標(biāo)題: 51單片機(jī)c語(yǔ)言音樂(lè)程序 [打印本頁(yè)]
作者: 070408meny    時(shí)間: 2024-11-4 18:20
#include <reg52.h>
#include <intrins.h>
sbit Beep =  P2^3 ;
unsigned char n=0;  //n為節(jié)拍常數(shù)變量
unsigned char code music_tab[] ={
0x18, 0x30, 0x1C , 0x10, //格式為: 頻率常數(shù), 節(jié)拍常數(shù), 頻率常數(shù), 節(jié)拍常數(shù),
0x20, 0x40, 0x1C , 0x10,
0x18, 0x10, 0x20 , 0x10,
0x1C, 0x10, 0x18 , 0x40,
0x1C, 0x20, 0x20 , 0x20,
0x1C, 0x20, 0x18 , 0x20,
0x20, 0x80, 0xFF , 0x20,
0x30, 0x1C, 0x10 , 0x18,
0x20, 0x15, 0x20 , 0x1C,
0x20, 0x20, 0x20 , 0x26,
0x40, 0x20, 0x20 , 0x2B,
0x20, 0x26, 0x20 , 0x20,
0x20, 0x30, 0x80 , 0xFF,
0x20, 0x20, 0x1C , 0x10,
0x18, 0x10, 0x20 , 0x20,
0x26, 0x20, 0x2B , 0x20,
0x30, 0x20, 0x2B , 0x40,
0x20, 0x30, 0x1C , 0x10,
0x18, 0x20, 0x15 , 0x20,
0x26, 0x40, 0x20 , 0x20,
0x2B, 0x20, 0x26 , 0x20,
0x20, 0x20, 0x30 , 0x80,
0x20, 0x10, 0x1C , 0x10,
0x20, 0x20, 0x26 , 0x20,
0x2B, 0x20, 0x30 , 0x20,
0x2B, 0x40, 0x20 , 0x15,
0x1F, 0x05, 0x20 , 0x10,
0x1C, 0x10, 0x20 , 0x20,
0x20, 0x20, 0x30 , 0x30,
0x18, 0x40, 0x1C , 0x20,
0x20, 0x20, 0x26 , 0x40,
0x13, 0x60, 0x18 , 0x20,
0x15, 0x40, 0x13 , 0x40,
0x18, 0x80, 0x00
void delay (unsigned char m)   //控制頻率延時(shí)
unsigned i=3*m;
while(--i);
void delayms(unsigned char a)  //豪秒延時(shí)子程序
  while(--a);
        unsigned char p,m;   //m為頻率常數(shù)變量
        unsigned char i=0;
        TMOD&=0x0f;
        TMOD|=0x01;
        TH0=0xd8;TL0=0xef;
        IE=0x82;
play:
        a:  p=music_tab[ i];
                if(p==0x00)
                        i=0, delayms(1000); goto play; //如果碰到結(jié)束符,延時(shí)1秒,回到開(kāi)始再來(lái)一遍
                        if(p==0xff)
                                i=i+1;delayms(100),TR0=0; goto a;  //若碰到休止符,延時(shí)100ms,繼續(xù)取下一音符
                                m=music_tab[i++], n=music_tab[i++];         //取頻率常數(shù) 和 節(jié)拍常數(shù)
                        TR0=1;                                             //開(kāi)定時(shí)器0
                while(n!=0)                    //等待節(jié)拍完成,輸出音頻
                        Beep=~Beep;
                        delay(m);
                TR0=0;                                             //關(guān)定時(shí)器0
void int0() interrupt 1   //采用中斷定時(shí)器0 控制節(jié)拍
        TH0=0xd8;
        TL0=0xef;
        n--;
