stm32 DEBUG USART程序
liuda
2015-1-23 01:32
stm32 DEBUG USART程序
#ifndef _DEBUGUSART_H_
#define _DEBUGUSART_H_
#include <stm32f10x.h>
#include<stdio.h>
#define USE_USART 3
#if(USE_USART==1)
#define DEBUG_USART USART1
#define DEBUGRX_PORT GPIOA
#define DEBUGRX_PIN GPIO_Pin_10//RX
#define DEBUGTX_PORT GPIOA
#define DEBUGTX_PIN GPIO_Pin_9//TX
#define DEBUG_USART_IRQn USART1_IRQn
#define DEBUG_RCC_APBnPeriphClockCmd() RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
#endif
#if (USE_USART==3)
#define DEBUG_USART USART3
#define DEBUGRX_PORT GPIOD
#define DEBUGRX_PIN GPIO_Pin_9//RX
#define DEBUGTX_PORT GPIOD
#define DEBUGTX_PIN GPIO_Pin_8//TX
#define DEBUG_USART_IRQn USART3_IRQn
#define DEBUG_RCC_APBnPeriphClockCmd() RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);\
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);\
GPIO_PinRemapConfig(GPIO_FullRemap_USART3,ENABLE);
#endif
void UARTGPIO_config(void);//串口IO口配置
void USART_config(u32 baudrate);//串口初始化
void UARTNVIC_config(void);//配置中斷
int fputc(int ch, FILE *f);//發送數據
int fgetc(FILE *f); // 接收數據
int USART_Scanf_Name(char * str);
void DEBUGUSART(u32 baudrate);
#endif
#include"DEBUG_USART.H"
USART_config(baudrate); //串口初始化19200
UARTGPIO_config(); //串口IO口配置
void UARTGPIO_config(void)//串口IO口配置
//GPIO_StructInit(&GPIO_InitStructure);//用默認值初始化結構體為所有端口2M浮空輸入
GPIO_InitStructure.GPIO_Pin = DEBUGTX_PIN;//PA9作為US1的TX端,負責發送數據
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//復用推挽輸出模式
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;//2M
GPIO_Init(DEBUGTX_PORT,&GPIO_InitStructure);//用以上值初始化PA9口
GPIO_InitStructure.GPIO_Pin = DEBUGRX_PIN;//PA10作為US1的RX端,負責接收數據
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空輸入模式
GPIO_Init(DEBUGRX_PORT, &GPIO_InitStructure);//用以上值初始化PA10口
void USART_config(u32 baudrate)//串口初始化
USART_InitTypeDef USART_InitStructure;
DEBUG_RCC_APBnPeriphClockCmd();
USART_StructInit(&USART_InitStructure);//將結構體設置為缺省狀態,9600bps,8數據位,1停止位,不校驗,硬件流控制失能
USART_InitStructure.USART_BaudRate =baudrate;//波特率設置為19200
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//一幀數據的寬度設置為8bits
USART_InitStructure.USART_StopBits = USART_StopBits_1;//在幀結尾傳輸1個停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//奇偶失能模式,無奇偶校驗
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//發送/接收使能
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//硬件流控制失能
USART_Init(DEBUG_USART, &USART_InitStructure);//設置串口1
//USART_ITConfig(DEBUG_USART, USART_IT_RXNE, ENABLE);//打開串口1的接收中斷響應函數
USART_Cmd(DEBUG_USART, ENABLE);//打開串口1
void UARTNVIC_config()//配置中斷
NVIC_InitTypeDef NVIC_InitStructure;
//NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);//選擇中斷分組1
NVIC_InitStructure.NVIC_IRQChannel = DEBUG_USART_IRQn;//選擇串口1中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//搶占式中斷優先級設置為0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;//響應式中斷優先級設置為3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中斷
NVIC_Init(&NVIC_InitStructure);
void DEBUG_USART_IRQHandler(void)//中斷方式的USART接收
if (USART_GetITStatus(DEBUG_USART, USART_IT_RXNE) != RESET) //判斷發生接收中斷
{//USART_ClearITPendingBit(DEBUG_USART, USART_IT_RXNE); //清除中斷標志,讀接收到的數據時自動清除
USART_SendData(DEBUG_USART, USART_ReceiveData(DEBUG_USART));//將數據回送至電腦
while(USART_GetFlagStatus(DEBUG_USART, USART_FLAG_TC) == RESET);//等待數據發送完畢
if (USART_GetFlagStatus(DEBUG_USART, USART_FLAG_RXNE) != RESET) //判斷接收標志;查詢方式的USART接收
USART_ReceiveData(DEBUG_USART);
USART_SendData(DEBUG_USART, i);//將數據回送至電腦
int fputc(int ch, FILE *f)//發送數據
USART_SendData(DEBUG_USART, (unsigned char) ch);//
while (!(DEBUG_USART->SR & USART_FLAG_TXE));
return (ch);
int fgetc(FILE *f) // 接收數據
while (!(DEBUG_USART->SR & USART_FLAG_RXNE));
return ((int)(DEBUG_USART->DR & 0x1FF));
//如果要使用printf函數除了#include<stdio.h>和重定義兩個輸入輸出函數外還應該Target->Code Generation中勾選Use MicroLIB
//char ch='E',str[10]={"FGHIJKLM"};
//int intd=12345;
//printf("The is a example!\n");
//printf("%c\n%s\n%d\n%c\n%s\n%d\n%d\n",'A',"BCD",0x23,ch,str,ch,intd);
//The is a example!
//A
//BCD
//35
//E
//FGHIJKLM
//69
//12345
* Function Name : USART_Scanf_Name
* Description : Gets Char values from the hyperterminal.
* Input : None
* Output : None
* Return : Length
u16 index = 0;
USART_ClearFlag(DEBUG_USART,USART_FLAG_RXNE);//清一下接收標志位
/* Loop until RXNE = 1 */
while(USART_GetFlagStatus(DEBUG_USART, USART_FLAG_RXNE) == RESET){}//等待直到有數據的到來
str[index++] = (USART_ReceiveData(DEBUG_USART));
printf("%c",str[index - 1]);//返回輸入的內容
if(str[index - 1] == 0x0d)//回車鍵\r
index--;//去掉回車符并以\0結尾
str[index] ='\0';//結束符號
return index;
