標(biāo)題: STARTUP.A51 研究 [打印本頁]
作者: heicc    時(shí)間: 2015-1-5 16:47
讓我們先來看看STARTUP.A51文件(默認(rèn)設(shè)置)吧!根據(jù)源文件中的說明文字,我們很容易分析出STARTUP.A51文件的工作方式和作用!讓我們把它先漢化一下看看!
$NOMOD51       ;Ax51宏匯編器控制命令:禁止預(yù)定義的8051
; This file is part of the C51 Compiler package
; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
; STARTUP.A51: This code is executed after processor reset.
; STARTUP.A51: STARTUP.A51文件所生成的代碼將在單片機(jī)復(fù)位后被執(zhí)行!
; To translate this file use A51 with the following invocation:
;   將按照下面的命令行語句調(diào)用A51編譯器進(jìn)行編譯產(chǎn)生目標(biāo)文件
;     A51 STARTUP.A51
; To link the modified STARTUP.OBJ file to your application use the following
; BL51 invocation:
;   將按照下面的命令行語句調(diào)用BL51連接器把STARTUP.OBJ定位連接到您的程序代碼中
;     BL51 <your object file list>, STARTUP.OBJ <controls>
; User-defined Power-On Initialization of Memory
; 自定義上電后需要初始化的儲(chǔ)存區(qū)域
; With the following EQU statements the initialization of memory
; at processor reset can be defined:
; 使用下列EQU偽指令定義初始化的存儲(chǔ)區(qū)域 在單片機(jī)復(fù)位后定義生效
;                   ; the absolute start-address of IDATA memory is always 0
IDATALEN            EQU     80H     ; the length of IDATA memory in bytes.
; IDATA(間接尋址區(qū))其起始地址固定為0;IDATALEN用于指定需要初始化
的IDATA區(qū)長度(以字節(jié)為單位)*
XDATASTART      EQU     0H      ; the absolute start-address of XDATA memory
XDATALEN           EQU      0H      ; the length of XDATA memory in bytes.
;XDATA (外部直接尋址區(qū)) XDATASTART用于指定需要初始化的XDATA區(qū)起始地
;XDATALEN 用于指定需要初始化的XDATA區(qū)長度(以字節(jié)為單位)*
PDATASTART      EQU     0H      ; the absolute start-address of PDATA memory
PDATALEN           EQU     0H      ; the length of PDATA memory in bytes.
;PDATA(頁尋址區(qū)) PDATASTART用于指定需要初始化的PDATA區(qū)起始地址
;PDATALEN用于指定需要初始化的;PDATA區(qū)長度(以字節(jié)為單位)*
; Notes: The IDATA space overlaps physically the DATA and BIT areas of the
;            8051 CPU. At minimum the memory space occupied from the C51
;           run-time routines must be set to zero.
;注釋:8051中 IDATA 區(qū)物理上已經(jīng)包括了DATA區(qū)(直接尋址區(qū))以及 BIT區(qū) (位尋址
             區(qū))。C51(庫)占用了 最小化內(nèi)存空間,運(yùn)行時(shí)程序需要把它設(shè)為0
; Reentrant Stack Initilization
; 重入堆棧初始化
; The following EQU statements define the stack pointer for reentrant
; functions and initialized it:
; 下面的EQU語句定義重入函數(shù)的堆棧指針并初始化它
; Stack Space for reentrant functions in the SMALL model.
; SMALL模式下的重入函數(shù)的堆棧空間
IBPSTACK        EQU     0       ; set to 1 if small reentrant is used.
;如果再SMALL模式下使用重入則設(shè)為1
IBPSTACKTOP     EQU     0FFH+1 ; set top of stack to highest location+1.
;設(shè)置堆棧頂 最高位置+1
; Stack Space for reentrant functions in the LARGE model.
; LARGE模式下的重入函數(shù)的堆棧空間
XBPSTACK        EQU     0       ; set to 1 if large reentrant is used.
;如果再LARGE模式下使用重入則設(shè)為1
XBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;設(shè)置堆棧頂 最高位置+1
; Stack Space for reentrant functions in the COMPACT model.
; COMPACT模式下的重入函數(shù)的堆棧空間
PBPSTACK        EQU     0       ; set to 1 if compact reentrant is used.
;如果再COMPACT模式下使用重入則設(shè)為1
PBPSTACKTOP     EQU     0FFFFH+1; set top of stack to highest location+1.
;設(shè)置堆棧頂 最高位置+1
; Page Definition for Using the Compact Model with 64 KByte xdata RAM
; 使用COMPACT模式時(shí)為64KB的XDATA RAM定義頁
; The following EQU statements define the xdata page used for pdata
; variables. The EQU PPAGE must conform with the PPAGE control used
; in the linker invocation.
; 下面的EQU語句定義PDATA變量的使用了XDATA頁
PPAGEENABLE     EQU     0       ; set to 1 if pdata object are used.
;如果使用PDATA頁則設(shè)為1
PPAGE           EQU     0       ; define PPAGE number.
;定義頁號(hào)
PPAGE_SFR       DATA    0A0H    ; SFR that supplies uppermost address byte
;SFR的最高地址字節(jié)
; (most 8051 variants use P2 as uppermost address byte)
; (大多數(shù)8051變量要用P2的最高地址字節(jié))
; Standard SFR Symbols
; 標(biāo)準(zhǔn)SFR符號(hào)
ACC     DATA    0E0H
B          DATA    0F0H
SP      DATA    81H
DPL     DATA    82H
DPH     DATA    83H
                                NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK                  SEGMENT   IDATA
                               RSEG    ?STACK
                                 DS      1
                               EXTRN CODE (?C_START)
;外部代碼(這個(gè)標(biāo)號(hào)將代表用戶程序的啟始地址)
                                PUBLIC ?C_STARTUP
;給外部使用的符號(hào)
                                CSEG    AT      0
;在code段的0地址處放以下代碼(使用AT指令進(jìn)行絕對(duì)地址的定位)
?C_STARTUP:     LJMP    STARTUP1
                              RSEG    ?C_C51STARTUP
STARTUP1:
IF IDATALEN <> 0
;如果長度大于1則初始化IDATA
                MOV     R0,#IDATALEN - 1
                CLR     A
IDATALOOP:      MOV     @R0,A
                DJNZ    R0,IDATALOOP
ENDIF
IF XDATALEN <> 0
;如果長度大于1則初始化XDATA
                MOV     DPTR,#XDATASTART
                MOV     R7,#LOW (XDATALEN)
IF (LOW (XDATALEN)) <> 0
;預(yù)置初始化時(shí)的外循環(huán)次數(shù)到R6
                MOV     R6,#(HIGH (XDATALEN)) +1
ELSE
                MOV     R6,#HIGH (XDATALEN)
ENDIF
                CLR     A
XDATALOOP:      MOVX    @DPTR,A
                INC     DPTR
                DJNZ    R7,XDATALOOP
                DJNZ    R6,XDATALOOP
ENDIF
IF PPAGEENABLE <> 0
                MOV     PPAGE_SFR,#PPAGE
ENDIF
IF PDATALEN <> 0
;如果長度大于1則初始化PDATA
                MOV     R0,#LOW (PDATASTART)
                MOV     R7,#LOW (PDATALEN)
                CLR     A
PDATALOOP:      MOVX    @R0,A
                INC     R0
                DJNZ    R7,PDATALOOP
ENDIF
IF IBPSTACK <> 0
;SMALL模式下使用重入函數(shù)時(shí)要設(shè)置的堆棧
EXTRN DATA (?C_IBP)
                MOV     ?C_IBP,#LOW IBPSTACKTOP
ENDIF
IF XBPSTACK <> 0
;COMPACT模式下使用重入函數(shù)時(shí)要設(shè)置的堆棧
EXTRN DATA (?C_XBP)
                MOV     ?C_XBP,#HIGH XBPSTACKTOP
                MOV     ?C_XBP+1,#LOW XBPSTACKTOP
ENDIF
IF PBPSTACK <> 0
;LARGE模式下使用重入函數(shù)時(shí)要設(shè)置的堆棧
EXTRN DATA (?C_PBP)
                MOV     ?C_PBP,#LOW PBPSTACKTOP
ENDIF
                MOV     SP,#?STACK-1
; This code is required if you use L51_BANK.A51 with Banking Mode 4
; 如果你的程序使用了Mode 4 程序分組技術(shù)(BANKING)請(qǐng)啟用下面的程序代碼
; EXTRN CODE (?B_SWITCH0)
;               CALL    ?B_SWITCH0      ; init bank mechanism to code bank 0
;程序從第一個(gè)塊(bank0)開始執(zhí)行
                LJMP    ?C_START ;從這里跳到你的程序入口
                END
