用放大用LM324比較差··不過溫度還是可以穩(wěn)定,用M8 AD10位 pwm10位溫度范圍為200-500
精確度1度··
因為程序的原因加上要慢慢整定所以每次升溫到設(shè)定值前15度就開始整定··
有個缺點就是PID控制恒溫時的那幾度溫度升的很慢··
設(shè)置部分還沒寫好
自己的思路是直接用那個可變電阻做設(shè)置
AD轉(zhuǎn)換采樣可變電阻來設(shè)定溫度
設(shè)置一按鍵為溫度設(shè)定
當(dāng)按了那按鍵后可變電阻設(shè)定溫度有效
沒按的話不管你怎么轉(zhuǎn)都不能調(diào)節(jié)溫度
那部分寫完后整個代碼,發(fā)出來大家一起參考
發(fā)覺問題還很多的。。希望大家多提下意見,小弟初學(xué)的
還有如果要改的話可以不改那電路的引一條采樣跟控制線出來直接連上M8也可以的
- project :A/D轉(zhuǎn)換數(shù)碼管顯示
- chip type : atmega8
- clock frequency:內(nèi)部RC(INT) 8MHz
- Author :周遠(yuǎn)峰
- #include "iom8v.h"
- #include "macros.h"
- #define osccal 0x7d
- unsigned long adc_rel; //處理后世界轉(zhuǎn)換結(jié)果
- unsigned long adc_rl; //A/D轉(zhuǎn)換結(jié)
- unsigned int tmp; //設(shè)置的溫度參數(shù)
- unsigned char adc_mux; //A/D通道
- unsigned char led_buff[3]={0,0,0}; //顯示緩存
- signed int error0; //當(dāng)前偏差
- signed int error1; //上次偏差
- signed int error2; //上上次偏差
- signed char Kp; //比例常數(shù)
- signed char Ki; //積分常數(shù)
- signed char Kd; //微分常數(shù)
- signed int kk1; //當(dāng)前控制輸出
- signed int kk2; //上次控制輸出
- #define NB -3
- #define NM -2
- #define NS -1
- #define ZO 0
- #define PS 1
- #define PM 2
- #define PB 3
- #pragma data:code
- //設(shè)置數(shù)據(jù)區(qū)位程序儲存器
- const unsigned char seg_table[16]={0x40,0x79,0x24,0x30,0x19,0x90,0x80,0x78,0x00,0x10,0x08,0x81,0x44,0x21,0x04,0x8c};
- const unsigned char KP_table[49]={PB,PB,PM,PM,PS,ZO,ZO,PB,PB,PM,PS,PS,ZO,NS,PM,PM,PM,PS,ZO,NS,NS,PM,PM,PS,ZO,NS,NM,NM,PS,PS,ZO,NS,NS,NM,NM,PS,ZO,NS,NM,NM,NM,NB,ZO,ZO,NM,NM,NM,NB,NB};
- const unsigned char KI_table[49]={NB,NB,NM,NM,NS,ZO,ZO,NB,NB,NM,NS,NS,ZO,ZO,NB,NM,NS,NS,ZO,PS,PS,NM,NM,NS,ZO,PS,PM,PM,NM,NS,ZO,PS,PS,PM,PB,ZO,ZO,PS,PS,PM,PB,PB,ZO,ZO,PS,PM,PM,PB,PB};
- const unsigned char KD_table[49]={PS,NS,NB,NB,NB,NM,NS,PS,NS,NB,NM,NM,NS,ZO,ZO,NS,NM,NM,NS,NS,ZO,ZO,NS,NS,NS,NS,NS,ZO,ZO,ZO,ZO,ZO,ZO,ZO,ZO,PB,NS,PS,PS,PS,PS,PB,PB,PM,PM,PM,PS,PS,PB};
- #pragma data:data
- //設(shè)置數(shù)據(jù)區(qū)回到數(shù)據(jù)儲存器
- 延時函數(shù)
- void delay_us(int time) //微秒級延時
- do
- time--;
- while (time>1);
- void delay_ms(unsigned int time) //毫秒級延時
- while (time!=0)
- delay_us(1000);
- time--;
- 中斷顯示初始化
- TIMER2 initialize - prescale:1024
- WGM: Normal
- desired value: 10mSec
- actual value: 9.984mSec (0.2%)
- void timer2_init(void)
- TCCR2 = 0x00; //stop
- ASSR = 0x00; //set async mode
- TCNT2 = 0xB2; //setup
- OCR2 = 0x4E;
- TCCR2 = 0x07; //start
- DDRB=0xff; //PC口為推挽1輸出
- PORTB=0xff; //PC口內(nèi)部上拉
- DDRD|=0xf1;
- PORTD&=0x1f; //關(guān)閉LED
- 中斷顯示
- #pragma interrupt_handler timer2_ovf_isr:5
- void timer2_ovf_isr(void)
- unsigned char i;
- static unsigned k;
- SEI();
- TCNT2 = 0xB2; //reload counter value
- for(i=0;i<3;i++)
- PORTB=led_buff[i];
- PORTD|=(1<<(i+5));//待顯示的位置1
- delay_ms(1);
- PWM初始化,OC1A口輸出
- void timer1_init(void)
- TCCR1B = 0x00; //stop
- TCNT1H = 0x00; //setup
- OCR1A = 200;
- TCCR1A = (1<<WGM11)|(1<<WGM10)|(1<<COM1A1);//輸出低電平
- TCCR1B = (1<<CS11)|(1<<CS10); //
- PID初始化
- void pidcalc_init(void)
- Kp=3;
- Ki=3;
- Kd=3;
- kk1=0; //當(dāng)前
- kk2=100;
- error0=0;
- error1=0;
- error2=0;
- tmp=300;
- void pidcalc_zizheng(void)
- if (tmp>adc_rel)
- if (kk2<500) kk2+=3;
- else kk2=500;
- if ((tmp-1)>adc_rel)
- else kk2=500;
- /*if ((tmp-2)>adc_rel)
- if (kk2<600) kk2+=3;
- else kk2=600;
- if (tmp<adc_rel)
- if (kk2>10) kk2-=3;
- else kk2=10;
- if ((tmp+1)<adc_rel)
- else kk2=10;
- /*if ((tmp+2)<adc_rel)
- else kk2=10;
- /*if (tmp>adc_rel)
- if (Ki<200) Ki+=4;
- else Ki=400;
- if (tmp<adc_rel)
- if (Ki>0) Ki-=4;
- else Ki=0;
- PID函數(shù)
- void pidcalc(void)
- signed long KPP;
- signed long KII;
- signed long KDD;
- signed int i;
- signed char j;
- error0=tmp-adc_rel;
- j=error0-error1;
- i=7*(3+error0)+(3+j);
- if(i<49)
- if (i>0)
- Kp=KP_table[i];
- Ki=KI_table[i];
- Kd=KD_table[i];
- } //輸出
- if ((tmp-15)<adc_rel) //比設(shè)定低一定值時開始PID
- if((tmp+5)>adc_rel) //比設(shè)定高時關(guān)PID
- KPP=Kp*(error0-error1); //比例
- KII=error0*Ki; //積分
- KDD=Kd*(error0-(2*error1)+error2); //微分
- kk1=(KPP+KII+KDD)*4+kk2;
- if(kk1<0x3ef)
- if (kk1>=10) OCR1A=kk1;
- else OCR1A=0;
- else
- OCR1A=0x3ff;
- /*if((tmp-2)>adc_rel)
- if(OCR1A<500) OCR1A+=20;
- else OCR1A=500;
- else
- //if (tmp<adc_rel)
- /// if (OCR1A>50) OCR1A-=20;
- // else OCR1A=50;
- OCR1A=0;
- else
- OCR1A=0x3ff;
- error2=error1;
- error1=error0;
- ADC初始化
- void adc_init(void)
- DDRC=0x00;
- PORTC=0X00;
- ADCSRA=0X00;
- ADMUX=(1<<REFS1)|(1<<REFS0)|(adc_mux&0x0f); //選擇內(nèi)部2.56V為基準(zhǔn)AREF外加濾波電容
- ACSR=(1<<ACD); //關(guān)閉模擬比較器
- ADCSRA=(1<<ADEN)|(1<<ADSC)|(1<<ADIE)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);//128分頻
- ADC中斷處理函數(shù)
- #pragma interrupt_handler adc_isr:15
- void adc_isr(void)
- static unsigned i;
- adc_rl+=ADC&0x3ff;
- ADMUX=(1<<REFS1)|(1<<REFS0)|(adc_mux&0x0f); //選擇內(nèi)部2.56V位基準(zhǔn)
- ADCSRA|=(1<<ADSC); //啟動AD轉(zhuǎn)換
- if (i<2048)
- i++;
- else
- adc_rel=adc_rl/2048;
- adc_rel=adc_rel*3/5;
- i=0;
- adc_rl=0;
- ADC數(shù)據(jù)轉(zhuǎn)壓縮BCD
- void ADCtoBCD(unsigned int temp)
- unsigned char i;
- for (i=0;i<3;i++)
- led_buff[i]=seg_table[temp%10];/*temp%10求余數(shù)‘假設(shè)一個數(shù)是234那么234/10=23余4也就是查找4的段碼*/
- temp=temp/10;// 234/10=23因為不處理小數(shù)實際就等于右移了
- 主程序
- void main(void)
- unsigned char i;
- unsigned int k;
- unsigned int adc_old;
- unsigned long adc_ol;
- unsigned int adc_o;
- DDRD=0xff;
- PORTD=0xf0;
- OSCCAL=osccal;
- TIMSK = 0x40; //timer interrupt sources
- adc_mux=0;
- adc_init();
- timer1_init();
- pidcalc_init();
- SEI();
- for(i=0;i<3;i++)
- led_buff[i]=seg_table[8];
- for(i=0;i<200;i++)
- timer2_init();
- adc_old=0;
- adc_rel=0;
- while(1)
- if(adc_old!=adc_rel)//ADC更新完畢就執(zhí)行數(shù)據(jù)處理
- adc_old=adc_rel;
- pidcalc();
- pidcalc_zizheng();
- if(k<5)
- k++;
- adc_ol+=adc_old;
- else
- adc_o=adc_ol/5;
- adc_ol=0;
- k=0;
- ADCtoBCD(adc_o);
