標題: 如何實現msp430f5529單片機串口接收來自openmv發送的字符串數據后又反發送回去 [打印本頁]
作者: dismay    時間: 2024-7-3 18:24
我想實現的功能是openmv進行圖片處理后,可以得到色塊像素個數,將像素個數轉為字符串類型并發送給msp430f5529,msp430f5529串口接收來自openmv發送的字符串數據后又反發送回去給openmv,請問這是可以實現的嗎?也是通過UCA0TXBUF = UCA0RXBUF來進行的嗎?
//msp430f5529代碼
#include <msp430.h>
#define CPU_F ((double)1000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
void Uart_Init(void)
        P3SEL |= BIT3+BIT4;
        UCA0CTL1 |= UCSWRST;
        UCA0CTL1 |= UCSSEL_2;
        UCA0BR0 = 6;
        UCA0BR1 = 0;
        UCA0MCTL = UCBRS_0 + UCBRF_13 + UCOS16;
        UCA0CTL1 &= ~UCSWRST;
        UCA0IE |= UCRXIE;
        _EINT();
void send_char()
    UCA0TXBUF = UCA0RXBUF;
    while (!(UCA0IFG&UCTXIFG));
void send_string(unsigned char *p)
    while(*p!='\0')
        while(!(UCA0IFG&UCTXIFG));
        UCA0TXBUF=*p;
        *p++;
char rec;
int main(void)
    WDTCTL = WDTPW + WDTHOLD;
    Uart_Init();
    __bis_SR_register(GIE);
        send_char();
        delay_ms(1000);
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
  switch(__even_in_range(UCA0IV,4))
      case 2:
            rec = UCA0RXBUF;
            break;
      default: break;
//openmv代碼
import sensor, image, time
from pyb import LED
from pyb import UART
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QQVGA)
sensor.skip_frames(time = 2000)
uart = UART(3, 9600)
uart.init(9600, bits=8, parity=None, stop=1)
clock = time.clock()
yellow_threshold   = (52, 2, 108, 21, 102, -7)
LED(1).on()
LED(2).on()
LED(3).on()
def receive_data():
    global uart
    if (uart.any()):
        tmp_data = uart.read();
        #tmp_data = uart.readline();
        print(tmp_data)
while(True):
    clock.tick()
    img = sensor.snapshot()
    blobs = img.find_blobs([yellow_threshold])
    if blobs:
        for blob in blobs:
            img.draw_rectangle(blob.rect())
            num = blob.pixels()
            uart.write(str(num))
            receive_data();
            time.sleep_ms(1000)
    else:
        print("no")
