國產(chǎn)8通道24位ADC SGM58601(替代ADS1256)GD32單片機驅(qū)動程序調(diào)試
弓長張
2024-1-19 20:49
調(diào)試過程中遇到的問題:
最大的問題,使用SPI驅(qū)動時讀數(shù)為0 -1 或者其他很大的數(shù)(都是不對的數(shù)),經(jīng)過反復(fù)驗證后發(fā)現(xiàn)與SPI時鐘有關(guān),參考STM32 驅(qū)動ADS1256程序 硬件SPI 時鐘分頻為256,燒錄后驅(qū)動正常,修改分頻系數(shù)后,讀數(shù)異常。但是256分頻后 時鐘頻率約1.幾KHz 速度太慢。有反復(fù)調(diào)試了一會,發(fā)現(xiàn)SPI時鐘速度 ,ADC采樣頻率都可能會導(dǎo)致讀數(shù)錯誤,具體問題沒有細(xì)究。經(jīng)過調(diào)試后可以使用該程序驅(qū)動SGM58601。下面附上代碼,單片機為GD32E103。
#ifndef _SGM58601_H
#define _SGM58601_H
#include "gd32e10x.h"
#include "systick.h"
#include "spi.h"
#define SGM58601_DRDY_PIN GPIO_PIN_3
#define SGM58601_DRDY gpio_input_bit_get(GPIOA, SGM58601_DRDY_PIN)
//define commands
#define SGM58601_CMD_WAKEUP 0x00
#define SGM58601_CMD_RDATA 0x01
#define SGM58601_CMD_RDATAC 0x03
#define SGM58601_CMD_SDATAC 0x0f
#define SGM58601_CMD_RREG 0x10
#define SGM58601_CMD_WREG 0x50
#define SGM58601_CMD_SELFCAL 0xf0
#define SGM58601_CMD_SELFOCAL 0xf1
#define SGM58601_CMD_SELFGCAL 0xf2
#define SGM58601_CMD_SYSOCAL 0xf3
#define SGM58601_CMD_SYSGCAL 0xf4
#define SGM58601_CMD_SYNC 0xfc
#define SGM58601_CMD_STANDBY 0xfd
#define SGM58601_CMD_REST 0xfe
//define the SGM58601 register values
#define SGM58601_STATUS 0x00
#define SGM58601_MUX 0x01
#define SGM58601_ADCON 0x02
#define SGM58601_DRATE 0x03
#define SGM58601_IO 0x04
#define SGM58601_OFC0 0x05
#define SGM58601_OFC1 0x06
#define SGM58601_OFC2 0x07
#define SGM58601_FSC0 0x08
#define SGM58601_FSC1 0x09
#define SGM58601_FSC2 0x0A
//define multiplexer codes
#define SGM58601_MUXP_AIN0 0x00
#define SGM58601_MUXP_AIN1 0x10
#define SGM58601_MUXP_AIN2 0x20
#define SGM58601_MUXP_AIN3 0x30
#define SGM58601_MUXP_AIN4 0x40
#define SGM58601_MUXP_AIN5 0x50
#define SGM58601_MUXP_AIN6 0x60
#define SGM58601_MUXP_AIN7 0x70
#define SGM58601_MUXP_AINCOM 0x80
#define SGM58601_MUXN_AIN0 0x00
#define SGM58601_MUXN_AIN1 0x01
#define SGM58601_MUXN_AIN2 0x02
#define SGM58601_MUXN_AIN3 0x03
#define SGM58601_MUXN_AIN4 0x04
#define SGM58601_MUXN_AIN5 0x05
#define SGM58601_MUXN_AIN6 0x06
#define SGM58601_MUXN_AIN7 0x07
#define SGM58601_MUXN_AINCOM 0x08
//define gain codes
#define SGM58601_GAIN_1 0x00
#define SGM58601_GAIN_2 0x01
#define SGM58601_GAIN_4 0x02
#define SGM58601_GAIN_8 0x03
#define SGM58601_GAIN_16 0x04
#define SGM58601_GAIN_32 0x05
#define SGM58601_GAIN_64 0x06
//#define SGM58601_GAIN_64 0x07
//define drate codes
#define SGM58601_DRATE_30000SPS 0xF0
#define SGM58601_DRATE_15000SPS 0xE0
#define SGM58601_DRATE_7500SPS 0xD0
#define SGM58601_DRATE_3750SPS 0xC0
#define SGM58601_DRATE_2000SPS 0xB0
#define SGM58601_DRATE_1000SPS 0xA1
#define SGM58601_DRATE_500SPS 0x92
#define SGM58601_DRATE_100SPS 0x82
#define SGM58601_DRATE_60SPS 0x72
#define SGM58601_DRATE_50SPS 0x63
#define SGM58601_DRATE_30SPS 0x53
#define SGM58601_DRATE_25SPS 0x43
#define SGM58601_DRATE_15SPS 0x33
#define SGM58601_DRATE_10SPS 0x23
#define SGM58601_DRATE_5SPS 0x13
#define SGM58601_DRATE_2_5SPS 0x03
// define commands
//define gain codes
void SGM58601_Gpio_Init(void); //SGM58601 GPIO初始化
void SGM58601AWREG(unsigned char regaddr,unsigned char databyte); //SGM58601A 寫寄存器
void SGM58601BWREG(unsigned char regaddr,unsigned char databyte); //SGM58601B 寫寄存器
signed int SGM58601AReadData(unsigned char channel); //SGM58601 讀數(shù)據(jù)
signed int SGM58601BReadData(unsigned char channel); //SGM58601 讀數(shù)據(jù)
void SGM58601A_Init(void); //SGM58601A 單端采集初始化
void SGM58601B_Init(void); //SGM58601B 差分采集初始化
int SGM58601_Read_SingleData(unsigned char channel); //SGM58601A 單端ADC讀取
int SGM58601_Read_DiffData(void); //SGM58601B 差分ADC讀取
#endif
#include "SGM58601.H"
gpio_init(SGM58601_GPIO_RCU,GPIO_MODE_IN_FLOATING,GPIO_OSPEED_50MHZ, SGM58601_DRDY_PIN);
void SGM58601AWREG(unsigned char regaddr,unsigned char databyte) //A
SPI_CS1_ENABLE();
while(SGM58601_DRDY);//當(dāng)SGM58601_DRDY為低時才能寫寄存器
//向寄存器寫入數(shù)據(jù)地址
SPI0_ReadWriteByte(SGM58601_CMD_WREG | (regaddr & 0x0F));
//寫入數(shù)據(jù)的個數(shù)n-1
SPI0_ReadWriteByte(0x00);
//向regaddr地址指向的寄存器寫入數(shù)據(jù)databyte
SPI0_ReadWriteByte(databyte);
SPI_CS1_DISABLE();
void SGM58601BWREG(unsigned char regaddr,unsigned char databyte) //B
SPI_CS2_ENABLE();
SPI_CS2_DISABLE();
//初始化SGM58601 // 單端采集
void SGM58601A_Init(void) //A
//*************自校準(zhǔn)****************
// while(SGM58601_DRDY);
// SPI_CS1_ENABLE();
// SPI0_ReadWriteByte(SGM58601_CMD_SELFCAL);
// SPI_CS1_DISABLE();
SGM58601AWREG(SGM58601_STATUS,0x06); // 高位在前、使用緩沖
// SGM58601AWREG(SGM58601_STATUS,0x04); // 高位在前、不使用緩沖
// SGM58601AWREG(SGM58601_MUX,0x08); // 初始化端口A0為‘+’,AINCOM位‘-’
SGM58601AWREG(SGM58601_ADCON,SGM58601_GAIN_1); // 放大倍數(shù)1
SGM58601AWREG(SGM58601_DRATE,SGM58601_DRATE_7500SPS); // 數(shù)據(jù)10sps
SGM58601AWREG(SGM58601_IO,0x00);
//初始化SGM58601 // 差分采集
void SGM58601B_Init(void) //B
// SPI_CS2_ENABLE();
// SPI_CS2_DISABLE();
SGM58601BWREG(SGM58601_STATUS,0x06); // 高位在前、使用緩沖
// SGM58601BWREG(SGM58601_STATUS,0x04); // 高位在前、不使用緩沖
SGM58601BWREG(SGM58601_MUX,0x08); // 初始化端口A0為‘+’,AINCOM位‘-’
SGM58601BWREG(SGM58601_ADCON,SGM58601_GAIN_64); // 放大倍數(shù)1
SGM58601BWREG(SGM58601_DRATE,SGM58601_DRATE_2000SPS); // 數(shù)據(jù)10sps
SGM58601BWREG(SGM58601_IO,0x00);
//讀取單端AD值
signed int SGM58601AReadData(unsigned char channel) //A
unsigned int sum=0;
SGM58601AWREG(SGM58601_MUX,channel); //設(shè)置通道
SPI_CS1_ENABLE();
SPI0_ReadWriteByte(SGM58601_CMD_SYNC);
SPI0_ReadWriteByte(SGM58601_CMD_WAKEUP);
SPI0_ReadWriteByte(SGM58601_CMD_RDATA);
sum |= (SPI0_ReadWriteByte(0xff) << 16);
sum |= (SPI0_ReadWriteByte(0xff) << 8);
sum |= SPI0_ReadWriteByte(0xff);
SPI_CS1_DISABLE();
if (sum>0x7FFFFF) // if MSB=1,
sum -= 0x1000000; // do 2's complement
return sum;
signed int SGM58601BReadData(unsigned char channel) //B
unsigned int sum=0;
SGM58601BWREG(SGM58601_MUX,channel); //設(shè)置通道
SPI_CS2_ENABLE();
SPI_CS2_DISABLE();
return sum;
return SGM58601AReadData( (channel << 4) | SGM58601_MUXN_AINCOM);
return SGM58601BReadData( SGM58601_MUXP_AIN0 | SGM58601_MUXN_AIN1);
GD32_SGM58601.7z
2024-1-19 22:16 上傳
202.25 KB, 下載次數(shù): 12
人工置頂員
2024-1-20 15:06
頂一下
