求用at89c51單片機測LM331 V/F轉(zhuǎn)化后的頻率 我的沒有顯示
煩熱
2024-2-28 23:35
我的沒有顯示,幫一下,謝謝。
要仿真圖和程序
(76.56 KB, 下載次數(shù): 69)
2024-2-28 23:45 上傳
#include <reg51.h>
sbit Awei = P1^0;
sbit Bwei = P1^1;
sbit Cwei = P1^2;
sbit Dwei = P1^3;
void jisuan();
void delay(int x);
int change(int x);
#define SHU_0 0X3F;
#define SHU_1 0X06;
#define SHU_2 0X5B;
#define SHU_3 0X4F;
#define SHU_4 0X66;
#define SHU_5 0X6D;
#define SHU_6 0X7D;
#define SHU_7 0X07;
#define SHU_8 0X7F;
#define SHU_9 0X6F;
int ge=0, shi=0, bai=0, qian=0;
int count = 0, i = 0;
int freq = 0;
int main()
ge = 0; shi = 0; bai = 0; qian = 0;
TMOD = 0X15;
TH0 = 0;
TL0 = 0;
TH1 = (65535 - 50000)/256;
TL1 = (65535 - 50000)%256;
IT0 = 1;
EX0 = 1;
EA = 1;
ET0 = 1;
ET1 = 1;
TR0 = 1;
TR1 = 1;
jisuan();
Awei = 1; Bwei = 1; Cwei = 1; Dwei = 0;
P2 = change(ge);
delay(10);
P2 = 0X00;
Awei = 1; Bwei = 1; Cwei = 0; Dwei = 1;
P2 = change(shi);
delay(10);
P2 = 0X00;
Awei = 1; Bwei = 0; Cwei = 1; Dwei = 1;
P2 = change(bai);
delay(10);
P2 = 0X00;
Awei = 0; Bwei = 1; Cwei = 1; Dwei = 1;
P2 = change(qian);
delay(10);
P2 = 0X00;
void service_timer0() interrupt 1 using 1
TH0 = 0;
TL0 = 0;
void service_timer1() interrupt 3 using 3
i++;
if (i == 20)
freq =TL0 + TH0*256;
i = 0;
TH0 = 0;
TL0 = 0;
void jisuan()
qian = freq /1000;
bai = (freq%1000)/100;
shi = (freq%100)/10;
ge = freq%10;
void delay(int x)
int i, j;
for(i = 0; i < x; i++)
for(j = 0; j < 100; j++);
int change(int x)
int shu;
switch(x)
case 0: shu = SHU_0; break;
case 1: shu = SHU_1; break;
case 2: shu = SHU_2; break;
case 3: shu = SHU_3; break;
case 4: shu = SHU_4; break;
case 5: shu = SHU_5; break;
case 6: shu = SHU_6; break;
case 7: shu = SHU_7; break;
case 8: shu = SHU_8; break;
case 9: shu = SHU_9; break;
return shu;
