//FLASH字節寫程序
//功能: 寫一個字節到內部FLASH
//入口: EEADRH,EEADR =地址
// EEDATH,EEDATA =數據
void write_flash ( void )
EEPGD = 1 ; //設置訪問目標為FLASH
WREN = 1 ; //允許進行寫操作
GIE = 0 ; //禁止中斷
EECON2 = 0x55 ;
EECON2 = 0xAA ;
WR = 1 ; //啟動一次寫操作
asm ("nop") ;
asm ("nop") ;
GIE = 1 ; //使能中斷
WREN = 0 ; //關閉寫操作
//FLASH字節讀程序
//功能: 從內部FLASH讀一個字節
//出口: EEDATH,EEDATA =數據
void read_flash( void )
RD = 1 ; //啟動一次讀操作
asm ("nop") ;
asm ("nop") ;
2.方法二:
void WriteEE(unsigned char addr,unsigned char data) //寫EEPROM
do{;}
while(WR==1); //上一次寫操作是否完成
EEADR=addr; //EEPROM地址
EEDATA=data; //準備寫入EEPROM的數據
EEPGD=0; //指向EEPROM數據儲存器
WREN=1; //使能寫操作
EECON2=0x55; //設置通用參數
EECON2=0xAA; //設置通用參數
WR=1; //開始寫
do{;}
while(WR==1); //等待寫操作完成
WREN=0; //禁止寫操作
unsigned char ReadEE(unsigned char addr) //讀EEPROM
unsigned char num;
do{;}
while(RD==1); //上一次讀操作是否完成
EEADR=addr; //EEPROM地址為00H
RD=1; //開始讀
do{;}
while(RD==1); //等待讀操作完成
num=EEDATA; //讀出
return(num); //返回讀出的數
說明:兩個程序基本步驟是一致的。個中的差別是:
1、一程序中更嚴密,其中增加了對WR和RD標志位的判別,缺點是實時性較差。
2、而二程序中沒有這個對WR和RD標志位的判別。那是因二將該判別的動作放在了上級程序中。也就是說,二在調用write_eeprom 函數之前,會先行判斷WR。確信上次寫操作已經結束后,才去調用新一次的寫操作。這樣做的目的是為了系統的實時性。
3.方法三:
PICC系統自帶“ PIC.H”文件中,已經內嵌了這兩個函數。!
以下是“ PIC.H”文件中的內容:
/****** EEPROM memory read/write macros and function definitions *******/
/* NOTE WELL:
The macro EEPROM_READ() is NOT safe to use immediately after any
write to EEPROM, as it does NOT wait for WR to clear. This is by
design, to allow minimal code size if a sequence of reads is
desired. To guarantee uncorrupted writes, use the function
eeprom_read() or insert
while(WR)continue;
before calling EEPROM_READ().
#if EEPROM_SIZE > 0
#ifdef __FLASHTYPE
// macro versions of EEPROM write and read
#define EEPROM_WRITE(addr, value) \
do{ \
while(WR)continue;EEADR=(addr);EEDATA=(value); \
EECON1&=0x7F;CARRY=0;if(GIE)CARRY=1;GIE=0; \
WREN=1;EECON2=0x55;EECON2=0xAA;WR=1;WREN=0; \
if(CARRY)GIE=1; \
}while(0)
#define EEPROM_READ(addr) ((EEADR=(addr)),(EECON1&=0x7F),(RD=1),EEDATA)
#else // else doesn't write flash
do{ \
if(CARRY)GIE=1; \
}while(0)
#define EEPROM_READ(addr) ((EEADR=(addr)),(RD=1),EEDATA)
#endif
/* library function versions */
extern void eeprom_write(unsigned char addr, unsigned char value);
extern unsigned char eeprom_read(unsigned char addr);
#endif // end EEPROM routines
真不錯,必須得頂上,沒有教程寫得那么詳細,頂~~~~~~~~~~~~~~~| 歡迎光臨 (http://www.raoushi.com/bbs/) | Powered by Discuz! X3.1 |
