標題: lcd240*128液晶屏的單片機驅動程序(貪食蛇) [打印本頁]
作者: dajia    時間: 2015-3-21 04:51
#ifndef _lcd_h
#define _lcd_h
#define uchar unsigned  char
#define uint unsigned short
#define cd(x) (x?(IOSET1|=1<<16):(IOCLR1|=1<<16))
#define rd(x) (x?(IOSET1|=1<<17):(IOCLR1|=1<<17))
#define wr(x) (x?(IOSET1|=1<<18):(IOCLR1|=1<<18))
#define portout(dat) do{IOSET1 = (unsigned char)dat<<19;IOCLR1 = (~(unsigned char)dat<<19)&0x07f80000;}while(0)
#define portint() (IO1PIN&0X07f80000)
#define output() (IO1DIR |=0X07f80000)
#define input()  ((IO1DIR |=0Xf807ffff))
extern void lcd_init(void);
extern void sel_big(uchar x,uchar y);
extern void erect(uchar y0,uchar y1,uchar x);
extern void horizontal(uchar x0,uchar x1,uchar y);
extern void graph_mode_writeword(uchar x,uchar y,uchar *dat);
extern void word_byte(uchar row ,uchar list, uchar *pdat);
extern void lcd_writecom_two(uchar onedat,uchar twodat,uchar com);
extern void lcd_writedat_onebyte(uchar onedat,uchar com);
extern void lcd_writedat_nbyte(uchar *dat,uchar len);
extern void clear_point(uchar x,uchar y);
extern void sel_point(uchar x,uchar y);
extern void clr_big(uchar x,uchar y);
extern void clr_lcd(void);
extern void draw_circle(int x, int y, int r);
extern void Draw_line(uchar x0,uchar y0,uchar x1,uchar y1);
#endif
#include "includes.h"
       讀取lcd狀態
uchar lcd_readcom()
  uchar temp;
  input();
  cd(1);
  //ce=0;
  rd(0);
  wr(1);
  temp=portint();
  rd(1);
  return temp;
   判斷指令/數據讀寫忙碌狀態
void check_busy()
uchar temp;
do{
   temp=lcd_readcom();
   }while((temp&0x03)!=0x03);
   判斷數據自動寫忙碌狀態
void check_auto_write_busy()
uchar temp;
do{
   temp=lcd_readcom();
   }while((temp&0x08)!=0x08);
       向lcd寫命令
void lcd_writecom(uchar dat)
output();
//check_busy();
cd(1);
//ce=0;
portout(dat);
wr(0);
rd(1);
wr(1);
        向lcd寫數據
void lcd_writedat(uchar dat)
output();
//check_busy();
cd(0);
//ce=0;
portout(dat);
wr(0);
rd(1);
wr(1);
     從lcd讀數據
uchar lcd_readdat()
  uchar temp;
input();
  cd(0);
  wr(1);
  //ce=0;
   rd(0);
  temp=portint();
  rd(1);
  return temp;
  發出命令控制 參數 onedat  twodat 命令com
lcd_writedat(onedat);
lcd_writedat(twodat);
lcd_writecom(com);
      一次讀/寫一個數據
lcd_writecom(com);
/*uchar lcd_readdat_onebyte(uchar com)
uchar dat;
lcd_writedat(com);
dat=lcd_readdat();
return dat;
       一次寫n個數據
   lcd_writecom(0xb0);
  check_auto_write_busy();
   while(len)
     lcd_writedat(*dat);
  dat++;
     len--;
   lcd_writecom(0xb2);
清除一個點坐標 X,Y  左上角第一個點為0,0
uint addr;
uchar temp1,temp2;
addr=y*30+(x>>3);//32+8
temp1=addr&0x00ff;
temp2=addr>>8;
lcd_writecom_two(temp1,temp2,0x24);
lcd_writecom(0xf7-(x&0x07));
點亮一個點 坐標 X,Y  左上角第一個點為0,0
uint addr;
uchar temp1,temp2;
temp1=addr&0x00ff;
temp2=addr>>8;
lcd_writecom(0xff-(x&0x07));
void clr_lcd(void)
unsigned int len ;
  len=30<<7;
lcd_writecom_two(0,0x00,0x24);
  lcd_writecom(0xb0);
   while(len)
     lcd_writedat(0x00);
     len--;
   lcd_writecom(0xb2);
/*sel_big(uchar x,uchar y)
  uint addr;
  uchar temp1,temp2,n;
addr=y*160+(x>>1);//x/8*4;
for(n=0;n<4;n++)
  temp1=addr%256;
  temp2=addr>>8;
  if(x%2)
    lcd_writecom(0xfb);
  lcd_writecom(0xfa);
  lcd_writecom(0xf9);
  lcd_writecom(0xf8);
  lcd_writecom(0xff);
  lcd_writecom(0xfe);
  lcd_writecom(0xfd);
  lcd_writecom(0xfc);
  addr+=40;
  uint addr;
addr=y*240+(x);//x/8*4;y*320=y*(256+64)=(y<<8)+(y<<6)
for(n=0;n<8;n++)
  temp1=addr&0x00ff;//addr%256
  temp2=addr>>8;
  lcd_writecom(0xfb);
  lcd_writecom(0xfa);
  lcd_writecom(0xf9);
  lcd_writecom(0xf8);
  lcd_writecom(0xff);
  lcd_writecom(0xfe);
  lcd_writecom(0xfd);
  lcd_writecom(0xfc);
  addr+=30;
  uint addr;
for(n=0;n<8;n++)
  temp2=addr>>8;
  lcd_writecom(0xf3);
  lcd_writecom(0xf2);
  lcd_writecom(0xf1);
  lcd_writecom(0xf0);
  lcd_writecom(0xf7);
  lcd_writecom(0xf6);
  lcd_writecom(0xf5);
  lcd_writecom(0xf4);
  addr+=30;
  uint addr;
  uint temp1;   //4
  uchar n;
  temp1=y;temp1=temp1*480;//512+128  640
  addr=temp1+2*x;
   for(n=0;n<16;n++)
  lcd_writecom_two((addr&0x00ff),(addr>>8),0x24);
  lcd_writedat_onebyte(*dat,0xc0);
  dat++;
  lcd_writedat_onebyte(*dat,0xc4);
  dat++;
  addr=addr+30;
uchar addr_h,addr_l,n;
uint p_addr;
for(n=0;n<16;n++)
p_addr=(list+n)*30+row;
addr_h=p_addr>>8;
addr_l=p_addr%256;
lcd_writecom_two(addr_l,addr_h,0x24);
lcd_writecom(0xb0);
  lcd_writedat(*(pdat+n));
lcd_writecom(0xb2);
uchar temp,n;
if(x0>x1)
  temp=x0;
  x0=x1;
  x1=temp;
n=x1-x0;
for(;n>0;n--)
  sel_point(x0+n,y);
  uchar temp,n;
if(y0>y1)
  temp=y0;
  y0=y1;
  y1=temp;
n=y1-y0;
for(;n>0;n--)
  sel_point(x,y0+n);
int dx,dy;                //定義X.Y軸上增加的變量值
int  sub;
int temp;                //起點、終點大小比較,交換數據時的中間變量
uchar flag;
if(x0>x1)                //X軸上,起點大于終點,交換數據
   temp=x1;
   x1=x0;
   x0=temp;
   temp=y1;
   y1=y0;
   y0=temp;
dx=x1-x0;                //X軸方向上的增量
dy=y1-y0;                //Y軸方向上的增量
   if(dx==0)
   //Draw_shu(x0,y0,y1);
   erect(y0,y1,x0);
if(dy==0)
   //Draw_zhi(x0,x1,y0);
   horizontal(x0,x1,y0);
   if(dy>0)
    flag=1;
    flag=0;
if((dx!=0)&&(dy!=0))
// 布蘭森漢姆(Bresenham)算法畫線 /
if(flag==1)
  if(dx>=dy)                  //靠近X軸
   sub=2*dy-dx;              //計算下個點的位置
   while(x0!=x1)
   sel_point(x0,y0);        //畫起點
     x0++;                  // X軸上加1
     if(sub>0)                // 判斷下下個點的位置
       y0++;                  // 為右上相鄰點,即(x0+1,y0+1)
       sub+=2*dy-2*dx;
       sub+=2*dy;            // 判斷下下個點的位置
   sel_point(x0,y0);
   sub=2*dy-dx;              //靠近Y軸
   while(y0!=y1)
   y0++;
     if(sub>0)              //判斷下下個點的位置
       x0++;
       sub+=2*dx-2*dy;
       sub+=2*dx;
    sel_point(x0,y0);
   dy=y0-y1;
   if(dx>=dy)                  //靠近X軸
   while(x0!=x1)
     x0++;                  // X軸上加1
       y0--;                  // 為右上相鄰點,即(x0+1,y0+1)
       sub+=2*dy-2*dx;
   sel_point(x0,y0);
    sub=2*dx-dy;              //靠近Y軸
   while(y0!=y1)
     y0--;
       x0++;
       sub+=2*dx-2*dy;
       sub+=2*dx;
    sel_point(x0,y0);
    int a, b, num;
    a = 0;
    b = r;
    while(2 * b * b >= r * r)          // 1/8圓即可
        sel_point(x + a, y - b); // 0~1
        sel_point(x - a, y - b); // 0~7
        sel_point(x - a, y + b); // 4~5
        sel_point(x + a, y + b); // 4~3
        sel_point(x + b, y + a); // 2~3
        sel_point(x + b, y - a); // 2~1
        sel_point(x - b, y - a); // 6~7
        sel_point(x - b, y + a); // 6~5
        a++;
        num = (a * a + b * b) - r*r;
        if(num > 0)
            b--;
            a--;
void lcd_init()
     lcd_writecom_two(0x00,0x00,0x24);
        lcd_writecom_two(0x00,0x00,0x21);
        lcd_writecom_two(0x00,0x00,0x42);
        lcd_writecom_two(0x1e,0x00,0x43);
        lcd_writecom_two(0x00,0x10,0x40);
        lcd_writecom_two(0x1e,0x00,0x41);
        lcd_writecom(0xa0);
        lcd_writecom(0x9c);
        lcd_writecom(0x80);
