay();
  71.    P0=a;
  72.
  73.
  74. delay();
  75. e=0;
  76. delay();
  77. }
  78. void writectrl(unsigned char ds)//寫指令
  79. {
  80.   rs=0;
  81.    delay();
  82.     rw=0;
  83.   delay();
  84.    e=1;
  85.    delay();
  86. P0=ds;
  87. delay();
  88. e=0;
  89.    delay();
  90.
  91. }
  92. void main()
  93. {
  94.     reset=0;
  95.     delay();
  96.     reset=1;
  97.     delay40ms();
  98.   writectrl(0x3f);//開擴(kuò)充指令操作數(shù)據(jù)位選擇8位
  99.    delay4_6ms();
  100.    writectrl(0x3e);//寫指令擴(kuò)充指令操作,8位數(shù)據(jù),繪圖開關(guān)關(guān)
  101.   delay4_6ms();
  102.    // writectrl(0x80);//寫指令設(shè)置  垂直  列地址 Y軸為  “0”
  103.    //delay4_6ms();
  104.     //writectrl(0x80);//寫指令設(shè)置 水平  行地址 X軸  “0”
  105.        //delay4_6ms();
  106.      //writedate(0xffff);  //數(shù)據(jù)寫入FffFH
  107.   //delay4_6ms();
  108.    x=0;
  109.    y=0;
  110.    i=0;
  111.    j=0;
  112. for( h=0;h<32;h++  )
  113. {
  114.      x=0;
  115.    for (k=0;k<8;k++)
  116.    {
  117.
  118.
  119.    writectrl((0x80+y));//寫指令設(shè)置  垂直  列地址 Y軸為  “0”
  120.    delay4_6ms();
  121.     writectrl((0x80+x));//寫指令設(shè)置 水平  行地址 X軸  “0”
  122.        delay4_6ms();
  123.   writedate(tab[i]);  //數(shù)據(jù)寫入FFH
  124.         i++;
  125.   writedate(tab[i]);  //數(shù)據(jù)寫入FFH
  126.   delay4_6ms();
  127.      i++;
  128.
  129.      x++;
  130.
  131.     }
  132.     y++;
  133.
  134. }
  135. //;***********以上是上半屏(Y=0-1F,X=0-07)以下是下扳平Y(jié)=8-0F X=0-1F********************************
  136. x=0;y=0;
  137. for( h=0;h<32;h++  )
  138. {
  139.      x=0;
  140.    for (k=0;k<8;k++)
  141.    {
  142.
  143.
  144.    writectrl((0x80+y));/:/寫指令設(shè)置  垂直  列地址 Y軸為  “0”
  145.    delay4_6ms();
  146.     writectrl((0x88+x));//寫指令設(shè)置 水平  行地址 X軸  “0”
  147.        delay4_6ms();
  148.    writedate(0x00);  //數(shù)據(jù)寫入FFH
  149.          i++;
  150.    writedate(0x00);  //數(shù)據(jù)寫入FFH
  151.
  152.   delay4_6ms();
  153.          i++;
  154.      x++;
  155.
  156.     }
  157.     y++;
  158.
  159. }
  160.
  161. while(1);  //*******************************************************
  162.             //12864到今晚我也成功了,呵呵,我是這樣的:把12864分成兩部分,上半部分12832,下半部分12832
  163.       //然后用掃描的辦法從第一行開始掃描,知道32行,在執(zhí)行下半部分掃描程序,第33行開始,掃描32行道64至
  164.       //這里還要說一個(gè)事:關(guān)于12864畫圖,你看那大海,水很多,但是它是由一滴滴水組成的,所以要想在12864屏幕上顯示一幅圖像,你就要
  165.       //從一個(gè)點(diǎn)開始,第一步我讓第一行的第一列顯示一個(gè)點(diǎn),怎么實(shí)現(xiàn)呢?我開始很是不明白,看了一天的手冊(cè),一下午的實(shí)驗(yàn),終于總結(jié)出
  166.       //1:向7920的寫入3F和3E指令,使液晶工作在擴(kuò)展指令狀態(tài),8位數(shù)據(jù),繪圖開關(guān)開2:設(shè)定繪圖RAM地址,先寫入列(Y軸)再寫入行(X軸)
  167.       //然后再一口氣寫入16位的數(shù)據(jù),也可以寫8位,但要寫2次,我是采取后者,然后這十六是什么呢?---即這樣的排列D15-D0,讓第一個(gè)點(diǎn)就寫入8000H
  168.       //那么,現(xiàn)在就是在第一行第一列顯示一個(gè)點(diǎn)!呵呵,會(huì)寫一個(gè)點(diǎn),你就一定會(huì)寫一幅圖像了,為什么呢,你只要讓單片機(jī)這樣重復(fù)的寫512個(gè)字就是有一幅
  169.       //12864的圖像了,這其實(shí)說白了就是點(diǎn)陣啊----------
  170.       //呵呵,2010年11月17日  與天津開發(fā)區(qū)第四項(xiàng)目部宿舍,操今天給分包隊(duì)干了一天的活,很郁悶,但是有單片機(jī)真的讓我開心起來
  171.       //
  172.       //
  173.       //
  174.       //
  175.       //
  176.       //
  177.       //
  178.       ///
  179.       //***************************************************8
  180. }
