標(biāo)題: 這個(gè)三個(gè)單片機(jī)串行通信程序有什么問(wèn)題? [打印本頁(yè)]
作者: hanbing17    時(shí)間: 2010-1-25 21:36
三個(gè)單片機(jī)串行通信,1號(hào)從機(jī)和2號(hào)從機(jī)在p1口處個(gè)接八個(gè)按鍵, 主機(jī)p0口有八個(gè)燈,另外主機(jī)在p1.0和p1.1有兩個(gè)按鍵,第一個(gè)按鍵按下接通一號(hào)從機(jī),當(dāng)1號(hào)從機(jī)有按鍵按下時(shí)候,主機(jī)p0對(duì)應(yīng)的燈亮,同理同理主機(jī)第2個(gè)按鍵按下 接通2號(hào)從機(jī),當(dāng)2號(hào)從機(jī)有按鍵按下時(shí)候,主機(jī)p0對(duì)應(yīng)的燈亮
程序如下,在protues 里仿真一點(diǎn)沒(méi)反應(yīng),請(qǐng)教下誰(shuí)能幫我看下程序錯(cuò)在哪里怎么改? 麻煩了 謝謝!!
主機(jī):
ORG 00H
AJMP MAIN
ORG 30H
MAIN:
       MOV SCON,#98H
START: MOV A,P1
       CJNE A,#0FFH,M1
       SJMP START
M1:    CJNE A,#0FEH,M2
       SJMP L1
M2:    CJNE A,#0FDH,START
       SJMP L2
L1:    MOV SBUF,#01H
       JBC TI,S1
       SJMP L1
L2:    MOV SBUF,#02H
       JBC TI,S2
       SJMP L2
S1:    JBC RI,WT1
       SJMP S1
S2:    JBC RI,WT2
       SJMP S2
WT1:   MOV A,SBUF
       XRL A,#01H
       JZ RIGHT
       SJMP WT1
WT2:   MOV A,SBUF
       XRL A,#02H
       JZ RIGHT
       SJMP WT2
RIGHT: CLR TB8
       JBC RI,REC
       SJMP RIGHT
REC:   MOV A,SBUF
       MOV P0,A
      AJMP RIGHT
      END
從機(jī):
ORG 00H
AJMP MAIN
ORG 30H
MAIN: MOV SCON,#0B0H
      MOV 30H,#0FFH
M1:   JBC RI,S1
      SJMP M1
S1:   MOV A,SBUF
      XRL A,#02H
      JNZ M1
      MOV SBUF,#02H
      MOV P0,#0FDH
WT:   JBC TI,S2
      SJMP WT
S2:   JNB RB8,RIGHT
      SETB SM2
      SJMP M1
RIGHT:MOV A,P1
      CJNE A,30H,SENT
      JMP RIGHT
SENT: MOV 30H,A
      MOV SBUF,A
WAIT: JBC TI, RIGHT
      SJMP WAIT
      END
