51單片機籃球計分器程序+電路圖
niuniu
2015-4-19 23:14
51單片機籃球計分器程序+電路圖
下面是電路圖:
以下是籃球計分器的c語言程序源代碼:
#include<reg52.h>
#include <intrins.h>
uchar secs = 0;
uchar minutes = 1;
uchar LED,num1,num2,num = 4;
uchar flag1 = 1,flag2 = 0;
uchar m_secs = 24;
uchar key_value = 0;
uchar table[13] = {1,2,3,4,5,6,7,8,9,0,1,2,3};
uchar code LedNum[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar scan_kay(void);
void delay(uchar z);
void INT0_Initial(void)
EX0 = 1;
IT0 = 1;
EA = 1;
P1 = 0xF0;
void INT0_Interrupt(void) interrupt 0
uchar temp;
temp = scan_kay();
if(temp!=0x7f)
key_value = temp;
P1 = 0xF0;
void Time0_Initial(void)
TMOD = 0x01;
TH0 = (65536-50000)/256;
TL0 = (65536-50000)%256;
ET0 = 1;
TR0 = 1;
EA = 1;
PT0 = 1;
PX0 = 0;
volatile uchar cnt = 0;
void Time0_Interrupt(void) interrupt 1
cnt ++;
minutes=11;
if(cnt==15)
cnt = 0;
secs --;
m_secs --;
if(flag2==1)
LED = !LED;
if(flag2==0)
LED = 0;
if(secs>60)
secs = 59;
minutes --;
if(m_secs>24)
m_secs = 23;
if(flag1==1)
flag2 = 1;
if(flag1==0)
flag2 = 0;
if(minutes>60)
minutes = 11;
m_secs = 24;
num ++;
if(num==4)
num = 1;
void HEXTOBCD(void)
table[0] = LedNum[num];
table[1] = LedNum[m_secs/10];
table[2] = LedNum[m_secs%10];
table[3] = LedNum[minutes/10];
table[4] = LedNum[minutes%10];
table[5] = LedNum[secs/10];
table[6] = LedNum[secs%10];
table[7] = LedNum[num1/100];
table[8] = LedNum[num1%100/10];
table[9] = LedNum[num1%10];
table[10] = LedNum[num2/100];
table[11] = LedNum[num2%100/10];
table[12] = LedNum[num2%10];
void Display(uchar *str)
uchar i,temp = 0;
for(i=0;i<13;i++)
P0 = 0x00;
_nop_();
P2 = temp+i;
P0 = str[i];
delay(2);
uchar i,j;
void delay(uchar z)
for(i=1;i<z;i++)
for(j=1;j<110;j++);
INT0_Initial();
Time0_Initial();
delay(10);
LED = 0;
switch(key_value)
case 12:
num1 ++;key_value = 0;
flag1 = 0;
if(num1>255)
num1 = 0;
break;
case 13:
num1 --;key_value = 0;
flag1 = 0;
if(num1>255)
num1 = 255;
break;
case 14:
num2 ++;key_value = 0;
flag1 = 0;
if(num2>255)
num2 = 0;
break;
case 15:
num2 --;key_value = 0;
flag1 = 0;
if(num2>255)
num2 = 255;
break;
case 1:
TR0 = 1;
key_value = 0;
break;
case 2:
num1 = 0;num2 = 0;
num = 4;
secs = 0;minutes = 12;
m_secs = 24;
key_value = 0;
TR0 = 1;
break;
case 3:
TR0 = 0;
key_value = 0;
break;
default:
break;
HEXTOBCD();
delay(5);
Display(table);
delay(10);
uchar scan_key(void)
uchar i,key_value;
P1 = 0xFF;
for(i=0;i<4;i++)
P1 = ~(1<<i);
key_value = P1&0xF0;
if(key_value!=0xF0)
delay(20);
if(key_value!=0xF0)
key_value &= 0xF0;
switch(key_value)
case 0x70: key_value = 15-(3-i)*4;break;
case 0xb0: key_value = 14-(3-i)*4;break;
case 0xd0: key_value = 13-(3-i)*4;break;
case 0xe0: key_value = 12-(3-i)*4;break;
default: key_value = 0x7f;
return key_value;
P1 = 0xFF;
return 0x7f;
uchar key_va1,key_va2;
key_va1 = scan_key();
if(key_va1==0x7f)
return 0x7f;
do
key_va2 = scan_key();
}while(key_va1==key_va2);
return key_va1;
籃球計分器的仿真文件下載:
http://www.raoushi.com/bbs/dpj-51424-1.html
2015-4-21 00:59
好東西來的..
佼佼の者
2015-4-25 16:18
贊。。。。。。。。。。。。。。。。。。
不留余力
2015-5-25 15:11
樓主,板子是自己焊的嗎
不留余力
2015-5-25 15:11
我很想做,請?zhí)峁c意見
413huade
2016-3-29 14:50
譯碼器 為什么No model.......
0827dongdong
2016-4-16 19:12
頂起,版主加油哦
ZhTSh
2016-4-17 17:30
不錯不錯
598509644
2016-4-18 21:14
感謝樓主分享,收藏了先
sunxiaohua
2016-4-19 18:06
還有電路圖的顯示器是用共陰還是共陽
好久不見
2016-11-17 17:09
不錯,可以看看
xiaokobe
2016-12-17 19:05
sunxiaohua 發(fā)表于 2016-4-19 18:06
**** 作者被禁止或刪除 內(nèi)容自動屏蔽 ****
共陰極的
wwww1
2017-2-1 10:37
感謝樓主分享
todaaae
2017-11-2 16:53
感謝樓主分享,收藏了先
todaaae
2017-11-2 16:53
感謝樓主分享!
pengyongnet
2018-6-27 09:15
能分享下源文件圖加程序嗎
pengyongnet
2018-6-27 09:16
能分享下源文件圖加程序嗎?學習下
2452047173
2018-6-30 16:16
樓主厲害呀
WCYYYYYYYYY
2020-9-4 16:14
這是完整的程序嗎?
