<<黃神姬東國>>音樂程序51單片機編程代碼
das
2015-4-16 03:00
; <<黃神姬東國>>音樂程序編程代碼清單姬學瑞
; 姬家寨電子科技實驗室制作,版權所有,侵權必究
ORG 0000H
LJMP START
ORG 000BH ;中斷入口
INC 20H ;中斷服務程序,中斷計數器加1
MOV TH0,#0D8H
MOV TL0,#0EFH ;12M晶振,形成10毫秒中斷
RETI
START:
MOV SP,#50H
MOV TH0,#0D8H
MOV TL0,#0EFH
MOV TMOD,#01H
MOV IE,#82H
MUSIC0:
NOP
MOV DPTR,#DAT ;表頭地址送DPTR
MOV 20H,#00H ;中斷計數器清0
MOV B,#00H ;表序號清0
MUSIC1:
NOP
CLR A
MOVC A,@A+DPTR ;查表取代碼
JZ END0 ;是00H,則結束
CJNE A,#0FFH,MUSIC5
LJMP MUSIC3
MUSIC5:
NOP
MOV R6,A
INC DPTR
MOV A,B
MOVC A,@A+DPTR ;取節拍代碼送R7
MOV R7,A
SETB TR0 ;啟動計數
MUSIC2:
NOP
CPL P3.7
MOV A,R6
MOV R3,A
CPL A
MOV P1,A ;顯示(修改者加入的顯示)
CPL A
LCALL DEL
MOV A,R7
CJNE A,20H,MUSIC2 ;中斷計數器(20H)=R7否?
;不等,則繼續循環
MOV 20H,#00H ;等于,則取下一代碼
INC DPTR
LJMP MUSIC1
MUSIC3:
NOP
CLR TR0 ;休止100毫秒
MOV R2,#0DH
MUSIC4:
NOP
MOV R3,#0FFH
LCALL DEL
DJNZ R2,MUSIC4
INC DPTR
LJMP MUSIC1
END0:
NOP
MOV R2,#64H ;歌曲結束,延時1秒后繼續
MUSIC6:
MOV R3,#00H
LCALL DEL
DJNZ R2,MUSIC6
LJMP MUSIC0
DEL:
NOP
DEL3:
MOV R4,#05H
DEL4:
NOP
DJNZ R4,DEL4
NOP
DJNZ R3,DEL3
RET
DAT:
DB 30H,40H,30H,40H,30H,40H,26H,40H,2BH,40H,2BH,40H,2BH,40H,30H,40H ;11132221《壹黃帝頌》
DB 39H,40H,39H,40H,39H,40H,30H,40H,2BH,90H ;66612
DB 30H,60H,2BH,20H,26H,20H,20H,20H,30H,20H,26H,20H,2BH,30H,30H,20H ;12351321
DB 39H,80H,2BH,30H,26H,20H,20H,20H,1CH,20H,20H,20H,30H,20H,2BH,90H ;62356512
DB 30H,30H,2BH,20H,26H,20H,20H,20H,30H,20H,26H,20H,2BH,60H,30H,20H ;12351321
DB 39H,80H,2BH,30H,26H,20H,2BH,20H,30H,20H,39H,20H,30H,20H,40H,90H ;62321615
DB 39H,80H,2BH,30H,30H,20H,40H,40H,39H,20H,30H,20H,30H,90H ;6215611
DB 39H,80H,2BH,30H,26H,20H,2BH,20H,30H,20H,39H,20H,30H,20H,30H,90H ;62321611
DB 20H,30H,1CH,20H,26H,40H,20H,40H,1CH,30H,18H,20H,1CH,80H,20H,20H ;56356165
DB 20H,20H,1CH,20H,20H,20H,30H,40H,26H,20H,20H,20H,2BH,90H,26H,30H ;56513523
DB 26H,20H,2BH,40H,26H,20H,20H,20H,2BH,30H,30H,20H,39H,80H,2BH,20H ;32352162
DB 2BH,20H,2BH,20H,26H,20H,20H,30H,1CH,20H,20H,90H ;223565
DB 2BH,20H,2BH,20H,26H,20H,20H,30H,1CH,20H,20H,90H,0FFH ;223565
DB 39H,80H,2BH,40H,30H,20H,40H,40H,39H,20H,30H,20H,30H,90H ;6215611
DB 26H,20H,2BH,40H,26H,20H,20H,20H,2BH,30H,30H,20H,39H,80H ;3235216
DB 2BH,20H,2BH,20H,2BH,20H,30H,20H,40H,40H,39H,20H,30H,20H,30H,90H ;22215611
DB 2BH,20H,2BH,20H,2BH,20H,30H,20H,40H,80H,39H,90H,30H,40H,30H,90H ;22215611
DB 30H,90H,30H,40H,0FFH ;11
DB 20H,20H,30H,20H,1CH,20H,18H,10H,1CH,10H,20H,40H,0FFH, 26H,10H ;51616503第一段《貳神的傳說》
DB 2BH,10H,30H,20H,1CH,40H,20H,20H,20H,80H,20H,20H,30H,20H,1CH,20H ;21655516
DB 18H,10H,1CH,10H,20H,40H,0FFH, 26H,10H,2BH,10H,30H,20H,2BH,40H ;16503212
DB 26H,20H,2BH,80H,2BH,30H,30H,10H,39H,40H,30H,20H,30H,40H,0FFH ;32216110
DB 30H,10H,2BH,10H,26H,20H,20H,40H,1CH,20H,26H,80H,2BH,30H,30H,10H ;12356321
DB 39H,20H,30H,20H,30H,40H,0FFH, 30H,10H,2BH,10H,26H,20H,18H,20H ;61101231
DB 19H,20H,1CH,10H,20H,10H,20H,80H,18H,20H,15H,40H,18H,40H,1CH,20H ;76551216
DB 18H,40H,1CH,20H,18H,40H,1CH,40H,20H,20H,1CH,40H,26H,20H,20H,40H ;16165635
DB 1CH,10H,2BH,40H,0FFH, 26H,40H,39H,20H,30H,40H,30H,20H,30H,10H ;62036111
DB 0FFH ;0
DB 20H,20H,30H,20H,1CH,20H,18H,10H,1CH,10H,20H,40H,0FFH, 26H,10H ;15616503第二段
DB 39H,20H,30H,20H,30H,40H, 0FFH, 30H,10H,2BH,10H,26H,20H,18H,20H ;61101231
DB 0FFH,30H,90H ;01
DB 20H,20H,15H,30H,18H,20H,15H,40H,13H,80H,18H,40H,15H,90H,15H,90H ;52123122第三段
DB 20H,80H,15H,60H,18H,20H,1CH,40H,18H,80H,20H,40H,1CH,90H,1CH,90H ;52161566
DB 1CH,30H,20H,20H,26H,40H,20H,40H,20H,90H,20H,30H,26H,20H,2BH,40H ;65355532
DB 26H,40H,26H,90H,0FFH, 26H,40H,20H,40H,1CH,40H,2BH,90H,26H,40H ;33035623
DB 30H,40H,2BH,40H,2BH,80H,26H,40H,2BH,20H,30H,20H,39H,40H,30H,40H ;12232161
DB 30H,90H,30H,90H ;11
DB 20H,20H,15H,30H,18H,20H,15H,40H,13H,80H,18H,40H,15H,90H,15H,90H ;55123122
DB 30H,40H,2BH,40H,2BH,80H,26H,40H,15H,20H,18H,20H,1CH,40H,18H,40H ;12232161
DB 18H,90H,18H,90H,18H,90H,0FFH ;111
DB 10H,30H,12H,10H,13H,10H,15H,10H,13H,10H,10H,10H,0EH,80H,15H,30H ;54323562《叁姬姓之歌》
DB 10H,30H,13H,10H,15H,10H,15H,10H,19H,10H,1CH,80H,20H,10H,26H,10H ;53227653
DB 20H,10H,1CH,10H,18H,10H,0FFH,19H,10H,1CH,10H,0FFH,1CH,10H ;56107606
DB 18H,10H,20H,10H,24H,10H,26H,20H,2BH,10H,26H,10H,20H,10H,18H,10H ;15432351
DB 1CH,10H,20H,10H,26H,10H,2BH,10H,30H,30H,2BH,10H,26H,20H,20H,20H ;65321235
DB 1CH,20H,19H,10H,1CH,10H,20H,20H,26H,20H,26H,80H,18H,10H,1CH,10H ;67653316
DB 18H,10H,2BH,10H,26H,90H,15H,20H,18H,10H,1CH,10H,18H,20H,15H,20H ;12131612
DB 15H,80H,1CH,10H,26H,10H,15H,10H,18H,10H,1CH,10H,18H,10H,1CH,60H ;26321616
DB 1CH,40H,19H,20H,1CH,10H,26H,10H,20H,10H,1CH,10H,19H,60H,19H,40H ;67635677
DB 18H,10H,1CH,10H,13H,10H,18H,10H,15H,90H,13H,20H,15H,10H,18H,10H ;16312321
DB 15H,10H,13H,10H,10H,60H,10H,40H,20H,10H,26H,10H,15H,10H,18H,10H ;23555321
DB 1CH,10H,18H,10H,1CH,60H,0EH,30H,0EH,10H,0EH,10H,10H,10H,13H,10H ;61666653
DB 0EH,10H,13H,10H,15H,10H,18H,10H,1CH,10H,13H,10H,18H,10H,15H,40H ;53216311
DB 26H,30H,20H,10H,1CH,10H,18H,10H,15H,10H,18H,10H,18H,10H,1CH,10H ;35612313
DB 1CH,40H,26H,10H,20H,10H,1CH,10H,19H,10H,18H,30H,18H,10H,18H,10H ;63567111
DB 1CH,10H,18H,20H,15H,10H,10H,10H,13H,80H,15H,30H,15H,10H,15H,10H ;61253222
DB 0EH,10H,13H,10H,15H,10H,18H,10H,1CH,10H,15H,80H,19H,10H,0FFH ;53216270
DB 19H,10H,1CH,10H,19H,10H,15H,40H,19H,10H,19H,10H,1CH,10H,26H,10H ;76727763
DB 20H,40H,18H,10H,18H,20H,1CH,10H,20H,10H,1CH,10H,18H,20H,15H,10H ;51165612
DB 15H,10H,1CH,10H,18H,10H,13H,10H,15H,40H,10H,30H,12H,10H,13H,10H ;26132543
DB 15H,10H,13H,10H,10H,10H,0EH,80H,15H,60H,10H,10H,13H,10H,15H,10H ;23562532
DB 15H,10H,19H,10H,1CH,80H,20H,10H,26H,10H,20H,10H,1CH,10H,18H,60H ;27653561
DB 19H,10H,1CH,60H,18H,10H,20H,10H,24H,10H,26H,20H,1CH,10H,18H,10H ;76154361
DB 15H,10H,13H,10H,10H,10H,12H,10H,13H,10H,15H,10H,13H,80H,10H,30H ;23543235
DB 12H,10H,13H,10H,1CH,10H,18H,10H,13H,10H,15H,80H,19H,20H,13H,20H ;43613273
DB 15H,10H,13H,20H,20H,20H,1CH,80H,20H,10H,26H,10H,20H,10H,1CH,10H ;23565356
DB 18H,30H,19H,10H,1CH,30H,18H,10H,20H,10H,24H,10H,26H,20H,2BH,10H ;17615432
DB 26H,10H,20H,10H,18H,10H,1CH,10H,20H,10H,26H,10H,2BH,10H,30H,80H ;35165321
DB 10H,30H,12H,10H,13H,10H,15H,10H,10H,10H,0EH,80H,13H,20H,1CH,20H ;54323636
DB 18H,10H,15H,10H,24H,10H,13H,10H,15H,80H,19H,60H,19H,10H,1CH,10H ;12432776
DB 26H,10H,20H,10H,1CH,10H,19H,80H,26H,20H,15H,20H,19H,20H,1CH,10H ;35673276
DB 26H,10H,20H,80H,18H,10H,18H,20H,1CH,10H,20H,10H,1CH,10H,18H,20H ;35116561
DB 1CH,10H,12H,10H,13H,10H,15H,10H,13H,40H,13H,10H,15H,20H,18H,10H ;64323321
DB 15H,10H,13H,10H,0EH,20H,13H,20H,15H,10H,1CH,10H,18H,40H,18H,10H ;23532611
DB 1CH,20H,20H,10H,18H,10H,15H,10H,13H,20H,10H,30H,12H,10H,13H,10H ;65123543
DB 15H,10H,13H,10H,10H,10H,0EH,80H,13H,20H,15H,40H,18H,20H,15H,20H ;23563212
DB 13H,20H,12H,20H,0EH,20H,10H,40H,0FFH,1CH,20H,18H,20H,15H,20H ;34650612
DB 13H,20H,0EH,80H,0EH,40H,0EH,20H,10H,20H,18H,80H,18H,80H,18H,80H ;36665111
DB 18H,80H,18H,80H,0FFH,18H,80H,0FFH ;1101
DB 20H,40H,20H,20H,1CH,20H,2BH,80H,30H,40H,30H,20H,39H,20H,2BH,80H ;55621162 第一段《肆東方紅》
DB 20H,40H,20H,40H,1CH,20H,18H,20H,1CH,20H,20H,20H,30H,40H,30H,20H ;55616511
DB 39H,20H,2BH,80H,20H,40H,2BH,20H,30H,40H,33H,20H,39H,20H,40H,40H ;62521765
DB 20H,40H,2BH,40H,26H,20H,2BH,20H,30H,40H,30H,20H,39H,20H,2BH,20H ;52321162
DB 26H,20H,2BH,20H,30H,20H,2BH,20H,30H,20H,33H,20H,39H,20H,40H,80H ;32121765
DB 40H,80H,0FFH,20H,40H,2BH,20H,30H,40H,33H,20H,39H,20H,40H,40H ;O521765
DB 40H,80H,0FFH ;50
DB 20H,40H,20H,20H,1CH,20H,2BH,80H,30H,40H,30H,20H,39H,20H,2BH,80H ;55621162 第二段
DB 40H,80H,0FFH ;50
DB 40H,80H,0FFH ;50
DB 20H,40H,20H,20H,1CH,20H,2BH,80H,30H,40H,30H,20H,39H,20H,2BH,80H ;55621162 第三段
DB 40H,80H,0FFH,20H,40H,2BH,20H,30H,40H,33H,20H,39H,20H,40H,40H ;5O521765
DB 40H, 80H,0FFH ;50
DB 40H,20H,30H,60H,30H,40H,30H,20H,30H,10H,40H,20H,39H,30H,33H,30H ;51111567《伍國歌》
DB 30H,40H,30H,40H,0FFH, 26H,20H,30H,20H,2BH,10H,26H,10H,20H,30H ;11031235
DB 20H,10H,20H,40H,26H,20H,26H,10H,30H,20H,26H,10H,20H,20H,26H,10H ;55331353
DB 2BH,40H,2BH,80H,1CH,40H,20H,40H,2BH,40H,26H,40H,20H,20H,26H,40H ;22652353
DB 20H,20H,26H,20H,2BH,10H,26H,10H,30H,20H,2BH,10H,26H,40H,0FFH ;53231230
DB 20H,20H,39H,10H,30H,20H,30H,20H,26H,20H,26H,10H,2BH,20H,2BH,20H ;56113355
DB 2BH,20H,2BH,20H,2BH,20H,39H,30H,39H,10H,2BH,60H,40H,20H,30H,60H ;22266251
DB 30H,20H,26H,60H,26H,20H,20H,80H,20H,80H,30H,20H,26H,10H,20H,20H ;13355135
DB 20H,10H,1CH,40H,20H,40H,26H,20H,30H,10H,20H,20H,20H,20H,20H,20H ;56531555
DB 26H,20H,0FFH,30H,20H,0FFH,40H,40H,30H,40H,4CH,20H,30H,10H ;30105131
DB 20H,20H,20H,20H,20H,20H,26H,20H,0FFH,30H,20H,0FFH,40H,40H ;55530105
DB 30H,40H,40H,40H,30H,40H,40H,40H,30H,40H,30H,40H,0FFH,0FFH ;15151100
DB 0FFH,0FFH ;00
DB 00H ;結束
END
