基于51單片機制作的低頻正弦信號發生器Proteus仿真程序
3112996265
2024-5-22 10:49
其控制核心是51系列單片機AT89C51,能產生14~44Hz的低頻正弦信號,可作為電子測量中的低頻信號源
附件里面包含源代碼文件,原理圖文件,希望能幫到大家
(235.07 KB, 下載次數: 46)
2024-5-22 13:51 上傳
#include <intrins.h>
#include <reg51.h>
#include <math.h>
typedef unsigned char Uchar;
typedef unsigned int Uint;
#define Segport P1
#define DAport P2
#define NOP _nop_()
sbit DA0832wr = P3^7;
Uchar FreqcValue = 30;
Uchar code DAdata[] = {0x08,0x83,0x85,0x88,0x8A,0x8D,0x8F,0x92,
0x94,0x97,0x99,0x9B,0x9E,0xA0,0xA3,0xA5,
0xA7,0xAA,0xAC,0xAE,0xB1,0xB3,0xB5,0xB7,
0xB9,0xBB,0xBD,0xBF,0xC1,0xC3,0xC5,0xC7,
0xC9,0xCB,0xCC,0xCE,0xD0,0xD1,0xD3,0xD4,
0xD6,0xD7,0xD8,0xDA,0xDB,0xDC,0xDD,0xDE,
0xDF,0xE0,0xE1,0xE2,0xE3,0xE3,0xE4,0xE4,
0xE5,0xE5,0xE6,0xE6,0xE7,0xE7,0xE7,0xE7,
0xE7,0xE7,0xE7,0xE7,0xE6,0xE6,0xE5,0xE5,
0xE4,0xE4,0xE3,0xE3,0xE2,0xE1,0xE0,0xDF,
0xDE,0xDD,0xDC,0xDB,0xDA,0xD8,0xD7,0xD6,
0xD4,0xD3,0xD1,0xD0,0xCE,0xCC,0xCB,0xC9,
0xC7,0xC5,0xC3,0xC1,0xBF,0xBD,0xBB,0xB9,
0xB7,0xB5,0xB3,0xB1,0xAE,0xAC,0xAA,0xA7,
0xA5,0xA3,0xA0,0x9E,0x9B,0x99,0x97,0x94,
0x92,0x8F,0x8D,0x8A,0x88,0x85,0x83,0x80,
0x7D,0x7B,0x78,0x76,0x73,0x71,0x6E,0x6C,
0x69,0x67,0x65,0x62,0x60,0x5D,0x5B,0x59,
0x56,0x54,0x52,0x4F,0x4D,0x4B,0x49,0x47,
0x45,0x43,0x41,0x3F,0x3D,0x3B,0x39,0x37,
0x35,0x34,0x32,0x30,0x2F,0x2D,0x2C,0x2A,
0x29,0x28,0x26,0x25,0x24,0x23,0x22,0x21,
0x20,0x1F,0x1E,0x1D,0x1D,0x1C,0x1C,0x1B,
0x1B,0x1A,0x1A,0x1A,0x19,0x19,0x19,0x19,
0x19,0x19,0x19,0x19,0x1A,0x1A,0x1A,0x1B,
0x1B,0x1C,0x1C,0x1D,0x1D,0x1E,0x1F,0x20,
0x21,0x22,0x23,0x24,0x25,0x26,0x28,0x29,
0x2A,0x2C,0x2D,0x2F,0x30,0x32,0x33,0x35,
0x37,0x39,0x3B,0x3D,0x3F,0x41,0x43,0x45,
0x47,0x49,0x4B,0x4D,0x4F,0x52,0x54,0x56,
0x59,0x5B,0x5D,0x60,0x62,0x65,0x67,0x69,
0x6C,0x6E,0x71,0x73,0x76,0x78,0x7B,0x7D
void dlay();
void T0f(void) interrupt 1
static Uchar i;
P2 = DAdata[i++];
DA0832wr = 1;
NOP; NOP;
DA0832wr = 0;
Uchar keyValue;
float tmp;
P3 = 0xFF;
P1 = 0xff;
TMOD = 0x02; // ö ʱ ģʽ
IE = 0x82;
dlay();
while (1)
P1 = ((FreqcValue / 10) << 4) | (FreqcValue % 10);
keyValue = P3 & 0x7f;
switch (keyValue)
case 0x7b:
dlay();
do
} while (keyValue == 0x7b);
if (FreqcValue < 44)
FreqcValue++;
break;
case 0x77:
dlay();
do
} while (keyValue == 0x77);
if (FreqcValue > 14)
FreqcValue--;
break;
case 0x3f:
dlay();
do
} while (keyValue == 0x3f);
tmp = 256 - 3600 / FreqcValue;
TH0 = tmp;
TL0 = tmp;
TR0 = 1;
break;
void dlay()
Uchar i, j;
for (i = 0; i < 20; i++)
for (j = 0; j < 255; j++)
Proteus8.13仿真和程序2個文件下載:
仿真程序.7z
(92.53 KB, 下載次數: 9)
2024-5-22 13:51 上傳
