標(biāo)題: 51單片機中斷和查詢工作模式的區(qū)別 [打印本頁]
作者: liuqq    時間: 2015-5-20 18:17
中斷是硬件自動的清零,查詢?nèi)绻遣樵兊腡FX就必須軟件清零,如果查詢的是THX和TLX就也是硬件自動的清零。驗證的程序如:
#include <reg51.h>
uchar count ;
sbit LED=P3^0;
        TMOD = 0X01;
        TH0 = (65536 - 50000)/256;
        TL0 = (65536 - 50000)%256;
        ET0 =1;
        TR0 = 1;
            while(TF0 == 1)
                        if(count++ == 50)
                            LED =!LED;
                    TF0 = 0;
                }        //查詢工作的模式        軟件清零
#include <reg51.h>
uint count=0;
       TMOD = 0X01;
        TH0 = (65536-50000)/256;
        TL0 =(65536-50000)%256;
        ET0 = 1;
        TR0 = 1;
                if((TH0 == 65535/256)&&(TL0 == 65535%256))                {
                        count++;
                        if(count == 50)
                                P3 = ~P3;
                                count = 0;
                    TH0 =(65536-50000)/256;
