為什么不顯示第二個從機(jī)的數(shù)據(jù)
滿山屁股我最叼
2025-3-17 18:30
兩發(fā)一收,發(fā)1接收沒問題同時跟發(fā)二接收就出問題了發(fā)2的數(shù)據(jù)沒有變化#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#define TX_ADR_WIDTH 5// 5字節(jié)寬度的發(fā)送/接收地址
#define TX_PLOAD_WIDTH 12 // 數(shù)據(jù)通道有效數(shù)據(jù)寬度
#define TX_ADR_WIDTH1 5// 5字節(jié)寬度的發(fā)送/接收地址
#define TX_PLOAD_WIDTH1 12 // 數(shù)據(jù)通道有效數(shù)據(jù)寬度
uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};
uchar code TX_ADDRES[TX_ADR_WIDTH1] = {0xc2,0xc2,0xc2,0xc2,0xc1};
// 定義一個靜態(tài)發(fā)送地址
uchar RX_BUF[TX_PLOAD_WIDTH];
uchar TX_BUF[TX_PLOAD_WIDTH];
uchar RX_BUF1[TX_PLOAD_WIDTH1];
uchar TX_BUF1[TX_PLOAD_WIDTH1];
#define Nack_counter 10
sbit LCD_RS = P0^6;
sbit LCD_RW = P0^5;
sbit LCD_EN= P0^7;
#define LCD_DATA P2
sbit CE = P3^7;
sbit CSN = P3^2;
sbit SCK = P3^6;
sbit MOSI = P3^3;
sbit MISO = P3^5;
sbit IRQ = P3^4;
uchar flag;
uchar DATA = 0x01;
uchar bdata sta;
sbit RX_DR = sta^6;
sbit TX_DS = sta^5;
sbit MAX_RT = sta^4;
#define NRF_WRITE_REG(reg, value) nrf_write_register(reg, value)
#define NRF_READ_REG(reg) nrf_read_register(reg)
unsigned char RxBuf[20]; // 接收緩沖區(qū)
unsigned char RxBuf1[20];
/*******************命令寄存器***************************/
#define R_REGISTER 0x00//讀取配置寄存器
#define W_REGISTER 0x20//寫配置寄存器
// SPI(nRF24L01) commands
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // 'Config' register address
#define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
#define SETUP_AW 0x03 // 'Setup address width' register address
#define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
#define RF_CH 0x05 // 'RF channel' register address
#define RF_SETUP 0x06 // 'RF setup' register address
#define STATUS 0x07 // 'Status' register address
#define OBSERVE_TX 0x08 // 'Observe TX' register address
#define CD 0x09 // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
#define TX_ADDR 0x10 // 'TX address' register address
#define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
void delay_ms(uchar x);
unsigned char NRFSPI(unsigned char date)
unsigned char i;
for(i=0;i<8;i++) // 循環(huán)8次
if(date&0x80)
MOSI=1;
MOSI=0; // byte最高位輸出到MOSI
date<<=1; // 低一位移位到最高位
SCK=1;
if(MISO) // 拉高SCK,nRF24L01從MOSI讀入1位數(shù)據(jù),同時從MISO輸出1位數(shù)據(jù)
date|=0x01; // 讀MISO到byte最低位
SCK=0; // SCK置低
return(date); // 返回讀出的一字節(jié)
void SPI_Write(unsigned char dat) {
unsigned char i;
for(i=0; i<8; i++) {
MOSI = (dat & 0x80);
dat <<= 1;
SCK = 1;
_nop_();_nop_();
SCK = 0;
函數(shù): init_io()
描述:
初始化IO
void init_io(void)
CE = 0; // 待機(jī)
CSN = 1; // SPI禁止
SCK = 0; // SPI時鐘置低
IRQ = 1; // 中斷復(fù)位
函數(shù):delay_ms()
描述:
延遲x毫秒
uchar i, j;
i = 0;
for(i=0; i<x; i++)
j = 250;
while(--j);
j = 250;
while(--j);
函數(shù):SPI_RW()
描述:
根據(jù)SPI協(xié)議,寫一字節(jié)數(shù)據(jù)到nRF24L01,同時從nRF24L01
讀出一字節(jié)
uchar SPI_RW(uchar byte)
uchar i;
for(i=0; i<8; i++) // 循環(huán)8次
MOSI = (byte & 0x80); // byte最高位輸出到MOSI
byte <<= 1; // 低一位移位到最高位
SCK = 1; // 拉高SCK,nRF24L01從MOSI讀入1位數(shù)據(jù),同時從MISO輸出1位數(shù)據(jù)
byte |= MISO; // 讀MISO到byte最低位
SCK = 0; // SCK置低
return(byte); // 返回讀出的一字節(jié)
函數(shù):SPI_RW_Reg()
描述:
寫數(shù)據(jù)value到reg寄存器
uchar SPI_RW_Reg(uchar reg, uchar value)
uchar status;
CSN = 0; // CSN置低,開始傳輸數(shù)據(jù)
status = SPI_RW(reg); // 選擇寄存器,同時返回狀態(tài)字
SPI_RW(value); // 然后寫數(shù)據(jù)到該寄存器
CSN = 1; // CSN拉高,結(jié)束數(shù)據(jù)傳輸
return(status); // 返回狀態(tài)寄存器
函數(shù):SPI_Read()
描述:
從reg寄存器讀一字節(jié)
uchar SPI_Read(uchar reg)
uchar reg_val;
reg_val = SPI_RW(0); // 然后從該寄存器讀數(shù)據(jù)
return(reg_val); // 返回寄存器數(shù)據(jù)
函數(shù):SPI_Read_Buf()
描述:
從reg寄存器讀出bytes個字節(jié),通常用來讀取接收通道
數(shù)據(jù)或接收/發(fā)送地址
uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
uchar status, i;
for(i=0; i<bytes; i++)
pBuf[i] = SPI_RW(0); // 逐個字節(jié)從nRF24L01讀出
函數(shù):SPI_Write_Buf()
描述:
把pBuf緩存中的數(shù)據(jù)寫入到nRF24L01,通常用來寫入發(fā)
射通道數(shù)據(jù)或接收/發(fā)送地址
uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
uchar status, i;
SPI_RW(pBuf[i]); // 逐個字節(jié)寫入nRF24L01
函數(shù):RX_Mode()
描述:
這個函數(shù)設(shè)置nRF24L01為接收模式,等待接收發(fā)送設(shè)備的數(shù)據(jù)包
void RX_Mode(void)
CE = 0;
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 接收設(shè)備接收通道0使用和發(fā)送設(shè)備相同的發(fā)送地址
SPI_Write_Buf(WRITE_REG + RX_ADDR_P1, TX_ADDRES, TX_ADR_WIDTH);
SPI_RW_Reg(WRITE_REG + EN_AA, 0x03); // 使能接收通道0自動應(yīng)答
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x03); // 使能接收通道0
SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 選擇射頻通道0x40
SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // 接收通道0選擇和發(fā)送通道相同有效數(shù)據(jù)寬度
SPI_RW_Reg(WRITE_REG + RX_PW_P1, TX_PLOAD_WIDTH);
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // 數(shù)據(jù)傳輸率1Mbps,發(fā)射功率0dBm,低噪聲放大器增益
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC使能,16位CRC校驗,上電,接收模式
CE = 1; // 拉高CE啟動接收設(shè)備
函數(shù):Check_ACK()
描述:
檢查接收設(shè)備有無接收到數(shù)據(jù)包,設(shè)定沒有收到應(yīng)答信
號是否重發(fā)
uchar Check_ACK(bit clear)
while(IRQ);
sta = SPI_RW(NOP); // 返回狀態(tài)寄存器
if(MAX_RT)
if(clear) // 是否清除TX FIFO,沒有清除在復(fù)位MAX_RT中斷標(biāo)志后重發(fā)
SPI_RW(FLUSH_TX);
SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除TX_DS或MAX_RT中斷標(biāo)志
IRQ = 1;
if(TX_DS)
return(0x00);
return(0xff);
void delayms(unsigned int ms) {
unsigned int i, j;
for(i=0; i<ms; i++)
for(j=0; j<114; j++);
uchar exchange(unsigned char dat)
unsigned char i,j=0;
for(i=8;i>0;i--)
j|=(dat&0x01)<<(i-1);
dat>>=1;
return j;
void lcd_write_cmd(unsigned char cmd) {
LCD_RS = 0;
LCD_RW = 0;
LCD_DATA =exchange(cmd);
LCD_EN = 1;
delay_ms(2);
LCD_EN = 0;
void lcd_write_data(unsigned char dat) {
LCD_RS = 1;
LCD_RW = 0;
LCD_DATA =exchange(dat);
LCD_EN = 1;
delay_ms(2);
LCD_EN = 0;
void lcd_init() {
lcd_write_cmd(0x38);
delay_ms(5);
lcd_write_cmd(0x0C);
delay_ms(5);
lcd_write_cmd(0x06);
delay_ms(5);
lcd_write_cmd(0x01);
delay_ms(5);
void lcd_show_str(unsigned char x, unsigned char y, char *str) {
unsigned char addr;
if(y == 0) addr = 0x80 + x;
else addr = 0xC0 + x;
lcd_write_cmd(addr);
while(*str) {
lcd_write_data(*str++);
delay_ms(1);
void main() {
// unsigned char RX_P_NO;//接收通道號
lcd_init();
init_io();
RX_Mode();
while(1){
if(SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH) ){
lcd_show_str(0, 0, RX_BUF);
delay_ms(20);
init_io();
RX_Mode();
if(SPI_Read_Buf(RD_RX_PLOAD, RX_BUF1, TX_PLOAD_WIDTH) ){
lcd_show_str(0, 1, RX_BUF1);
delay_ms(20);
(3.57 MB, 下載次數(shù): 0)
2025-3-17 18:29 上傳
