I2C————AT24C02程序無現象
葛新華
2014-6-11 18:14
I2C————AT24C02程序無現象
寫的程序如下:實驗現象沒有。求教高人指點。
#include<reg52.h>
sbit scl=P2^1;
sbit sda=P2^0;
sbit de=P1^4;
sbit dula=P2^7;
sbit wela=P2^6;
void delay() [url=]//@12.000MHz[/url]
void Delay2ms() [url=]//@12.000MHz[/url] 2毫秒延時
unsigned char i, j;
i = 4;
j = 225;
do
while (--j);
} while (--i);
void init()
sda=1;
scl=1;
delay();
void start() //開始信號
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop() //停止信號
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons() //應答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<255))i++;
scl=0;
delay();
void write_byte(uchar date) //寫一個字節
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
scl=0;
delay();
temp<<=1;
sda=CY;
delay();
scl=1;
delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte(void) //讀取一個字節
uchar i,j;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
j=(j<<1)|sda;
scl=0;
delay();
return j;
void write_add(uchar address,uchar date)
{ //在xx位置寫個字節
start(); /**/
write_byte(0xa0); /**/
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
init();
start();
write_add(0x01,0xaa);
delay();
Delay4ms();
P0=read_add(0xaa);
delay();
Delay4ms();
de=0;
while(1);
