標(biāo)題: 單片機(jī)頻率測(cè)量+1602顯示程序 [打印本頁(yè)]
作者: dagu    時(shí)間: 2015-1-24 14:09
     大家注意一個(gè)問(wèn)題就可以了,被測(cè)頻率的最高值為晶振值除以24,如果是12M晶振,只能測(cè)到500K,如果想測(cè)量更高的程序,可以考慮分頻了,常用器件是74HC390或者是74LS390,看你的頻率了,當(dāng)讓?zhuān)?4HC74或者LS74可以把頻率降低一倍。
#include <reg52.h>
#include <intrins.h>
#define unit unsigned int
#define ulong unsigned long
typedef bit BOOL ;
uchar T0count=0;//T0計(jì)數(shù)
ulong f;
uchar temp[6]={0};
bit flag;
sbit rs = P2^7;
sbit rw = P2^6;
sbit ep = P2^5;
sbit L = P2^0;    //背光
sbit key1 = P2^1;    //
sbit key2 = P2^2;    //
sbit k0 = P1^0;    //
sbit k1 = P1^1;    //
sbit k2 = P1^2;    //
uchar code dis1[] = {" CRB L/C Meter "};
uchar code dis2[] = {"    2009-08-01    "};
delay(unit ms)
{         // 延時(shí)子程序
uchar i;
while(ms--)
      for(i = 0; i< 250; i++)
    {_nop_();_nop_();_nop_();_nop_();}
BOOL lcd_bz()
{         // 測(cè)試LCD忙碌狀態(tài)
BOOL result;
rs = 0; rw = 1; ep = 1;
result = (BOOL)(P0 & 0x80);
ep = 0;
return result;
lcd_wcmd(uchar cmd)
{         // 寫(xiě)入指令數(shù)據(jù)到LCD
while(lcd_bz());
rs = 0;rw = 0;ep = 0;
_nop_();_nop_();
P0 = cmd;
ep = 1;
ep = 0;
lcd_pos(uchar pos)
{         //設(shè)定顯示位置
lcd_wcmd(pos | 0x80);
lcd_wdat(uchar dat)
{         //寫(xiě)入字符顯示數(shù)據(jù)到LCD
while(lcd_bz());
rs = 1;rw = 0;ep = 0;
P0 = dat;
_nop_();_nop_(); _nop_();_nop_();
ep = 1;
ep = 0;
lcd_init()
{         //LCD初始化設(shè)定
lcd_wcmd(0x38);     //
delay(1);
lcd_wcmd(0x0c);     //
delay(1);
lcd_wcmd(0x06);     //
delay(1);
lcd_wcmd(0x01);     //清除LCD的顯示內(nèi)容
delay(1);
void dis(void)
f=T0count*65536+TH0*256+TL0; //計(jì)算0.05秒內(nèi)的脈沖次數(shù)
f=f*20;
     temp[0]=f/100000+0x30;
temp[1]=f%100000/10000+0x30;
temp[2]=f%100000%10000/1000+0x30;
temp[3]=f%100000%10000%1000/100+0x30;
temp[4]=f%100000%10000%1000%100/10+0x30;
temp[5]=f%100000%10000%1000%100%10+0x30;
main()
     uchar i;
TMOD=0x15; //T1定時(shí),T0計(jì)數(shù) 16位定時(shí)計(jì)數(shù)器
     TH0=0;TL0=0;
TH1=(65536-50000)/256;TL1=(65536-50000)%256;      //定時(shí)為0.05S
TR1=1;TR0=1;
ET0=1;ET1=1;
EA=1;
    //k2=0;
lcd_init();      // 初始化LCD
delay(10);
lcd_pos(0);      // 設(shè)置顯示位置
i = 0;
     L=0;
P1=0xff;
while(dis1[i] != '\0')
{        // 顯示字符
    lcd_wdat(dis1[i]);
    i++;
lcd_pos(0x40);     // 設(shè)置顯示位置為
i = 0;
while(dis2[i] != '\0')
    lcd_wdat(dis2[i]); // 顯示字符"
    i++;
lcd_wcmd(0x01);
while(1)      //
if(flag==1)
      dis();
    lcd_pos(0x80);     // 設(shè)置顯示位置
      lcd_wdat('-');
         for(i=0;i<=5;i++)
          lcd_wdat(temp[i]); // 顯示字符
    lcd_wdat('-');
      flag=0;
    T0count=0;
    TH0=0;TL0=0;
    TR0=1;TR1=1;
void t0(void) interrupt 1 using 1 //T0工作在計(jì)數(shù)狀態(tài)下,T0(P3.4)
     T0count++; //T0count中斷次數(shù)
void t1(void) interrupt 3 using 2 //T1工作在定時(shí)狀態(tài)下,
     TR0=0;TR1=0;
flag=1;
作者: lb688    時(shí)間: 2015-4-3 15:06
學(xué)習(xí)了。
作者: menwawork    時(shí)間: 2015-9-5 19:39
學(xué)習(xí)了。
作者: qq1223320836    時(shí)間: 2016-7-27 03:45
謝謝樓主
作者: 阿凡提    時(shí)間: 2016-12-23 21:12
這個(gè)可以學(xué)習(xí)一下
作者: 夢(mèng)寧一    時(shí)間: 2018-7-20 20:56
k0,k1,k2表示的什么
作者: 康德    時(shí)間: 2018-7-22 15:02
     TH0=0;TL0=0;
TR1=1;TR0=1;
ET0=1;ET1=1;
EA=1;
這個(gè)TMOD=0x15 什么意思啊??
請(qǐng)指點(diǎn)一下。。謝謝
作者: 電子迷ZZ    時(shí)間: 2019-8-13 15:42
下載學(xué)習(xí)一下!點(diǎn)贊
