msp430.h頭文件下載
das
2015-4-18 01:25
msp430.h頭文件下載
msp430.h單片機頭文件代碼最后的復(fù)制代碼保存到電腦的方式實現(xiàn)下載:
/* Legacy Header File */
/* Not recommended for use in new projects. */
/* Please use the msp430.h file or the device specific header file */
* Standard register and bit definitions for the Texas Instruments
* MSP430 microcontroller.
* This file supports assembler and C development for
* MSP430x22x4 devices.
* Texas Instruments, Version 1.5
* Rev. 1.0, Setup
* Rev. 1.1, Updated names for USCI
* Rev. 1.2, Added missing definitions in OA and ADC10
* Rev. 1.3 Removed bit definitions for ADC10AEx as this are in conflict with ADC10AEx Register
* Removed not existing SWCTL register definition
* Rev. 1.4, added definitions for Interrupt Vectors xxIV
* Rev. 1.5, Fixed typo in ADC10: SREF3 -> SREF2
#ifndef __msp430x22x4
#define __msp430x22x4
#define __MSP430_HEADER_VERSION__ 1065 /* Beta-Build-Tag: #0023 */
#ifdef __IAR_SYSTEMS_ICC__
#ifndef _SYSTEM_BUILD
#pragma system_include
#endif
#endif
#if (((__TID__ >> 8) & 0x7F) != 0x2b) /* 0x2b = 43 dec */
#error msp430x22x4.h file for use with ICC430/A430 only
#endif
#include "in430.h"
#pragma language=extended
#define DEFC(name, address) __no_init volatile unsigned char name @ address;
#define DEFW(name, address) __no_init volatile unsigned short name @ address;
#define DEFXC volatile unsigned char
#define DEFXW volatile unsigned short
#endif /* __IAR_SYSTEMS_ICC__ */
#ifdef __IAR_SYSTEMS_ASM__
#define DEFC(name, address) sfrb name = address;
#define DEFW(name, address) sfrw name = address;
#endif /* __IAR_SYSTEMS_ASM__*/
#ifdef __cplusplus
#define READ_ONLY
#else
#define READ_ONLY const
#endif
* STANDARD BITS
#define BIT0 (0x0001u)
#define BIT1 (0x0002u)
#define BIT2 (0x0004u)
#define BIT3 (0x0008u)
#define BIT4 (0x0010u)
#define BIT5 (0x0020u)
#define BIT6 (0x0040u)
#define BIT7 (0x0080u)
#define BIT8 (0x0100u)
#define BIT9 (0x0200u)
#define BITA (0x0400u)
#define BITB (0x0800u)
#define BITC (0x1000u)
#define BITD (0x2000u)
#define BITE (0x4000u)
#define BITF (0x8000u)
* STATUS REGISTER BITS
#define C (0x0001u)
#define Z (0x0002u)
#define N (0x0004u)
#define V (0x0100u)
#define GIE (0x0008u)
#define CPUOFF (0x0010u)
#define OSCOFF (0x0020u)
#define SCG0 (0x0040u)
#define SCG1 (0x0080u)
/* Low Power Modes coded with Bits 4-7 in SR */
#ifndef __IAR_SYSTEMS_ICC__ /* Begin #defines for assembler */
#define LPM0 (CPUOFF)
#define LPM1 (SCG0+CPUOFF)
#define LPM2 (SCG1+CPUOFF)
#define LPM3 (SCG1+SCG0+CPUOFF)
#define LPM4 (SCG1+SCG0+OSCOFF+CPUOFF)
/* End #defines for assembler */
#else /* Begin #defines for C */
#define LPM0_bits (CPUOFF)
#define LPM1_bits (SCG0+CPUOFF)
#define LPM2_bits (SCG1+CPUOFF)
#define LPM3_bits (SCG1+SCG0+CPUOFF)
#define LPM4_bits (SCG1+SCG0+OSCOFF+CPUOFF)
#include "in430.h"
#define LPM0 _BIS_SR(LPM0_bits) /* Enter Low Power Mode 0 */
#define LPM0_EXIT _BIC_SR_IRQ(LPM0_bits) /* Exit Low Power Mode 0 */
#define LPM1 _BIS_SR(LPM1_bits) /* Enter Low Power Mode 1 */
#define LPM1_EXIT _BIC_SR_IRQ(LPM1_bits) /* Exit Low Power Mode 1 */
#define LPM2 _BIS_SR(LPM2_bits) /* Enter Low Power Mode 2 */
#define LPM2_EXIT _BIC_SR_IRQ(LPM2_bits) /* Exit Low Power Mode 2 */
#define LPM3 _BIS_SR(LPM3_bits) /* Enter Low Power Mode 3 */
#define LPM3_EXIT _BIC_SR_IRQ(LPM3_bits) /* Exit Low Power Mode 3 */
#define LPM4 _BIS_SR(LPM4_bits) /* Enter Low Power Mode 4 */
#define LPM4_EXIT _BIC_SR_IRQ(LPM4_bits) /* Exit Low Power Mode 4 */
#endif /* End #defines for C */
* PERIPHERAL FILE MAP
* SPECIAL FUNCTION REGISTER ADDRESSES + CONTROL BITS
#define IE1_ (0x0000u) /* Interrupt Enable 1 */
DEFC( IE1 , IE1_)
#define WDTIE (0x01) /* Watchdog Interrupt Enable */
#define OFIE (0x02) /* Osc. Fault Interrupt Enable */
#define NMIIE (0x10) /* NMI Interrupt Enable */
#define ACCVIE (0x20) /* Flash Access Violation Interrupt Enable */
#define IFG1_ (0x0002u) /* Interrupt Flag 1 */
DEFC( IFG1 , IFG1_)
#define WDTIFG (0x01) /* Watchdog Interrupt Flag */
#define OFIFG (0x02) /* Osc. Fault Interrupt Flag */
#define PORIFG (0x04) /* Power On Interrupt Flag */
#define RSTIFG (0x08) /* Reset Interrupt Flag */
#define NMIIFG (0x10) /* NMI Interrupt Flag */
#define IE2_ (0x0001u) /* Interrupt Enable 2 */
DEFC( IE2 , IE2_)
#define UC0IE IE2
#define UCA0RXIE (0x01)
#define UCA0TXIE (0x02)
#define UCB0RXIE (0x04)
#define UCB0TXIE (0x08)
#define IFG2_ (0x0003u) /* Interrupt Flag 2 */
DEFC( IFG2 , IFG2_)
#define UC0IFG IFG2
#define UCA0RXIFG (0x01)
#define UCA0TXIFG (0x02)
#define UCB0RXIFG (0x04)
#define UCB0TXIFG (0x08)
* ADC10
#define __MSP430_HAS_ADC10__ /* Definition to show that Module is available */
#define ADC10DTC0_ (0x0048u) /* ADC10 Data Transfer Control 0 */
DEFC( ADC10DTC0 , ADC10DTC0_)
#define ADC10DTC1_ (0x0049u) /* ADC10 Data Transfer Control 1 */
DEFC( ADC10DTC1 , ADC10DTC1_)
#define ADC10AE0_ (0x004Au) /* ADC10 Analog Enable 0 */
DEFC( ADC10AE0 , ADC10AE0_)
#define ADC10AE1_ (0x004Bu) /* ADC10 Analog Enable 1 */
DEFC( ADC10AE1 , ADC10AE1_)
#define ADC10CTL0_ (0x01B0u) /* ADC10 Control 0 */
DEFW( ADC10CTL0 , ADC10CTL0_)
#define ADC10CTL1_ (0x01B2u) /* ADC10 Control 1 */
DEFW( ADC10CTL1 , ADC10CTL1_)
#define ADC10MEM_ (0x01B4u) /* ADC10 Memory */
DEFW( ADC10MEM , ADC10MEM_)
#define ADC10SA_ (0x01BCu) /* ADC10 Data Transfer Start Address */
DEFW( ADC10SA , ADC10SA_)
/* ADC10CTL0 */
#define ADC10SC (0x001) /* ADC10 Start Conversion */
#define ENC (0x002) /* ADC10 Enable Conversion */
#define ADC10IFG (0x004) /* ADC10 Interrupt Flag */
#define ADC10IE (0x008) /* ADC10 Interrupt Enalbe */
#define ADC10ON (0x010) /* ADC10 On/Enable */
#define REFON (0x020) /* ADC10 Reference on */
#define REF2_5V (0x040) /* ADC10 Ref 0:1.5V / 1:2.5V */
#define MSC (0x080) /* ADC10 Multiple SampleConversion */
#define REFBURST (0x100) /* ADC10 Reference Burst Mode */
#define REFOUT (0x200) /* ADC10 Enalbe output of Ref. */
#define ADC10SR (0x400) /* ADC10 Sampling Rate 0:200ksps / 1:50ksps */
#define ADC10SHT0 (0x800) /* ADC10 Sample Hold Select Bit: 0 */
#define ADC10SHT1 (0x1000u) /* ADC10 Sample Hold Select Bit: 1 */
#define SREF0 (0x2000u) /* ADC10 Reference Select Bit: 0 */
#define SREF1 (0x4000u) /* ADC10 Reference Select Bit: 1 */
#define SREF2 (0x8000u) /* ADC10 Reference Select Bit: 2 */
#define ADC10SHT_0 (0*0x800u) /* 4 x ADC10CLKs */
#define ADC10SHT_1 (1*0x800u) /* 8 x ADC10CLKs */
#define ADC10SHT_2 (2*0x800u) /* 16 x ADC10CLKs */
#define ADC10SHT_3 (3*0x800u) /* 64 x ADC10CLKs */
#define SREF_0 (0*0x2000u) /* VR+ = AVCC and VR- = AVSS */
#define SREF_1 (1*0x2000u) /* VR+ = VREF+ and VR- = AVSS */
#define SREF_2 (2*0x2000u) /* VR+ = VEREF+ and VR- = AVSS */
#define SREF_3 (3*0x2000u) /* VR+ = VEREF+ and VR- = AVSS */
#define SREF_4 (4*0x2000u) /* VR+ = AVCC and VR- = VREF-/VEREF- */
#define SREF_5 (5*0x2000u) /* VR+ = VREF+ and VR- = VREF-/VEREF- */
#define SREF_6 (6*0x2000u) /* VR+ = VEREF+ and VR- = VREF-/VEREF- */
#define SREF_7 (7*0x2000u) /* VR+ = VEREF+ and VR- = VREF-/VEREF- */
/* ADC10CTL1 */
#define ADC10BUSY (0x0001u) /* ADC10 BUSY */
#define CONSEQ0 (0x0002u) /* ADC10 Conversion Sequence Select 0 */
#define CONSEQ1 (0x0004u) /* ADC10 Conversion Sequence Select 1 */
#define ADC10SSEL0 (0x0008u) /* ADC10 Clock Source Select Bit: 0 */
#define ADC10SSEL1 (0x0010u) /* ADC10 Clock Source Select Bit: 1 */
#define ADC10DIV0 (0x0020u) /* ADC10 Clock Divider Select Bit: 0 */
#define ADC10DIV1 (0x0040u) /* ADC10 Clock Divider Select Bit: 1 */
#define ADC10DIV2 (0x0080u) /* ADC10 Clock Divider Select Bit: 2 */
#define ISSH (0x0100u) /* ADC10 Invert Sample Hold Signal */
#define ADC10DF (0x0200u) /* ADC10 Data Format 0:binary 1:2's complement */
#define SHS0 (0x0400u) /* ADC10 Sample/Hold Source Bit: 0 */
#define SHS1 (0x0800u) /* ADC10 Sample/Hold Source Bit: 1 */
#define INCH0 (0x1000u) /* ADC10 Input Channel Select Bit: 0 */
#define INCH1 (0x2000u) /* ADC10 Input Channel Select Bit: 1 */
#define INCH2 (0x4000u) /* ADC10 Input Channel Select Bit: 2 */
#define INCH3 (0x8000u) /* ADC10 Input Channel Select Bit: 3 */
#define CONSEQ_0 (0*2u) /* Single channel single conversion */
#define CONSEQ_1 (1*2u) /* Sequence of channels */
#define CONSEQ_2 (2*2u) /* Repeat single channel */
#define CONSEQ_3 (3*2u) /* Repeat sequence of channels */
#define ADC10SSEL_0 (0*8u) /* ADC10OSC */
#define ADC10SSEL_1 (1*8u) /* ACLK */
#define ADC10SSEL_2 (2*8u) /* MCLK */
#define ADC10SSEL_3 (3*8u) /* SMCLK */
#define ADC10DIV_0 (0*0x20u) /* ADC10 Clock Divider Select 0 */
#define ADC10DIV_1 (1*0x20u) /* ADC10 Clock Divider Select 1 */
#define ADC10DIV_2 (2*0x20u) /* ADC10 Clock Divider Select 2 */
#define ADC10DIV_3 (3*0x20u) /* ADC10 Clock Divider Select 3 */
#define ADC10DIV_4 (4*0x20u) /* ADC10 Clock Divider Select 4 */
#define ADC10DIV_5 (5*0x20u) /* ADC10 Clock Divider Select 5 */
#define ADC10DIV_6 (6*0x20u) /* ADC10 Clock Divider Select 6 */
#define ADC10DIV_7 (7*0x20u) /* ADC10 Clock Divider Select 7 */
#define SHS_0 (0*0x400u) /* ADC10SC */
#define SHS_1 (1*0x400u) /* TA3 OUT1 */
#define SHS_2 (2*0x400u) /* TA3 OUT0 */
#define SHS_3 (3*0x400u) /* TA3 OUT2 */
#define INCH_0 (0*0x1000u) /* Selects Channel 0 */
#define INCH_1 (1*0x1000u) /* Selects Channel 1 */
#define INCH_2 (2*0x1000u) /* Selects Channel 2 */
#define INCH_3 (3*0x1000u) /* Selects Channel 3 */
#define INCH_4 (4*0x1000u) /* Selects Channel 4 */
#define INCH_5 (5*0x1000u) /* Selects Channel 5 */
#define INCH_6 (6*0x1000u) /* Selects Channel 6 */
#define INCH_7 (7*0x1000u) /* Selects Channel 7 */
#define INCH_8 (8*0x1000u) /* Selects Channel 8 */
#define INCH_9 (9*0x1000u) /* Selects Channel 9 */
#define INCH_10 (10*0x1000u) /* Selects Channel 10 */
#define INCH_11 (11*0x1000u) /* Selects Channel 11 */
#define INCH_12 (12*0x1000u) /* Selects Channel 12 */
#define INCH_13 (13*0x1000u) /* Selects Channel 13 */
#define INCH_14 (14*0x1000u) /* Selects Channel 14 */
#define INCH_15 (15*0x1000u) /* Selects Channel 15 */
/* ADC10DTC0 */
#define ADC10FETCH (0x001) /* This bit should normally be reset */
#define ADC10B1 (0x002) /* ADC10 block one */
#define ADC10CT (0x004) /* ADC10 continuous transfer */
#define ADC10TB (0x008) /* ADC10 two-block mode */
#define ADC10DISABLE (0x000) /* ADC10DTC1 */
* Basic Clock Module
#define __MSP430_HAS_BC2__ /* Definition to show that Module is available */
#define DCOCTL_ (0x0056u) /* DCO Clock Frequency Control */
DEFC( DCOCTL , DCOCTL_)
#define BCSCTL1_ (0x0057u) /* Basic Clock System Control 1 */
DEFC( BCSCTL1 , BCSCTL1_)
#define BCSCTL2_ (0x0058u) /* Basic Clock System Control 2 */
DEFC( BCSCTL2 , BCSCTL2_)
#define BCSCTL3_ (0x0053u) /* Basic Clock System Control 3 */
DEFC( BCSCTL3 , BCSCTL3_)
#define MOD0 (0x01) /* Modulation Bit 0 */
#define MOD1 (0x02) /* Modulation Bit 1 */
#define MOD2 (0x04) /* Modulation Bit 2 */
#define MOD3 (0x08) /* Modulation Bit 3 */
#define MOD4 (0x10) /* Modulation Bit 4 */
#define DCO0 (0x20) /* DCO Select Bit 0 */
#define DCO1 (0x40) /* DCO Select Bit 1 */
#define DCO2 (0x80) /* DCO Select Bit 2 */
#define RSEL0 (0x01) /* Range Select Bit 0 */
#define RSEL1 (0x02) /* Range Select Bit 1 */
#define RSEL2 (0x04) /* Range Select Bit 2 */
#define RSEL3 (0x08) /* Range Select Bit 3 */
#define DIVA0 (0x10) /* ACLK Divider 0 */
#define DIVA1 (0x20) /* ACLK Divider 1 */
#define XTS (0x40) /* LFXTCLK 0:Low Freq. / 1: High Freq. */
#define XT2OFF (0x80) /* Enable XT2CLK */
#define DIVA_0 (0x00) /* ACLK Divider 0: /1 */
#define DIVA_1 (0x10) /* ACLK Divider 1: /2 */
#define DIVA_2 (0x20) /* ACLK Divider 2: /4 */
#define DIVA_3 (0x30) /* ACLK Divider 3: /8 */
#define DCOR (0x01) /* Enable External Resistor : 1 */
#define DIVS0 (0x02) /* SMCLK Divider 0 */
#define DIVS1 (0x04) /* SMCLK Divider 1 */
#define SELS (0x08) /* SMCLK Source Select 0:DCOCLK / 1:XT2CLK/LFXTCLK */
#define DIVM0 (0x10) /* MCLK Divider 0 */
#define DIVM1 (0x20) /* MCLK Divider 1 */
#define SELM0 (0x40) /* MCLK Source Select 0 */
#define SELM1 (0x80) /* MCLK Source Select 1 */
#define DIVS_0 (0x00) /* SMCLK Divider 0: /1 */
#define DIVS_1 (0x02) /* SMCLK Divider 1: /2 */
#define DIVS_2 (0x04) /* SMCLK Divider 2: /4 */
#define DIVS_3 (0x06) /* SMCLK Divider 3: /8 */
#define DIVM_0 (0x00) /* MCLK Divider 0: /1 */
#define DIVM_1 (0x10) /* MCLK Divider 1: /2 */
#define DIVM_2 (0x20) /* MCLK Divider 2: /4 */
#define DIVM_3 (0x30) /* MCLK Divider 3: /8 */
#define SELM_0 (0x00) /* MCLK Source Select 0: DCOCLK */
#define SELM_1 (0x40) /* MCLK Source Select 1: DCOCLK */
#define SELM_2 (0x80) /* MCLK Source Select 2: XT2CLK/LFXTCLK */
#define SELM_3 (0xC0) /* MCLK Source Select 3: LFXTCLK */
#define LFXT1OF (0x01) /* Low/high Frequency Oscillator Fault Flag */
#define XT2OF (0x02) /* High frequency oscillator 2 fault flag */
#define XCAP0 (0x04) /* XIN/XOUT Cap 0 */
#define XCAP1 (0x08) /* XIN/XOUT Cap 1 */
#define LFXT1S0 (0x10) /* Mode 0 for LFXT1 (XTS = 0) */
#define LFXT1S1 (0x20) /* Mode 1 for LFXT1 (XTS = 0) */
#define XT2S0 (0x40) /* Mode 0 for XT2 */
#define XT2S1 (0x80) /* Mode 1 for XT2 */
#define XCAP_0 (0x00) /* XIN/XOUT Cap : 0 pF */
#define XCAP_1 (0x04) /* XIN/XOUT Cap : 6 pF */
#define XCAP_2 (0x08) /* XIN/XOUT Cap : 10 pF */
#define XCAP_3 (0x0C) /* XIN/XOUT Cap : 12.5 pF */
#define LFXT1S_0 (0x00) /* Mode 0 for LFXT1 : Normal operation */
#define LFXT1S_1 (0x10) /* Mode 1 for LFXT1 : Reserved */
#define LFXT1S_2 (0x20) /* Mode 2 for LFXT1 : VLO */
#define LFXT1S_3 (0x30) /* Mode 3 for LFXT1 : Digital input signal */
#define XT2S_0 (0x00) /* Mode 0 for XT2 : 0.4 - 1 MHz */
#define XT2S_1 (0x40) /* Mode 1 for XT2 : 1 - 4 MHz */
#define XT2S_2 (0x80) /* Mode 2 for XT2 : 2 - 16 MHz */
#define XT2S_3 (0xC0) /* Mode 3 for XT2 : Digital input signal */
* Flash Memory
#define __MSP430_HAS_FLASH2__ /* Definition to show that Module is available */
#define FCTL1_ (0x0128u) /* FLASH Control 1 */
DEFW( FCTL1 , FCTL1_)
#define FCTL2_ (0x012Au) /* FLASH Control 2 */
DEFW( FCTL2 , FCTL2_)
#define FCTL3_ (0x012Cu) /* FLASH Control 3 */
DEFW( FCTL3 , FCTL3_)
#define FRKEY (0x9600u) /* Flash key returned by read */
#define FWKEY (0xA500u) /* Flash key for write */
#define FXKEY (0x3300u) /* for use with XOR instruction */
#define ERASE (0x0002u) /* Enable bit for Flash segment erase */
#define MERAS (0x0004u) /* Enable bit for Flash mass erase */
#define EEI (0x0008u) /* Enable Erase Interrupts */
#define EEIEX (0x0010u) /* Enable Emergency Interrupt Exit */
#define WRT (0x0040u) /* Enable bit for Flash write */
#define BLKWRT (0x0080u) /* Enable bit for Flash segment write */
#define SEGWRT (0x0080u) /* old definition */ /* Enable bit for Flash segment write */
#define FN0 (0x0001u) /* Divide Flash clock by 1 to 64 using FN0 to FN5 according to: */
#define FN1 (0x0002u) /* 32*FN5 + 16*FN4 + 8*FN3 + 4*FN2 + 2*FN1 + FN0 + 1 */
#ifndef FN2
#define FN2 (0x0004u)
#endif
#ifndef FN3
#define FN3 (0x0008u)
#endif
#ifndef FN4
#define FN4 (0x0010u)
#endif
#define FN5 (0x0020u)
#define FSSEL0 (0x0040u) /* Flash clock select 0 */ /* to distinguish from USART SSELx */
#define FSSEL1 (0x0080u) /* Flash clock select 1 */
#define FSSEL_0 (0x0000u) /* Flash clock select: 0 - ACLK */
#define FSSEL_1 (0x0040u) /* Flash clock select: 1 - MCLK */
#define FSSEL_2 (0x0080u) /* Flash clock select: 2 - SMCLK */
#define FSSEL_3 (0x00C0u) /* Flash clock select: 3 - SMCLK */
#define BUSY (0x0001u) /* Flash busy: 1 */
#define KEYV (0x0002u) /* Flash Key violation flag */
#define ACCVIFG (0x0004u) /* Flash Access violation flag */
#define WAIT (0x0008u) /* Wait flag for segment write */
#define LOCK (0x0010u) /* Lock bit: 1 - Flash is locked (read only) */
#define EMEX (0x0020u) /* Flash Emergency Exit */
#define LOCKA (0x0040u) /* Segment A Lock bit: read = 1 - Segment is locked (read only) */
#define FAIL (0x0080u) /* Last Program or Erase failed */
* Operational Amplifier
#define __MSP430_HAS_OA_2__ /* Definition to show that Module is available */
#define OA0CTL0_ (0x00C0u) /* OA0 Control register 0 */
DEFC( OA0CTL0 , OA0CTL0_)
#define OA0CTL1_ (0x00C1u) /* OA0 Control register 1 */
DEFC( OA0CTL1 , OA0CTL1_)
#define OA1CTL0_ (0x00C2u) /* OA1 Control register 0 */
DEFC( OA1CTL0 , OA1CTL0_)
#define OA1CTL1_ (0x00C3u) /* OA1 Control register 1 */
DEFC( OA1CTL1 , OA1CTL1_)
#define OAADC0 (0x01) /* OAx output to ADC12 input channel select 0 */
#define OAADC1 (0x02) /* OAx output to ADC12 input channel select 1 */
#define OAPM0 (0x04) /* OAx Power mode select 0 */
#define OAPM1 (0x08) /* OAx Power mode select 1 */
#define OAP0 (0x10) /* OAx Non-inverting input select 0 */
#define OAP1 (0x20) /* OAx Non-inverting input select 1 */
#define OAN0 (0x40) /* OAx Inverting input select 0 */
#define OAN1 (0x80) /* OAx Inverting input select 1 */
#define OAPM_0 (0x00) /* OAx Power mode select: off */
#define OAPM_1 (0x04) /* OAx Power mode select: slow */
#define OAPM_2 (0x08) /* OAx Power mode select: meduim */
#define OAPM_3 (0x0C) /* OAx Power mode select: fast */
#define OAP_0 (0x00) /* OAx Non-inverting input select 00 */
#define OAP_1 (0x10) /* OAx Non-inverting input select 01 */
#define OAP_2 (0x20) /* OAx Non-inverting input select 10 */
#define OAP_3 (0x30) /* OAx Non-inverting input select 11 */
#define OAN_0 (0x00) /* OAx Inverting input select 00 */
#define OAN_1 (0x40) /* OAx Inverting input select 01 */
#define OAN_2 (0x80) /* OAx Inverting input select 10 */
#define OAN_3 (0xC0) /* OAx Inverting input select 11 */
#define OARRIP (0x01) /* OAx Rail-to-Rail Input off */
#define OANEXT (0x02) /* OAx Inverting input external */
//#define OACAL (0x02) /* OAx Offset Calibration */
#define OAFC0 (0x04) /* OAx Function control 0 */
#define OAFC1 (0x08) /* OAx Function control 1 */
#define OAFC2 (0x10) /* OAx Function control 2 */
#define OAFBR0 (0x20) /* OAx Feedback resistor select 0 */
#define OAFBR1 (0x40) /* OAx Feedback resistor select 1 */
#define OAFBR2 (0x80) /* OAx Feedback resistor select 2 */
#define OAFC_0 (0x00) /* OAx Function: Gen. Purpose */
#define OAFC_1 (0x04) /* OAx Function: Unity gain buffer */
#define OAFC_2 (0x08) /* OAx Function: Reserved */
#define OAFC_3 (0x0C) /* OAx Function: Comparator */
#define OAFC_4 (0x10) /* OAx Function: Non-inverting PGA */
#define OAFC_5 (0x14) /* OAx Function: Cascaded non-inverting PGA */
#define OAFC_6 (0x18) /* OAx Function: Inverting PGA */
#define OAFC_7 (0x1C) /* OAx Function: Differential amplifier */
#define OAFBR_0 (0x00) /* OAx Feedback resistor: Tap 0 */
#define OAFBR_1 (0x20) /* OAx Feedback resistor: Tap 1 */
#define OAFBR_2 (0x40) /* OAx Feedback resistor: Tap 2 */
#define OAFBR_3 (0x60) /* OAx Feedback resistor: Tap 3 */
#define OAFBR_4 (0x80) /* OAx Feedback resistor: Tap 4 */
#define OAFBR_5 (0xA0) /* OAx Feedback resistor: Tap 5 */
#define OAFBR_6 (0xC0) /* OAx Feedback resistor: Tap 6 */
#define OAFBR_7 (0xE0) /* OAx Feedback resistor: Tap 7 */
* DIGITAL I/O Port1/2 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT1_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT2_R__ /* Definition to show that Module is available */
#define P1IN_ (0x0020u) /* Port 1 Input */
READ_ONLY DEFC( P1IN , P1IN_)
#define P1OUT_ (0x0021u) /* Port 1 Output */
DEFC( P1OUT , P1OUT_)
#define P1DIR_ (0x0022u) /* Port 1 Direction */
DEFC( P1DIR , P1DIR_)
#define P1IFG_ (0x0023u) /* Port 1 Interrupt Flag */
DEFC( P1IFG , P1IFG_)
#define P1IES_ (0x0024u) /* Port 1 Interrupt Edge Select */
DEFC( P1IES , P1IES_)
#define P1IE_ (0x0025u) /* Port 1 Interrupt Enable */
DEFC( P1IE , P1IE_)
#define P1SEL_ (0x0026u) /* Port 1 Selection */
DEFC( P1SEL , P1SEL_)
#define P1REN_ (0x0027u) /* Port 1 Resistor Enable */
DEFC( P1REN , P1REN_)
#define P2IN_ (0x0028u) /* Port 2 Input */
READ_ONLY DEFC( P2IN , P2IN_)
#define P2OUT_ (0x0029u) /* Port 2 Output */
DEFC( P2OUT , P2OUT_)
#define P2DIR_ (0x002Au) /* Port 2 Direction */
DEFC( P2DIR , P2DIR_)
#define P2IFG_ (0x002Bu) /* Port 2 Interrupt Flag */
DEFC( P2IFG , P2IFG_)
#define P2IES_ (0x002Cu) /* Port 2 Interrupt Edge Select */
DEFC( P2IES , P2IES_)
#define P2IE_ (0x002Du) /* Port 2 Interrupt Enable */
DEFC( P2IE , P2IE_)
#define P2SEL_ (0x002Eu) /* Port 2 Selection */
DEFC( P2SEL , P2SEL_)
#define P2REN_ (0x002Fu) /* Port 2 Resistor Enable */
DEFC( P2REN , P2REN_)
* DIGITAL I/O Port3/4 Pull up / Pull down Resistors
#define __MSP430_HAS_PORT3_R__ /* Definition to show that Module is available */
#define __MSP430_HAS_PORT4_R__ /* Definition to show that Module is available */
#define P3IN_ (0x0018u) /* Port 3 Input */
READ_ONLY DEFC( P3IN , P3IN_)
#define P3OUT_ (0x0019u) /* Port 3 Output */
DEFC( P3OUT , P3OUT_)
#define P3DIR_ (0x001Au) /* Port 3 Direction */
DEFC( P3DIR , P3DIR_)
#define P3SEL_ (0x001Bu) /* Port 3 Selection */
DEFC( P3SEL , P3SEL_)
#define P3REN_ (0x0010u) /* Port 3 Resistor Enable */
DEFC( P3REN , P3REN_)
#define P4IN_ (0x001Cu) /* Port 4 Input */
READ_ONLY DEFC( P4IN , P4IN_)
#define P4OUT_ (0x001Du) /* Port 4 Output */
DEFC( P4OUT , P4OUT_)
#define P4DIR_ (0x001Eu) /* Port 4 Direction */
DEFC( P4DIR , P4DIR_)
#define P4SEL_ (0x001Fu) /* Port 4 Selection */
DEFC( P4SEL , P4SEL_)
#define P4REN_ (0x0011u) /* Port 4 Resistor Enable */
DEFC( P4REN , P4REN_)
* Timer A3
#define __MSP430_HAS_TA3__ /* Definition to show that Module is available */
#define TAIV_ (0x012Eu) /* Timer A Interrupt Vector Word */
READ_ONLY DEFW( TAIV , TAIV_)
#define TACTL_ (0x0160u) /* Timer A Control */
DEFW( TACTL , TACTL_)
#define TACCTL0_ (0x0162u) /* Timer A Capture/Compare Control 0 */
DEFW( TACCTL0 , TACCTL0_)
#define TACCTL1_ (0x0164u) /* Timer A Capture/Compare Control 1 */
DEFW( TACCTL1 , TACCTL1_)
#define TACCTL2_ (0x0166u) /* Timer A Capture/Compare Control 2 */
DEFW( TACCTL2 , TACCTL2_)
#define TAR_ (0x0170u) /* Timer A Counter Register */
DEFW( TAR , TAR_)
#define TACCR0_ (0x0172u) /* Timer A Capture/Compare 0 */
DEFW( TACCR0 , TACCR0_)
#define TACCR1_ (0x0174u) /* Timer A Capture/Compare 1 */
DEFW( TACCR1 , TACCR1_)
#define TACCR2_ (0x0176u) /* Timer A Capture/Compare 2 */
DEFW( TACCR2 , TACCR2_)
/* Alternate register names */
#define CCTL0 TACCTL0 /* Timer A Capture/Compare Control 0 */
#define CCTL1 TACCTL1 /* Timer A Capture/Compare Control 1 */
#define CCTL2 TACCTL2 /* Timer A Capture/Compare Control 2 */
#define CCR0 TACCR0 /* Timer A Capture/Compare 0 */
#define CCR1 TACCR1 /* Timer A Capture/Compare 1 */
#define CCR2 TACCR2 /* Timer A Capture/Compare 2 */
#define CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
#define CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
#define CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
#define CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
#define CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
#define CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
/* Alternate register names - 5xx style */
#define TA0IV TAIV /* Timer A Interrupt Vector Word */
#define TA0CTL TACTL /* Timer A Control */
#define TA0CCTL0 TACCTL0 /* Timer A Capture/Compare Control 0 */
#define TA0CCTL1 TACCTL1 /* Timer A Capture/Compare Control 1 */
#define TA0CCTL2 TACCTL2 /* Timer A Capture/Compare Control 2 */
#define TA0R TAR /* Timer A Counter Register */
#define TA0CCR0 TACCR0 /* Timer A Capture/Compare 0 */
#define TA0CCR1 TACCR1 /* Timer A Capture/Compare 1 */
#define TA0CCR2 TACCR2 /* Timer A Capture/Compare 2 */
#define TA0IV_ TAIV_ /* Timer A Interrupt Vector Word */
#define TA0CTL_ TACTL_ /* Timer A Control */
#define TA0CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
#define TA0CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
#define TA0CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
#define TA0R_ TAR_ /* Timer A Counter Register */
#define TA0CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
#define TA0CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
#define TA0CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
#define TIMER0_A1_VECTOR TIMERA1_VECTOR /* Int. Vector: Timer A CC1-2, TA */
#define TIMER0_A0_VECTOR TIMERA0_VECTOR /* Int. Vector: Timer A CC0 */
#define TASSEL1 (0x0200u) /* Timer A clock source select 1 */
#define TASSEL0 (0x0100u) /* Timer A clock source select 0 */
#define ID1 (0x0080u) /* Timer A clock input divider 1 */
#define ID0 (0x0040u) /* Timer A clock input divider 0 */
#define MC1 (0x0020u) /* Timer A mode control 1 */
#define MC0 (0x0010u) /* Timer A mode control 0 */
#define TACLR (0x0004u) /* Timer A counter clear */
#define TAIE (0x0002u) /* Timer A counter interrupt enable */
#define TAIFG (0x0001u) /* Timer A counter interrupt flag */
#define MC_0 (0*0x10u) /* Timer A mode control: 0 - Stop */
#define MC_1 (1*0x10u) /* Timer A mode control: 1 - Up to CCR0 */
#define MC_2 (2*0x10u) /* Timer A mode control: 2 - Continous up */
#define MC_3 (3*0x10u) /* Timer A mode control: 3 - Up/Down */
#define ID_0 (0*0x40u) /* Timer A input divider: 0 - /1 */
#define ID_1 (1*0x40u) /* Timer A input divider: 1 - /2 */
#define ID_2 (2*0x40u) /* Timer A input divider: 2 - /4 */
#define ID_3 (3*0x40u) /* Timer A input divider: 3 - /8 */
#define TASSEL_0 (0*0x100u) /* Timer A clock source select: 0 - TACLK */
#define TASSEL_1 (1*0x100u) /* Timer A clock source select: 1 - ACLK */
#define TASSEL_2 (2*0x100u) /* Timer A clock source select: 2 - SMCLK */
#define TASSEL_3 (3*0x100u) /* Timer A clock source select: 3 - INCLK */
#define CM1 (0x8000u) /* Capture mode 1 */
#define CM0 (0x4000u) /* Capture mode 0 */
#define CCIS1 (0x2000u) /* Capture input select 1 */
#define CCIS0 (0x1000u) /* Capture input select 0 */
#define SCS (0x0800u) /* Capture sychronize */
#define SCCI (0x0400u) /* Latched capture signal (read) */
#define CAP (0x0100u) /* Capture mode: 1 /Compare mode : 0 */
#define OUTMOD2 (0x0080u) /* Output mode 2 */
#define OUTMOD1 (0x0040u) /* Output mode 1 */
#define OUTMOD0 (0x0020u) /* Output mode 0 */
#define CCIE (0x0010u) /* Capture/compare interrupt enable */
#define CCI (0x0008u) /* Capture input signal (read) */
#define OUT (0x0004u) /* PWM Output signal if output mode 0 */
#define COV (0x0002u) /* Capture/compare overflow flag */
#define CCIFG (0x0001u) /* Capture/compare interrupt flag */
#define OUTMOD_0 (0*0x20u) /* PWM output mode: 0 - output only */
#define OUTMOD_1 (1*0x20u) /* PWM output mode: 1 - set */
#define OUTMOD_2 (2*0x20u) /* PWM output mode: 2 - PWM toggle/reset */
#define OUTMOD_3 (3*0x20u) /* PWM output mode: 3 - PWM set/reset */
#define OUTMOD_4 (4*0x20u) /* PWM output mode: 4 - toggle */
#define OUTMOD_5 (5*0x20u) /* PWM output mode: 5 - Reset */
#define OUTMOD_6 (6*0x20u) /* PWM output mode: 6 - PWM toggle/set */
#define OUTMOD_7 (7*0x20u) /* PWM output mode: 7 - PWM reset/set */
#define CCIS_0 (0*0x1000u) /* Capture input select: 0 - CCIxA */
#define CCIS_1 (1*0x1000u) /* Capture input select: 1 - CCIxB */
#define CCIS_2 (2*0x1000u) /* Capture input select: 2 - GND */
#define CCIS_3 (3*0x1000u) /* Capture input select: 3 - Vcc */
#define CM_0 (0*0x4000u) /* Capture mode: 0 - disabled */
#define CM_1 (1*0x4000u) /* Capture mode: 1 - pos. edge */
#define CM_2 (2*0x4000u) /* Capture mode: 1 - neg. edge */
#define CM_3 (3*0x4000u) /* Capture mode: 1 - both edges */
/* TA3IV Definitions */
#define TAIV_NONE (0x0000u) /* No Interrupt pending */
#define TAIV_TACCR1 (0x0002u) /* TACCR1_CCIFG */
#define TAIV_TACCR2 (0x0004u) /* TACCR2_CCIFG */
#define TAIV_6 (0x0006u) /* Reserved */
#define TAIV_8 (0x0008u) /* Reserved */
#define TAIV_TAIFG (0x000Au) /* TAIFG */
* Timer B3
#define __MSP430_HAS_TB3__ /* Definition to show that Module is available */
#define TBIV_ (0x011Eu) /* Timer B Interrupt Vector Word */
READ_ONLY DEFW( TBIV , TBIV_)
#define TBCTL_ (0x0180u) /* Timer B Control */
DEFW( TBCTL , TBCTL_)
#define TBCCTL0_ (0x0182u) /* Timer B Capture/Compare Control 0 */
DEFW( TBCCTL0 , TBCCTL0_)
#define TBCCTL1_ (0x0184u) /* Timer B Capture/Compare Control 1 */
DEFW( TBCCTL1 , TBCCTL1_)
#define TBCCTL2_ (0x0186u) /* Timer B Capture/Compare Control 2 */
DEFW( TBCCTL2 , TBCCTL2_)
#define TBR_ (0x0190u) /* Timer B Counter Register */
DEFW( TBR , TBR_)
#define TBCCR0_ (0x0192u) /* Timer B Capture/Compare 0 */
DEFW( TBCCR0 , TBCCR0_)
#define TBCCR1_ (0x0194u) /* Timer B Capture/Compare 1 */
DEFW( TBCCR1 , TBCCR1_)
#define TBCCR2_ (0x0196u) /* Timer B Capture/Compare 2 */
DEFW( TBCCR2 , TBCCR2_)
#define TB0IV TBIV /* Timer B Interrupt Vector Word */
#define TB0CTL TBCTL /* Timer B Control */
#define TB0CCTL0 TBCCTL0 /* Timer B Capture/Compare Control 0 */
#define TB0CCTL1 TBCCTL1 /* Timer B Capture/Compare Control 1 */
#define TB0CCTL2 TBCCTL2 /* Timer B Capture/Compare Control 2 */
#define TB0R TBR /* Timer B Counter Register */
#define TB0CCR0 TBCCR0 /* Timer B Capture/Compare 0 */
#define TB0CCR1 TBCCR1 /* Timer B Capture/Compare 1 */
#define TB0CCR2 TBCCR2 /* Timer B Capture/Compare 2 */
#define TB0IV_ TBIV_ /* Timer B Interrupt Vector Word */
#define TB0CTL_ TBCTL_ /* Timer B Control */
#define TB0CCTL0_ TBCCTL0_ /* Timer B Capture/Compare Control 0 */
#define TB0CCTL1_ TBCCTL1_ /* Timer B Capture/Compare Control 1 */
#define TB0CCTL2_ TBCCTL2_ /* Timer B Capture/Compare Control 2 */
#define TB0R_ TBR_ /* Timer B Counter Register */
#define TB0CCR0_ TBCCR0_ /* Timer B Capture/Compare 0 */
#define TB0CCR1_ TBCCR1_ /* Timer B Capture/Compare 1 */
#define TB0CCR2_ TBCCR2_ /* Timer B Capture/Compare 2 */
#define TBCLGRP1 (0x4000u) /* Timer B Compare latch load group 1 */
#define TBCLGRP0 (0x2000u) /* Timer B Compare latch load group 0 */
#define CNTL1 (0x1000u) /* Counter lenght 1 */
#define CNTL0 (0x0800u) /* Counter lenght 0 */
#define TBSSEL1 (0x0200u) /* Clock source 1 */
#define TBSSEL0 (0x0100u) /* Clock source 0 */
#define TBCLR (0x0004u) /* Timer B counter clear */
#define TBIE (0x0002u) /* Timer B interrupt enable */
#define TBIFG (0x0001u) /* Timer B interrupt flag */
#define SHR1 (0x4000u) /* Timer B Compare latch load group 1 */
#define SHR0 (0x2000u) /* Timer B Compare latch load group 0 */
#define TBSSEL_0 (0*0x0100u) /* Clock Source: TBCLK */
#define TBSSEL_1 (1*0x0100u) /* Clock Source: ACLK */
#define TBSSEL_2 (2*0x0100u) /* Clock Source: SMCLK */
#define TBSSEL_3 (3*0x0100u) /* Clock Source: INCLK */
#define CNTL_0 (0*0x0800u) /* Counter lenght: 16 bit */
#define CNTL_1 (1*0x0800u) /* Counter lenght: 12 bit */
#define CNTL_2 (2*0x0800u) /* Counter lenght: 10 bit */
#define CNTL_3 (3*0x0800u) /* Counter lenght: 8 bit */
#define SHR_0 (0*0x2000u) /* Timer B Group: 0 - individually */
#define SHR_1 (1*0x2000u) /* Timer B Group: 1 - 3 groups (1-2, 3-4, 5-6) */
#define SHR_2 (2*0x2000u) /* Timer B Group: 2 - 2 groups (1-3, 4-6)*/
#define SHR_3 (3*0x2000u) /* Timer B Group: 3 - 1 group (all) */
#define TBCLGRP_0 (0*0x2000u) /* Timer B Group: 0 - individually */
#define TBCLGRP_1 (1*0x2000u) /* Timer B Group: 1 - 3 groups (1-2, 3-4, 5-6) */
#define TBCLGRP_2 (2*0x2000u) /* Timer B Group: 2 - 2 groups (1-3, 4-6)*/
#define TBCLGRP_3 (3*0x2000u) /* Timer B Group: 3 - 1 group (all) */
/* Additional Timer B Control Register bits are defined in Timer A */
#define CLLD1 (0x0400u) /* Compare latch load source 1 */
#define CLLD0 (0x0200u) /* Compare latch load source 0 */
#define SLSHR1 (0x0400u) /* Compare latch load source 1 */
#define SLSHR0 (0x0200u) /* Compare latch load source 0 */
#define SLSHR_0 (0*0x0200u) /* Compare latch load sourec : 0 - immediate */
#define SLSHR_1 (1*0x0200u) /* Compare latch load sourec : 1 - TBR counts to 0 */
#define SLSHR_2 (2*0x0200u) /* Compare latch load sourec : 2 - up/down */
#define SLSHR_3 (3*0x0200u) /* Compare latch load sourec : 3 - TBR counts to TBCTL0 */
#define CLLD_0 (0*0x0200u) /* Compare latch load sourec : 0 - immediate */
#define CLLD_1 (1*0x0200u) /* Compare latch load sourec : 1 - TBR counts to 0 */
#define CLLD_2 (2*0x0200u) /* Compare latch load sourec : 2 - up/down */
#define CLLD_3 (3*0x0200u) /* Compare latch load sourec : 3 - TBR counts to TBCTL0 */
/* TB3IV Definitions */
#define TBIV_NONE (0x0000u) /* No Interrupt pending */
#define TBIV_TBCCR1 (0x0002u) /* TBCCR1_CCIFG */
#define TBIV_TBCCR2 (0x0004u) /* TBCCR2_CCIFG */
#define TBIV_3 (0x0006u) /* Reserved */
#define TBIV_4 (0x0008u) /* Reserved */
#define TBIV_5 (0x000Au) /* Reserved */
#define TBIV_6 (0x000Cu) /* Reserved */
#define TBIV_TBIFG (0x000Eu) /* TBIFG */
* USCI
#define __MSP430_HAS_USCI__ /* Definition to show that Module is available */
#define UCA0CTL0_ (0x0060u) /* USCI A0 Control Register 0 */
DEFC( UCA0CTL0 , UCA0CTL0_)
#define UCA0CTL1_ (0x0061u) /* USCI A0 Control Register 1 */
DEFC( UCA0CTL1 , UCA0CTL1_)
#define UCA0BR0_ (0x0062u) /* USCI A0 Baud Rate 0 */
DEFC( UCA0BR0 , UCA0BR0_)
#define UCA0BR1_ (0x0063u) /* USCI A0 Baud Rate 1 */
DEFC( UCA0BR1 , UCA0BR1_)
#define UCA0MCTL_ (0x0064u) /* USCI A0 Modulation Control */
DEFC( UCA0MCTL , UCA0MCTL_)
#define UCA0STAT_ (0x0065u) /* USCI A0 Status Register */
DEFC( UCA0STAT , UCA0STAT_)
#define UCA0RXBUF_ (0x0066u) /* USCI A0 Receive Buffer */
READ_ONLY DEFC( UCA0RXBUF , UCA0RXBUF_)
#define UCA0TXBUF_ (0x0067u) /* USCI A0 Transmit Buffer */
DEFC( UCA0TXBUF , UCA0TXBUF_)
#define UCA0ABCTL_ (0x005Du) /* USCI A0 LIN Control */
DEFC( UCA0ABCTL , UCA0ABCTL_)
#define UCA0IRTCTL_ (0x005Eu) /* USCI A0 IrDA Transmit Control */
DEFC( UCA0IRTCTL , UCA0IRTCTL_)
#define UCA0IRRCTL_ (0x005Fu) /* USCI A0 IrDA Receive Control */
DEFC( UCA0IRRCTL , UCA0IRRCTL_)
#define UCB0CTL0_ (0x0068u) /* USCI B0 Control Register 0 */
DEFC( UCB0CTL0 , UCB0CTL0_)
#define UCB0CTL1_ (0x0069u) /* USCI B0 Control Register 1 */
DEFC( UCB0CTL1 , UCB0CTL1_)
#define UCB0BR0_ (0x006Au) /* USCI B0 Baud Rate 0 */
DEFC( UCB0BR0 , UCB0BR0_)
#define UCB0BR1_ (0x006Bu) /* USCI B0 Baud Rate 1 */
DEFC( UCB0BR1 , UCB0BR1_)
#define UCB0I2CIE_ (0x006Cu) /* USCI B0 I2C Interrupt Enable Register */
DEFC( UCB0I2CIE , UCB0I2CIE_)
#define UCB0STAT_ (0x006Du) /* USCI B0 Status Register */
DEFC( UCB0STAT , UCB0STAT_)
#define UCB0RXBUF_ (0x006Eu) /* USCI B0 Receive Buffer */
READ_ONLY DEFC( UCB0RXBUF , UCB0RXBUF_)
#define UCB0TXBUF_ (0x006Fu) /* USCI B0 Transmit Buffer */
DEFC( UCB0TXBUF , UCB0TXBUF_)
#define UCB0I2COA_ (0x0118u) /* USCI B0 I2C Own Address */
DEFW( UCB0I2COA , UCB0I2COA_)
#define UCB0I2CSA_ (0x011Au) /* USCI B0 I2C Slave Address */
DEFW( UCB0I2CSA , UCB0I2CSA_)
// UART-Mode Bits
#define UCPEN (0x80) /* Async. Mode: Parity enable */
#define UCPAR (0x40) /* Async. Mode: Parity 0:odd / 1:even */
#define UCMSB (0x20) /* Async. Mode: MSB first 0:LSB / 1:MSB */
#define UC7BIT (0x10) /* Async. Mode: Data Bits 0:8-bits / 1:7-bits */
#define UCSPB (0x08) /* Async. Mode: Stop Bits 0:one / 1: two */
#define UCMODE1 (0x04) /* Async. Mode: USCI Mode 1 */
#define UCMODE0 (0x02) /* Async. Mode: USCI Mode 0 */
#define UCSYNC (0x01) /* Sync-Mode 0:UART-Mode / 1:SPI-Mode */
// SPI-Mode Bits
#define UCCKPH (0x80) /* Sync. Mode: Clock Phase */
#define UCCKPL (0x40) /* Sync. Mode: Clock Polarity */
#define UCMST (0x08) /* Sync. Mode: Master Select */
// I2C-Mode Bits
#define UCA10 (0x80) /* 10-bit Address Mode */
#define UCSLA10 (0x40) /* 10-bit Slave Address Mode */
#define UCMM (0x20) /* Multi-Master Environment */
//#define res (0x10) /* reserved */
#define UCMODE_0 (0x00) /* Sync. Mode: USCI Mode: 0 */
#define UCMODE_1 (0x02) /* Sync. Mode: USCI Mode: 1 */
#define UCMODE_2 (0x04) /* Sync. Mode: USCI Mode: 2 */
#define UCMODE_3 (0x06) /* Sync. Mode: USCI Mode: 3 */
// UART-Mode Bits
#define UCSSEL1 (0x80) /* USCI 0 Clock Source Select 1 */
#define UCSSEL0 (0x40) /* USCI 0 Clock Source Select 0 */
#define UCRXEIE (0x20) /* RX Error interrupt enable */
#define UCBRKIE (0x10) /* Break interrupt enable */
#define UCDORM (0x08) /* Dormant (Sleep) Mode */
#define UCTXADDR (0x04) /* Send next Data as Address */
#define UCTXBRK (0x02) /* Send next Data as Break */
#define UCSWRST (0x01) /* USCI Software Reset */
// SPI-Mode Bits
//#define res (0x20) /* reserved */
//#define res (0x08) /* reserved */
//#define res (0x04) /* reserved */
//#define res (0x02) /* reserved */
// I2C-Mode Bits
#define UCTR (0x10) /* Transmit/Receive Select/Flag */
#define UCTXNACK (0x08) /* Transmit NACK */
#define UCTXSTP (0x04) /* Transmit STOP */
#define UCTXSTT (0x02) /* Transmit START */
#define UCSSEL_0 (0x00) /* USCI 0 Clock Source: 0 */
#define UCSSEL_1 (0x40) /* USCI 0 Clock Source: 1 */
#define UCSSEL_2 (0x80) /* USCI 0 Clock Source: 2 */
#define UCSSEL_3 (0xC0) /* USCI 0 Clock Source: 3 */
#define UCBRF3 (0x80) /* USCI First Stage Modulation Select 3 */
#define UCBRF2 (0x40) /* USCI First Stage Modulation Select 2 */
#define UCBRF1 (0x20) /* USCI First Stage Modulation Select 1 */
#define UCBRF0 (0x10) /* USCI First Stage Modulation Select 0 */
#define UCBRS2 (0x08) /* USCI Second Stage Modulation Select 2 */
#define UCBRS1 (0x04) /* USCI Second Stage Modulation Select 1 */
#define UCBRS0 (0x02) /* USCI Second Stage Modulation Select 0 */
#define UCOS16 (0x01) /* USCI 16-times Oversampling enable */
#define UCBRF_0 (0x00) /* USCI First Stage Modulation: 0 */
#define UCBRF_1 (0x10) /* USCI First Stage Modulation: 1 */
#define UCBRF_2 (0x20) /* USCI First Stage Modulation: 2 */
#define UCBRF_3 (0x30) /* USCI First Stage Modulation: 3 */
#define UCBRF_4 (0x40) /* USCI First Stage Modulation: 4 */
#define UCBRF_5 (0x50) /* USCI First Stage Modulation: 5 */
#define UCBRF_6 (0x60) /* USCI First Stage Modulation: 6 */
#define UCBRF_7 (0x70) /* USCI First Stage Modulation: 7 */
#define UCBRF_8 (0x80) /* USCI First Stage Modulation: 8 */
#define UCBRF_9 (0x90) /* USCI First Stage Modulation: 9 */
#define UCBRF_10 (0xA0) /* USCI First Stage Modulation: A */
#define UCBRF_11 (0xB0) /* USCI First Stage Modulation: B */
#define UCBRF_12 (0xC0) /* USCI First Stage Modulation: C */
#define UCBRF_13 (0xD0) /* USCI First Stage Modulation: D */
#define UCBRF_14 (0xE0) /* USCI First Stage Modulation: E */
#define UCBRF_15 (0xF0) /* USCI First Stage Modulation: F */
#define UCBRS_0 (0x00) /* USCI Second Stage Modulation: 0 */
#define UCBRS_1 (0x02) /* USCI Second Stage Modulation: 1 */
#define UCBRS_2 (0x04) /* USCI Second Stage Modulation: 2 */
#define UCBRS_3 (0x06) /* USCI Second Stage Modulation: 3 */
#define UCBRS_4 (0x08) /* USCI Second Stage Modulation: 4 */
#define UCBRS_5 (0x0A) /* USCI Second Stage Modulation: 5 */
#define UCBRS_6 (0x0C) /* USCI Second Stage Modulation: 6 */
#define UCBRS_7 (0x0E) /* USCI Second Stage Modulation: 7 */
#define UCLISTEN (0x80) /* USCI Listen mode */
#define UCFE (0x40) /* USCI Frame Error Flag */
#define UCOE (0x20) /* USCI Overrun Error Flag */
#define UCPE (0x10) /* USCI Parity Error Flag */
#define UCBRK (0x08) /* USCI Break received */
#define UCRXERR (0x04) /* USCI RX Error Flag */
#define UCADDR (0x02) /* USCI Address received Flag */
#define UCBUSY (0x01) /* USCI Busy Flag */
#define UCIDLE (0x02) /* USCI Idle line detected Flag */
//#define res (0x80) /* reserved */
//#define res (0x40) /* reserved */
#define UCNACKIE (0x08) /* NACK Condition interrupt enable */
#define UCSTPIE (0x04) /* STOP Condition interrupt enable */
#define UCSTTIE (0x02) /* START Condition interrupt enable */
#define UCALIE (0x01) /* Arbitration Lost interrupt enable */
#define UCSCLLOW (0x40) /* SCL low */
#define UCGC (0x20) /* General Call address received Flag */
#define UCBBUSY (0x10) /* Bus Busy Flag */
#define UCNACKIFG (0x08) /* NAK Condition interrupt Flag */
#define UCSTPIFG (0x04) /* STOP Condition interrupt Flag */
#define UCSTTIFG (0x02) /* START Condition interrupt Flag */
#define UCALIFG (0x01) /* Arbitration Lost interrupt Flag */
#define UCIRTXPL5 (0x80) /* IRDA Transmit Pulse Length 5 */
#define UCIRTXPL4 (0x40) /* IRDA Transmit Pulse Length 4 */
#define UCIRTXPL3 (0x20) /* IRDA Transmit Pulse Length 3 */
#define UCIRTXPL2 (0x10) /* IRDA Transmit Pulse Length 2 */
#define UCIRTXPL1 (0x08) /* IRDA Transmit Pulse Length 1 */
#define UCIRTXPL0 (0x04) /* IRDA Transmit Pulse Length 0 */
#define UCIRTXCLK (0x02) /* IRDA Transmit Pulse Clock Select */
#define UCIREN (0x01) /* IRDA Encoder/Decoder enable */
#define UCIRRXFL5 (0x80) /* IRDA Receive Filter Length 5 */
#define UCIRRXFL4 (0x40) /* IRDA Receive Filter Length 4 */
#define UCIRRXFL3 (0x20) /* IRDA Receive Filter Length 3 */
#define UCIRRXFL2 (0x10) /* IRDA Receive Filter Length 2 */
#define UCIRRXFL1 (0x08) /* IRDA Receive Filter Length 1 */
#define UCIRRXFL0 (0x04) /* IRDA Receive Filter Length 0 */
#define UCIRRXPL (0x02) /* IRDA Receive Input Polarity */
#define UCIRRXFE (0x01) /* IRDA Receive Filter enable */
#define UCDELIM1 (0x20) /* Break Sync Delimiter 1 */
#define UCDELIM0 (0x10) /* Break Sync Delimiter 0 */
#define UCSTOE (0x08) /* Sync-Field Timeout error */
#define UCBTOE (0x04) /* Break Timeout error */
#define UCABDEN (0x01) /* Auto Baud Rate detect enable */
#define UCGCEN (0x8000u) /* I2C General Call enable */
#define UCOA9 (0x0200u) /* I2C Own Address 9 */
#define UCOA8 (0x0100u) /* I2C Own Address 8 */
#define UCOA7 (0x0080u) /* I2C Own Address 7 */
#define UCOA6 (0x0040u) /* I2C Own Address 6 */
#define UCOA5 (0x0020u) /* I2C Own Address 5 */
#define UCOA4 (0x0010u) /* I2C Own Address 4 */
#define UCOA3 (0x0008u) /* I2C Own Address 3 */
#define UCOA2 (0x0004u) /* I2C Own Address 2 */
#define UCOA1 (0x0002u) /* I2C Own Address 1 */
#define UCOA0 (0x0001u) /* I2C Own Address 0 */
#define UCSA9 (0x0200u) /* I2C Slave Address 9 */
#define UCSA8 (0x0100u) /* I2C Slave Address 8 */
#define UCSA7 (0x0080u) /* I2C Slave Address 7 */
#define UCSA6 (0x0040u) /* I2C Slave Address 6 */
#define UCSA5 (0x0020u) /* I2C Slave Address 5 */
#define UCSA4 (0x0010u) /* I2C Slave Address 4 */
#define UCSA3 (0x0008u) /* I2C Slave Address 3 */
#define UCSA2 (0x0004u) /* I2C Slave Address 2 */
#define UCSA1 (0x0002u) /* I2C Slave Address 1 */
#define UCSA0 (0x0001u) /* I2C Slave Address 0 */
* WATCHDOG TIMER
#define __MSP430_HAS_WDT__ /* Definition to show that Module is available */
#define WDTCTL_ (0x0120u) /* Watchdog Timer Control */
DEFW( WDTCTL , WDTCTL_)
/* The bit names have been prefixed with "WDT" */
#define WDTIS0 (0x0001u)
#define WDTIS1 (0x0002u)
#define WDTSSEL (0x0004u)
#define WDTCNTCL (0x0008u)
#define WDTTMSEL (0x0010u)
#define WDTNMI (0x0020u)
#define WDTNMIES (0x0040u)
#define WDTHOLD (0x0080u)
#define WDTPW (0x5A00u)
/* WDT-interval times [1ms] coded with Bits 0-2 */
/* WDT is clocked by fSMCLK (assumed 1MHz) */
#define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL) /* 32ms interval (default) */
#define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0) /* 8ms " */
#define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1) /* 0.5ms " */
#define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
/* WDT is clocked by fACLK (assumed 32KHz) */
#define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL) /* 1000ms " */
#define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
#define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
#define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
/* Watchdog mode -> reset after expired time */
#define WDT_MRST_32 (WDTPW+WDTCNTCL) /* 32ms interval (default) */
#define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS0) /* 8ms " */
#define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS1) /* 0.5ms " */
#define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
#define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL) /* 1000ms " */
#define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
#define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
#define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
/* INTERRUPT CONTROL */
/* These two bits are defined in the Special Function Registers */
/* #define WDTIE 0x01 */
/* #define WDTIFG 0x01 */
* Calibration Data in Info Mem
#ifndef __DisableCalData
#define CALDCO_16MHZ_ (0x10F8u) /* DCOCTL Calibration Data for 16MHz */
READ_ONLY DEFC( CALDCO_16MHZ , CALDCO_16MHZ_)
#define CALBC1_16MHZ_ (0x10F9u) /* BCSCTL1 Calibration Data for 16MHz */
READ_ONLY DEFC( CALBC1_16MHZ , CALBC1_16MHZ_)
#define CALDCO_12MHZ_ (0x10FAu) /* DCOCTL Calibration Data for 12MHz */
READ_ONLY DEFC( CALDCO_12MHZ , CALDCO_12MHZ_)
#define CALBC1_12MHZ_ (0x10FBu) /* BCSCTL1 Calibration Data for 12MHz */
READ_ONLY DEFC( CALBC1_12MHZ , CALBC1_12MHZ_)
#define CALDCO_8MHZ_ (0x10FCu) /* DCOCTL Calibration Data for 8MHz */
READ_ONLY DEFC( CALDCO_8MHZ , CALDCO_8MHZ_)
#define CALBC1_8MHZ_ (0x10FDu) /* BCSCTL1 Calibration Data for 8MHz */
READ_ONLY DEFC( CALBC1_8MHZ , CALBC1_8MHZ_)
#define CALDCO_1MHZ_ (0x10FEu) /* DCOCTL Calibration Data for 1MHz */
READ_ONLY DEFC( CALDCO_1MHZ , CALDCO_1MHZ_)
#define CALBC1_1MHZ_ (0x10FFu) /* BCSCTL1 Calibration Data for 1MHz */
READ_ONLY DEFC( CALBC1_1MHZ , CALBC1_1MHZ_)
#endif /* #ifndef __DisableCalData */
* Interrupt Vectors (offset from 0xFFE0)
#define PORT1_VECTOR (2 * 2u) /* 0xFFE4 Port 1 */
#define PORT2_VECTOR (3 * 2u) /* 0xFFE6 Port 2 */
#define ADC10_VECTOR (5 * 2u) /* 0xFFEA ADC10 */
#define USCIAB0TX_VECTOR (6 * 2u) /* 0xFFEC USCI A0/B0 Transmit */
#define USCIAB0RX_VECTOR (7 * 2u) /* 0xFFEE USCI A0/B0 Receive */
#define TIMERA1_VECTOR (8 * 2u) /* 0xFFF0 Timer A CC1-2, TA */
#define TIMERA0_VECTOR (9 * 2u) /* 0xFFF2 Timer A CC0 */
#define WDT_VECTOR (10 * 2u) /* 0xFFF4 Watchdog Timer */
#define TIMERB1_VECTOR (12 * 2u) /* 0xFFF8 Timer B CC1-2, TB */
#define TIMERB0_VECTOR (13 * 2u) /* 0xFFFA Timer B CC0 */
#define NMI_VECTOR (14 * 2u) /* 0xFFFC Non-maskable */
#define RESET_VECTOR (15 * 2u) /* 0xFFFE Reset [Highest Priority] */
* End of Modules
#pragma language=default
#endif /* #ifndef __msp430x22x4 */
lqsgg
2018-11-29 13:49
謝謝分享!學習學習!
