architecture lammy01 of showled is
--signal in_data:std_logic_vector(3 downto 0);
begin
process(indata)
begin
case indata is
when "0000" => outdata<="0111111";--0
when "0001" => outdata<="0000110";--1
when "0010" => outdata<="1011011";--2
when "0011" => outdata<="1001111";--3
when "0100" => outdata<="1100110";--4
when "0101" => outdata<="1101101";--5
when "0110" => outdata<="1111101";--6
when "0111" => outdata<="0000111";--7
when "1000" => outdata<="1111111";--8
when "1001" => outdata<="1101111";--9
when others => null;
end case;
end process;
end;
///////////////cnt10.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
architecture lammy02 of cnt10 is
type state is(s0,s1,s2,s3);
signal led_state:state;
signal outdata_1,outdata_2,outdata_3,outdata_4:std_logic_vector(3 downto 0):="0000";
begin
lammy_01:process(rest,clk,led_state)
begin
if rest='1' then cout1<="0000";led_state<=s0;
elsif clk'event and clk='1' then
case led_state is
when s0 => bt<="1000";cout1<=outdata_1;led_state<=s1;
when s1 => bt<="0100";cout1<=outdata_2;led_state<=s2;
when s2 => bt<="0010";cout1<=outdata_3;led_state<=s3;
when s3 => bt<="0001";cout1<=outdata_4;led_state<=s0;
end case;
end if;
end process;
lammy_02:process(clk_key)
variable cout_1,cout_2,cout_3,cout_4:std_logic_vector(3 downto 0);
begin
if rising_edge(clk_key) then
if clk_md="000" then
if cout_1="1001" and cout_2="1001" and cout_3="1001" and cout_4="1001"
then cout_1:="1001" ; cout_2:="1001" ; cout_3:="1001" ; cout_4:="1001";
elsif cout_1="1001" and cout_2="1001" and cout_3="1001" then cout_4:=cout_4+1;cout_1:="0000";cout_2:="0000";cout_3:="0000";
elsif cout_1="1001" and cout_2="1001" then cout_3:=cout_3+1;cout_1:="0000";cout_2:="0000";
elsif cout_1="1001" then cout_2:=cout_2+1;cout_1:="0000";
else cout_1:=cout_1+1;
end if;
elsif clk_md="001" then
if cout_2="1001" and cout_3="1001" and cout_4="1001"
then cout_2:="1001" ; cout_3:="1001" ; cout_4:="1001";
elsif cout_2="1001" and cout_3="1001" then cout_4:=cout_4+1;cout_2:="0000";cout_3:="0000";
elsif cout_2="1001" then cout_3:=cout_3+1; cout_2:="0000";
else cout_2:=cout_2+1;
end if;
elsif clk_md="010" then
if cout_3="1001" and cout_4="1001"
then cout_3:="1001" ; cout_4:="1001";
elsif cout_3="1001" then cout_4:=cout_4+1;cout_3:="0000";
else cout_3:=cout_3+1;
end if;
elsif clk_md="011" then
if cout_4="1001" then cout_4:="1001";
else cout_4:=cout_4+1;
end if;
end if;
end if;
outdata_1<=cout_1;
outdata_2<=cout_2;
outdata_3<=cout_3;
outdata_4<=cout_4;
end process;
end;
