標(biāo)題: 基于51單片機(jī)的時(shí)間日期顯示(DS1302+OLED0.96+按鍵可調(diào)+定時(shí)器掃描按鍵) [打印本頁(yè)]
作者: 來(lái)3毛錢(qián)的    時(shí)間: 2024-2-6 20:44
#include <STC89C5xRC.H>
#include "OLED.h"
#include "ds1302.h"
#include "Key.h"
#include "Timer0.h"
unsigned char keynum,mode,adjust_bit,adjust_bit_flag;
unsigned char hmd,tmp;
void timeshow()
        ds1302_readtime();
        OLED_ShowNum(0,0,20,2,16);
        OLED_ShowNum(18,0,ds1302_time[0],2,16);
        OLED_ShowNum(56,0,ds1302_time[1],2,16);
        OLED_ShowNum(94,0,ds1302_time[2],2,16);
        OLED_ShowNum(0,2,ds1302_time[3],2,16);
        OLED_ShowNum(28,2,ds1302_time[4],2,16);
        OLED_ShowNum(58,2,ds1302_time[5],2,16);
void timeset()                //ʱ¼äÉèÖÃ
        if(keynum==2)
                adjust_bit++;
                adjust_bit%=6;
        if(keynum==3)
                ds1302_time[adjust_bit]++;
                if(ds1302_time[0]>99){ds1302_time[0]=0;}//Äê
                if(ds1302_time[1]>12){ds1302_time[1]=1;}//ÔÂ
                //ÈÕ
                if(ds1302_time[1]==1||ds1302_time[1]==3||ds1302_time[1]==5||ds1302_time[1]==7||ds1302_time[1]==8||ds1302_time[1]==10||ds1302_time[1]==12)
                        if(ds1302_time[2]>31){ds1302_time[2]=1;}
                else if(ds1302_time[1]==4|ds1302_time[1]==6||ds1302_time[1]==9||ds1302_time[1]==11)
                        if(ds1302_time[2]>30){ds1302_time[2]=1;}
                else if(ds1302_time[1]==2)
                        if(ds1302_time[0]%4==0)
                                if(ds1302_time[2]>29){ds1302_time[2]=1;}
                                if(ds1302_time[2]>28){ds1302_time[2]=1;}
                if(ds1302_time[3]>23){ds1302_time[3]=0;}
                if(ds1302_time[4]>59){ds1302_time[4]=0;}
                if(ds1302_time[5]>59){ds1302_time[5]=0;}
        if(keynum==4)
                ds1302_time[adjust_bit]--;
                if(ds1302_time[0]==0xff){ds1302_time[0]=99;}
                if(ds1302_time[1]<1){ds1302_time[1]=12;}
                        if(ds1302_time[2]<1){ds1302_time[2]=31;}
                        if(ds1302_time[2]>31){ds1302_time[2]=1;}//¼õ¼õÒ²ÒªÅжÏ
                        if(ds1302_time[2]<1){ds1302_time[2]=30;}
                                if(ds1302_time[2]<1){ds1302_time[2]=29;}
                                if(ds1302_time[2]<1){ds1302_time[2]=28;}
                if(ds1302_time[3]==0xff){ds1302_time[3]=23;}
                if(ds1302_time[4]==0xff){ds1302_time[4]=59;}
                if(ds1302_time[5]==0xff){ds1302_time[5]=59;}
        if(adjust_bit==0&&adjust_bit_flag==1){OLED_ShowString(18,0,"  ",16);}
        else{OLED_ShowNum(18,0,ds1302_time[0],2,16);}                            //¸üÐÂÏÔʾ
        if(adjust_bit==1&&adjust_bit_flag==1){OLED_ShowString(56,0,"  ",16);}
        else{OLED_ShowNum(56,0,ds1302_time[1],2,16);}
        if(adjust_bit==2&&adjust_bit_flag==1){OLED_ShowString(94,0,"  ",16);}
        else{OLED_ShowNum(94,0,ds1302_time[2],2,16);}
        if(adjust_bit==3&&adjust_bit_flag==1){OLED_ShowString(0,2,"  ",16);}
        else{OLED_ShowNum(0,2,ds1302_time[3],2,16);}
        if(adjust_bit==4&&adjust_bit_flag==1){OLED_ShowString(28,2,"  ",16);}
        else{OLED_ShowNum(28,2,ds1302_time[4],2,16);}
        if(adjust_bit==5&&adjust_bit_flag==1){OLED_ShowString(58,2,"  ",16);}
        else{OLED_ShowNum(58,2,ds1302_time[5],2,16);}
        Timer0_Init();
        OLED_Init();
        OLED_Clear();
        ds1302_init();
        ds1302_settime();
        OLED_ShowCHinese(36,0,0);
        OLED_ShowCHinese(75,0,1);
        OLED_ShowCHinese(110,0,2);
        OLED_ShowChar(18,2,':',16);
        OLED_ShowChar(47,2,':',16);
                keynum=key_return();
                if(keynum==1)
                        if(mode==0){mode=1;adjust_bit=0;}
                        else if(mode==1){mode=0;ds1302_settime();}//µ÷ÕûÍêÔÚд½øÈ¥¡£
                switch(mode)
                        case 0:{timeshow();break;}
                        case 1:{timeset();break;}
void Timer0_Routine() interrupt 1
        static unsigned int T0Count1,T0Count2;
    TL0 = 0x18;
        TH0 = 0xFC;
    T0Count1++;
    if(T0Count1>=500)
        T0Count1=0;
                adjust_bit_flag=!adjust_bit_flag;    //adjust_bit_flag^=0x01;
        T0Count2++;
        if(T0Count2>=20)
        T0Count2=0;
                keyloop();
屏幕截圖 2024-02-06 204232.png (45.77 KB, 下載次數(shù): 119)
基于51單片機(jī)的時(shí)間日期顯示(DS1302 OLED0.96 按鍵可調(diào) 定時(shí)器掃描按鍵).zip
87.71 KB, 下載次數(shù): 92, 下載積分: 黑幣 -5
程序
Desktop.zip
410.76 KB, 下載次數(shù): 53, 下載積分: 黑幣 -5
proteus仿真
作者: zsps    時(shí)間: 2024-2-12 19:33
支持樓主,使用ds3231好像會(huì)更好一點(diǎn)。
作者: STC莊偉    時(shí)間: 2024-7-15 16:17
現(xiàn)在直接用帶RTC的,還有星期的
一塊三 的 USB, STC8H2K32U-45MHz-LQFP32/TSSOP28/20,SOP16,
支持硬件USB 支持 仿真/下載, RTC 實(shí)時(shí)時(shí)鐘, 年/月/日/時(shí)/分/秒,星期
作者: LF1234    時(shí)間: 2024-12-9 17:18
這個(gè)資料非常好
