標(biāo)題: STM32 ADC筆記單次轉(zhuǎn)換已測(cè)試通過(guò) [打印本頁(yè)]
作者: niuniu    時(shí)間: 2015-6-9 03:01
下面分別為庫(kù)函數(shù)和直接操作寄存器的兩個(gè)范便,我都已測(cè)試通過(guò)
使用此程序前必要對(duì)GPIO設(shè)好為模擬輸入方式
=====================================庫(kù)函數(shù)版=========================================
void AD_CONFIG_SINGLE(void )
//先配置IO口:
ADC_InitTypeDef adcInitStruct;
//  //PB1作為模擬通道輸入引腳
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 ,ENABLE);   //使能ADC和GPIOC時(shí)鐘
//配置ADC:
//將ADC配置成非掃描方式(就是每次處理時(shí)不會(huì)掃描本組內(nèi)的所有端口),因?yàn)椴捎靡?guī)則組時(shí)只有一個(gè)寄存器保存adc結(jié)果;單次模式。
adcInitStruct.ADC_Mode = ADC_Mode_Independent;
adcInitStruct.ADC_ScanConvMode = DISABLE;
adcInitStruct.ADC_ContinuousConvMode = DISABLE;
adcInitStruct.ADC_ExternalTrigConv =ADC_ExternalTrigConv_None;
adcInitStruct.ADC_DataAlign = ADC_DataAlign_Right;
adcInitStruct.ADC_NbrOfChannel = 1;
ADC_Init(ADC1, &adcInitStruct);
       ADC_Cmd(ADC1, ENABLE);
       ADC_TempSensorVrefintCmd(ENABLE);
  ADC_ResetCalibration(ADC1);
  while((ADC_GetResetCalibrationStatus(ADC1)));//&& (timeOut--));
  ADC_StartCalibration(ADC1);
  while((ADC_GetCalibrationStatus(ADC1)));//&& (timeOut--));
//每次掃描時(shí)調(diào)用函數(shù):
u16AD_sysGetAdcResult(void)
   u16 ad;
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1,ADC_SampleTime_55Cycles5);
ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
   ADC_SoftwareStartConvCmd(ADC1, ENABLE);
   while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)==0);
    ad =ADC_GetConversionValue(ADC1);
   //ADC_TempSensorVrefintCmd(DISABLE);
   //ADC_SoftwareStartConvCmd(ADC1, DISABLE);
   //ADC_Cmd(ADC1, DISABLE);
    returnad;
=====================================寄存器版=========================================
void   AD_CONFIG_SINGLE(void)
       //先初始化 IO 口
       //RCC->APB2ENR|=1<<2;       //使能 PORTA 口時(shí)鐘
       //GPIOA->CRL&=0XFFFF0000;//PA0 1 2 3anolog 輸入
       //通道 10/11設(shè)置
       RCC->APB2ENR|=1<<9;       //ADC1時(shí)鐘使能
       RCC->APB2RSTR|=1<<9;     //ADC1 復(fù)位
       RCC->APB2RSTR&=~(1<<9);//復(fù)位結(jié)束
       RCC->CFGR&=~(3<<14);     //分頻因子清零
       //SYSCLK/DIV2=12M ADC 時(shí)鐘設(shè)置為 12M,ADC 最大時(shí)鐘不能超過(guò) 14M!
       //否則將導(dǎo)致 ADC 準(zhǔn)確度下降!
       RCC->CFGR|=2<<14;
       ADC1->CR1&=0XF0FFFF;     //工作模式清零
       ADC1->CR1|=0<<16;           //獨(dú)立工作模式
       ADC1->CR1&=~(1<<8);       //非掃描模式
       ADC1->CR2&=~(1<<1);       //單次轉(zhuǎn)換模式
       ADC1->CR2&=~(7<<17);
       ADC1->CR2|=7<<17;         //軟件控制轉(zhuǎn)換
       ADC1->CR2|=1<<20;           //使用用外部觸發(fā)(SWSTART)!!! 必須使用一個(gè)事件來(lái)觸發(fā)
       ADC1->CR2&=~(1<<11);     //右對(duì)齊
       ADC1->SQR1&=~(0XF<<20);
       ADC1->SQR1&=0<<20;         //1 個(gè)轉(zhuǎn)換在規(guī)則序列中  也就是只轉(zhuǎn)換規(guī)則序列1
       //設(shè)置通道 0~3 的采樣時(shí)間
       ADC1->SMPR1|=7;//通道 10  239.5周期,提高采樣時(shí)間可以提高精確度
       ADC1->CR2|=1<<0;             //開(kāi)啟 AD轉(zhuǎn)換器
       ADC1->CR2|=1<<3;               //使能復(fù)位校準(zhǔn)
       while(ADC1->CR2&1<<3);   //等待校準(zhǔn)結(jié)束
       //該位由軟件設(shè)置并由硬件清除。在校準(zhǔn)寄存器被初始化后該位將被清除。
       ADC1->CR2|=1<<2;               //開(kāi)啟 AD校準(zhǔn)
       while(ADC1->CR2&1<<2);   //等待校準(zhǔn)結(jié)束
       //該位由軟件設(shè)置以開(kāi)始校準(zhǔn),并在校準(zhǔn)結(jié)束時(shí)由硬件清除
//獲得 ADC 值
//ch:通道值  0~3
       //設(shè)置轉(zhuǎn)換序列
       ADC1->SQR3&=0XFFFFFFE0;//規(guī)則序列1  通道 ch
       ADC1->SQR3|=10;
       ADC1->CR2|=1<<22;             //啟動(dòng)規(guī)則轉(zhuǎn)換通道
       while(!(ADC1->SR&1<<1));//等待轉(zhuǎn)換結(jié)束
       returnADC1->DR;        //返回 adc 值
