標題: esp32和8×8點陣寫貪吃蛇會有別的列一起點亮 [打印本頁]
作者: yuki·kiko    時間: 2024-9-4 16:07
import machine
import time
import random
import _thread  # MicroPython 線程庫
# 定義點陣的行和列引腳
rows = [machine.Pin(i, machine.Pin.OUT) for i in [32, 33, 25, 26, 27, 14, 12, 13]]
cols = [machine.Pin(i, machine.Pin.OUT) for i in [19, 18, 5, 17, 16, 4, 2, 15]]
snake_body = []  # 初始化蛇身體
direction = ()  # 蛇的方向
food = ()  # 食物的位置
direction_lock = _thread.allocate_lock()
def create_food():
    """生成不與蛇重合的食物位置"""
    global food
    while True:
        # 隨機生成食物的位置
        food = (random.randint(0, 7), random.randint(0, 7))
        if food not in snake_body:
            break  # 找到不重合的位置,退出循環
def init_snake():
    """初始化蛇的位置和方向"""
    global snake_body, direction
    snake_body = [(3, 3), (3, 2), (3, 1)]  # 初始化蛇身體
    direction = (0, 1)  # 初始化食物方向
    create_food()  # 初始化食物
def set_pixel(x, y, state):
    """設置點陣某個像素的狀態"""
    rows[x].value(not state)
    cols[y].value(state)
def clear_display():
    print("clear")
    for i in range(8):
        for j in range(8):
            set_pixel(i, j, 0)
def draw_snake():
    """繪制蛇和食物"""
    for segment in snake_body:
        print(f"{segment}")
        set_pixel(segment[0], segment[1], 1)
def draw_food():
    """繪制蛇和食物"""
    set_pixel(1, 1, 1)
    print(f"{food}")
def change_direction(new_direction):
    global direction
    opposite_direction = (-direction[0], -direction[1])
    if new_direction != opposite_direction:
        with direction_lock:
            direction = new_direction
def snake_move():
    """移動蛇的位置"""
    global snake_body, food
    # 計算新位置
    new_head = (snake_body[0][0] + direction[0], snake_body[0][1] + direction[1])
    # 使用取模運算使蛇在碰到墻壁時從另一側出現
    new_head = (new_head[0] % 8, new_head[1] % 8)
    if new_head in snake_body:
        return False  # 撞到自己,游戲結束
    snake_body.insert(0, new_head)  # 更新蛇頭位置
    # 吃到食物
    if new_head == food:
        create_food()
    else:
        snake_body.pop()  # 如果沒有吃到食物,尾巴移動
    return True
if __name__ == "__main__":
    init_snake()
#     _thread.start_new_thread(key_scan, ()) # 創建線程
    while True:
        if not snake_move():
            break  # 游戲結束
        clear_display()
        draw_snake()
        draw_food()
        time.sleep_ms(500)
這是代碼,如果是整列從左到右或者從上到下進行點亮就沒問題,如果是用這個代碼進行單個循環點亮時就會有別的列一起點亮,是為什么呢
作者: yuki·kiko    時間: 2024-9-4 16:09
就像這樣
作者: GlenXu    時間: 2024-9-6 12:02
顯示或循環處理速度過快,加點延時
