標題: 用單片機+液晶顯示的一個時鐘 [打印本頁]
作者: n04769431433    時間: 2024-7-4 10:17
標題: 用單片機+液晶顯示的一個時鐘
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit dula=P2^6;
  5. sbit wela=P2^7;
  6. sbit rs=P3^5;
  7. sbit lcden=P3^4;
  8. sbit s1=P3^0;
  9. sbit s2=P3^1;
  10. sbit s3=P3^2;
  11. sbit rd=P3^7;
  12. uchar count,s1num;
  13. char miao,shi,fen;
  14. uchar code table[]="  2007-7-30 MON";
  15. uchar code table1[]="    00:00:00";
  16. void delay(uint z)
  17. {
  18.         uint x,y;
  19.         for(x=z;x>0;x--)
  20.                 for(y=110;y>0;y--);
  21. }
  22. void write_com(uchar com)
  23. {
  24.         rs=0;
  25.         lcden=0;
  26.         P0=com;
  27.         delay(5);
  28.         lcden=1;
  29.         delay(5);
  30.         lcden=0;
  31. }
  32. void write_date(uchar date)
  33. {
  34.         rs=1;
  35.         lcden=0;
  36.         P0=date;
  37.         delay(5);
  38.         lcden=1;
  39.         delay(5);
  40.         lcden=0;
  41. }
  42. void init()
  43. {
  44.         uchar num;
  45.         dula=0;
  46.         wela=0;
  47.         lcden=0;
  48. //        fen=59;
  49. //        miao=53;
  50. //        shi=23;
  51.         write_com(0x38);
  52.         write_com(0x0c);
  53.         write_com(0x06);
  54.         write_com(0x01);
  55.         write_com(0x80);
  56.         for(num=0;num<15;num++)
  57.                 {
  58.                         write_date(table[num]);
  59.                         delay(5);
  60.                 }
  61.         write_com(0x80+0x40);
  62.         for(num=0;num<12;num++)
  63.                 {
  64.                         write_date(table1[num]);
  65.                         delay(5);
  66.                 }
  67.         TMOD=0x01;
  68.         TH0=(65536-50000)/256;
  69.         TL0=(65536-50000)%256;
  70.         EA=1;
  71.         ET0=1;
  72.         TR0=1;
  73. }
  74. void write_sfm(uchar add,uchar date)
  75. {
  76.         uchar shi,ge;
  77.         shi=date/10;
  78.         ge=date%10;
  79.         write_com(0x80+0x40+add);
  80.         write_date(0x30+shi);
  81.         write_date(0x30+ge);
  82. }
  83. void keyscan()
  84. {
  85.         rd=0;
  86.         if(s1==0)
  87.         {
  88.                 delay(5);
  89.                 if(s1==0)
  90.                 {        s1num++;
  91.                         while(!s1);
  92.                         if(s1num==1)
  93.                         {
  94.                                 TR0=0;
  95.                                 write_com(0x80+0x40+10);
  96.                                 write_com(0x0f);
  97.                         }
  98.         }
  99.                         if(s1num==2)
  100.                         {
  101.                                 write_com(0x80+0x40+7);
  102.                         }
  103.                         if(s1num==3)
  104.                         {
  105.                                 write_com(0x80+0x40+4);
  106.                         }
  107.                         if(s1num==4)
  108.                         {
  109.                                 s1num=0;
  110.                                 write_com(0x0c);
  111.                                 TR0=1;
  112.                         }
  113.
  114.                 }
  115.                 if(s1num!=0)
  116.                 {
  117.                         if(s2==0)
  118.                         {
  119.                                 delay(5);
  120.                                 if(s2==0)
  121.                                 {
  122.                                         while(!s2);
  123.                                         if(s1num==1)
  124.                                         {
  125.                                                 miao++;
  126.                                                 if(miao==60)
  127.                                                         miao=0;
  128.                                                 write_sfm(10,miao);
  129.                                                 write_com(0x80+0x40+10);
  130.
  131.
  132.                                         }
  133.                                         if(s1num==2)
  134.                                         {
  135.                                                 fen++;
  136.                                                 if(fen==60)
  137.                                                         fen=0;
  138.                                                 write_sfm(7,fen);
  139.                                                 write_com(0x80+0x40+7);
  140.                                         }
  141.                                         if(s1num==3)
  142.                                         {
  143.                                                 shi++;
  144.                                                 if(shi==24)
  145.                                                         shi=0;
  146.                                                 write_sfm(4,shi);
  147.                                                 write_com(0x80+0x40+4);
  148.                                         }
  149.                                 }
  150.                         }
  151.                         if(s3==0)
  152.                         {
  153.                                 delay(5);
  154.                                 if(s3==0)
  155.                                 {
  156.                                         while(!s3);
  157.                                         if(s1num==1)
  158.                                         {
  159.                                         /*        if(miao==0)
  160.                                                 {
  161.                                                         miao=59;
  162.                                                         write_sfm(10,miao);
  163.                                                         write_com(0x80+0x40+10);
  164.                                                 }*/
  165.                                                 miao--;
  166.                                                 if(miao==-1)
  167.                                                         miao=59;
  168.                                                 write_sfm(10,miao);
  169.                                                 write_com(0x80+0x40+10);
  170.                                         }
  171.                                         if(s1num==2)
  172.                                         {
  173.                                                 fen--;
  174.                                                 if(fen==-1)
  175.                                                         fen=59;
  176.                                                 write_sfm(7,fen);
  177.                                                 write_com(0x80+0x40+7);
  178.                                         }
  179.                                         if(s1num==3)
  180.                                         {
  181.                                                 shi--;
  182.                                                 if(shi==-1)
  183.                                                         shi=23;
  184.                                                 write_sfm(4,shi);
  185.                                                 write_com(0x80+0x40+4);
  186.                                         }
  187.                                 }
  188.                         }
  189.                 }
  190. }
  191. void main()
  192. {
  193.         init();
  194.         while(1)
  195.         {
  196.                 keyscan();
  197.
  198.         }
  199. //        while(1);
  200. }
  201. void timer0() interrupt 1
  202. {
  203.         TH0=(65536-50000)/256;
  204.         TL0=(65536-50000)%256;
  205.         count++;
  206. if(count==18)
  207.                 {
  208.                         count=0;
  209.                         miao++;
  210.                         if(miao==60)
  211.                         {
  212.                                 miao=0;
  213.                                 fen++;
  214.                                 if(fen==60)
  215.                                 {
  216.                                         fen=0;
  217.                                         shi++;
  218.                                         if(shi==24)
  219.                                         {
  220.                                                 shi=0;
  221.                                         }
  222.                                         write_sfm(4,shi);
  223.                                 }
  224.                                 write_sfm(7,fen);
  225.                         }
  226.                         write_sfm(10,miao);
  227.
  228.                 }
  229. }
作者: cy009    時間: 2025-5-21 10:23
sbit dula=P2^6;
sbit wela=P2^7;
作者: cy009    時間: 2025-5-21 10:28
sbit dula=P2^6;
sbit wela=P2^7;
void init()
        uchar num;
        dula=0;
        wela=0;
通過分析程序,樓主的時鐘案例應該是從數碼管提升到LCD1206,是一個進步,但思路還不夠清晰,程序中還保留有數碼管驅動鎖存器的定義。
