標題: 新唐M051學習之(2)-串口 [打印本頁]
作者: dashan    時間: 2015-3-21 17:42
標題: 新唐M051學習之(2)-串口
        今天參照CMSIS庫里面的例子寫了個簡單的串口程序。
        在寫串口程序之前先把硬件連接好。準備一個USB轉TTL的模塊(我用的是STC的下載器),他可以把M051發送的數據傳送到計算機上,通過串口助手程序接收數據。USB轉TTL模塊的TXD接P3.0,RXD接P3.1,GND接M051的GND(也就是共地)。安裝12M晶振和30pf電容。如下圖所示。
MDK中也要做如下設置。從M051SeriesBSP_CMSIS_v2.01.002 里找到cor_cm0.c 、 system_M051Series.c 、 retarget.c 三個文件,加入到項目中,如下圖示。
includle paths 里面也要多包含兩個路徑:
C:\Keil\M051SeriesBSP_CMSIS_v2.01.002\M051SeriesBSP_CMSIS_v2.01.002\LibM051Series\CMSIS\CM0\CoreSupport
C:\Keil\M051SeriesBSP_CMSIS_v2.01.002\M051SeriesBSP_CMSIS_v2.01.002\LibM051Series\StdDriver\inc
源文件如下:
#include <stdio.h>
#include <M051Series.h>
#define PLLCON_SETTING      SYSCLK_PLLCON_50MHz_XTAL
#define PLL_CLOCK           50000000
void SystemInit(void)
void SYS_Init(void)
/* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable External XTAL (4~24 MHz) */
    SYSCLK->PWRCON |= SYSCLK_PWRCON_XTL12M_EN_Msk;
    /* Waiting for 12MHz clock ready */
    SYS_WaitingForClockReady( SYSCLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to XTAL */
    SYSCLK->CLKSEL0 = SYSCLK_CLKSEL0_HCLK_XTAL;
    /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    SYSCLK->PLLCON|= SYSCLK_PLLCON_PD_Msk;
    /* Set PLL frequency */
    SYSCLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    SYS_WaitingForClockReady(SYSCLK_CLKSTATUS_PLL_STB_Msk);
    /* Switch HCLK clock source to PLL */
    SYSCLK->CLKSEL0 = SYSCLK_CLKSEL0_HCLK_PLL;
    /* Enable IP clock */
    SYSCLK->APBCLK = SYSCLK_APBCLK_UART0_EN_Msk | SYSCLK_APBCLK_UART1_EN_Msk;
    /* Select IP clock source */
    SYSCLK->CLKSEL1 = SYSCLK_CLKSEL1_UART_XTAL;;
    /* Reset PWMB channel0~channel3 */
    SYS->IPRSTC2 = SYS_IPRSTC2_PWM47_RST_Msk;
    SYS->IPRSTC2 = 0;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
/* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD  */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
    /* Lock protected registers */
    SYS_LockReg();
void UART0_Init()
/* Init UART        */
    UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_DIV_MODE2(__XTAL,115200);
    _UART_SET_DATA_FORMAT(UART0, UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1);
int main(void)
    uint32_t u32Item;
    SYS_Init();
    UART0_Init();
    printf("請發送一個字符\n");
        u32Item = getchar();
        printf("你發送的是:%c\n",u32Item);
燒寫程序,并連接串口助手(我用的是STC的燒寫工具里的串口助手),助手的波特率必須設置115200,因為M051的程序里設置的是115200。隨便發送幾個字母測試。
