單片機實時時鐘實驗程序
liuda
2015-1-21 23:33
單片機實時時鐘實驗程序
是用51hei單片機開發板 電路圖詳見:
http://www.raoushi.com/f/51hei-5.pdf
的數碼管部分, 用2個74hc573 鎖存,p0口作為數據口 ,注意圖中要改一下p3.6和p3.7分別是段和位的鎖存端口.P2口上面是按鍵 p1口上面是8個led燈. 你用單片機自帶的定時器來做時鐘
#include<reg52.h>
uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar ACT[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar code WEEK_SEG7[8]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x7f};
sbit D=P3^6;
sbit V=P3^7;
uchar deda,sec,min,hour,week=1;
uchar cnt;
void init(void)
TMOD=0x11;
TH0=-(50000/256);
TL0=-(50000%256);
ET0=1;
TR0=1;
TH1=-(1000/256);
TL1=-(1000%256);
ET1=1;
TR1=1;
EA=1;
void time0(void) interrupt 1
TH0=-(50000/256);
TL0=-(50000%256);
deda++;
void time1(void) interrupt 3
TH1=-(1000/256);
TL1=-(1000%256);
if(++cnt>7)cnt=0;
switch(cnt)
case 0:D=1;P0=SEG7[sec%10];D=0;P0=0xff;V=1;P0=ACT[5];V=0;break;
case 1:D=1;P0=SEG7[sec/10];D=0;P0=0xff;V=1;P0=ACT[4];V=0;break;
case 2:D=1;P0=SEG7[min%10];D=0;P0=0xff;V=1;P0=ACT[3];V=0;break;
case 3:D=1;P0=SEG7[min/10];D=0;P0=0xff;V=1;P0=ACT[2];V=0;break;
case 4:D=1;P0=SEG7[hour%10];D=0;P0=0xff;V=1;P0=ACT[1];V=0;break;
case 5:D=1;P0=SEG7[hour/10];D=0;P0=0xff;V=1;P0=ACT[0];V=0;break;
case 6:D=1;P0=0x00;D=0;P0=0xff;V=1;P0=0xff;V=0;break;
case 7:D=1;P0=WEEK_SEG7[week];D=0;P0=0xff;V=1;P0=ACT[7];V=0;break;
default:break;
void conv(void)
if(deda>=20){deda=0;sec++;}
if(sec>=60){sec=0;min++;}
if(min>=60){min=0;hour++;}
if(hour>=24){hour=0;week++;}
if(week>7){week=1;}
void delay(uint k)
uint data i,j;
for(i=0;i<k;i++){
for(j=0;j<121;j++)
uchar scan_key(void)
uchar temp;
P2=0xff;
temp=P2;
if(temp!=0xff)
{delay(20);
temp=P2;
if(temp!=0xff)return temp;
return 0;
void main(void)
{uchar key_flag;
init();
conv();
key_flag=scan_key();
switch(key_flag)
case 0xef:if(++min>59)min=0;delay(300);break;
case 0xdf:if(++hour>23)hour=0;delay(300);break;
case 0xbf:if(++week>7)week=1;delay(300);break;
default:break;
