| #include<reg51.h> unsigned char code LedChar[] = { //數碼管顯示數 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E }; unsigned char LedBuff[7] = { //數碼管顯示緩沖區 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,0xFF }; unsigned char code Table[] = { 0xFE, 0xFD, 0xFB, 0xF7, 0xEF, 0xDF }; void DisPlay(unsigned long num); void delay1ms(unsigned char n); void LedScan(); void main() { DisPlay(53467); //數碼管顯示0 高位為0不顯示 LedScan(); } void DisPlay(unsigned long num) { signed char i; unsigned char buf[6]; for (i=0; i<6; i++) //把長整型數轉換為6位十進制的數組 { buf = num % 10; num = num / 10; } for (i=5; i>=1; i--) //從最高位起,遇到0轉換為空格,遇到非0則退出循環 { if (buf == 0) LedBuff = 0xFF; else break; } for ( ; i>=0; i--) //剩余低位都如實轉換為數碼管顯示字符 { LedBuff = LedChar[buf]; } } void LedScan() { unsigned char i; P0 = 0xFF; for (i=0; i<6; i++) { P2 = Table; P0 = LedBuff; delay1ms(1); } } void delay1ms(unsigned char n) { static unsigned char i; while(n--) for(i=0;i<125;i++); ?
資料:http://bbs.dzsc.com/showtopic-371170.html |
