標(biāo)題: 利用定時(shí)器延時(shí) [打印本頁(yè)]
作者: sayno186    時(shí)間: 2015-2-11 20:56
#include <reg52.h>
#define DELAY_TIME 120       //時(shí)間設(shè)置    秒 = DELAY_TIME * system_delay(系統(tǒng)時(shí)標(biāo)時(shí)間)
bit b_switch_delay = 0;
unsigned char u_tem = 0;
void switch_delay()
        if (system_delay)
                system_delay = 0;                                //定時(shí)器系統(tǒng)時(shí)標(biāo)清0;
                if (u_temp >= DELAY_TIME)
                        b_switch_delay = 1;                        //延時(shí)時(shí)間標(biāo)記
                u_temp++;
//復(fù)位延時(shí)清0
void rst_switch_delay()
        u_temp                         = 0;                                //臨時(shí)計(jì)數(shù)變量清0;
        b_switch_delay         = 0;                                //延時(shí)時(shí)間標(biāo)記清0
作者: admin    時(shí)間: 2015-2-11 22:06
注釋比較詳細(xì),謝謝分享
