DHT11溫濕度模塊 單片機程序不完整
lqkk
2023-10-22 21:31
DHT11溫濕度模塊 單片機程序不完整
資料代碼分享
#include "DHT11.h"
extern unsigned char temperature,humidity;
//選擇PA4作為 data線
void SET_PA4_OUTPUT(void)
//Gec_GPIO_Init(GPIOA, GPIO_Pin_4, GPIO_MODE_OUT_PP);
GPIO_InitTypeDef g;
RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOA, ENABLE);
g.GPIO_Pin = GPIO_Pin_4;
g.GPIO_Mode = GPIO_Mode_OUT;
g.GPIO_OType = GPIO_OType_PP;
g.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init( GPIOA, &g);
void SET_PA4_INPUT(void)
// Gec_GPIO_Init(GPIOA, GPIO_Pin_4, GPIO_MODE_IN_PULLUP);
GPIO_InitTypeDef g;
g.GPIO_Mode = GPIO_Mode_IN;
g.GPIO_PuPd = GPIO_PuPd_NOPULL;
//g.GPIO_OType = GPIO_OType_PP;
//g.GPIO_Speed = GPIO_Speed_50MHz;
static unsigned char Read_Byte(void)
SET_PA4_INPUT();
unsigned char i,ByteData=0;
for(i=0;i<8;i++)
ByteData <<= 1;//先左移一位,因為數(shù)據(jù)是高位先出
while(!(PAin(4)==0));//每個bit都是從50us的低電平開始
while(!(PAin(4)==1));//等待變?yōu)楦唠娖?br />
udelay(30);//延時30us
if(PAin(4) == 1)//說明該Bit位就是1
ByteData |= 1;//把最低位變?yōu)?
return ByteData;
Read_DHT11:向DHT11發(fā)送命令,讀取溫濕度數(shù)據(jù)
參數(shù):
無
返回值:
讀取成功返回1,失敗返回0
int Read_DHT11(void)
unsigned char ReadBuf[5];
/*主機發(fā)送開始信號*/
SET_PA4_OUTPUT();//設(shè)置為輸出模式
PAout(4) = 0;
udelay(20000);//至少18ms
/*主機拉高20~40us*/
PAout(4) = 1;
udelay(40);
/*等待DHT11回響應(yīng)信號*/
SET_PA4_INPUT();//設(shè)置為輸入模式
while(!(PAin(4)==0));//等待總線變?yōu)榈碗娖?響應(yīng)信號)
/*等待DHT11拉高80us,DHT11開始傳輸數(shù)據(jù)*/
/*數(shù)據(jù)總共有40bits,即5個字節(jié)*/
ReadBuf[0] = Read_Byte();
ReadBuf[1] = Read_Byte();
ReadBuf[2] = Read_Byte();
ReadBuf[3] = Read_Byte();
ReadBuf[4] = Read_Byte();
/*校驗*/
if((ReadBuf[0]+ReadBuf[1]+ReadBuf[2]+ReadBuf[3])%256 == ReadBuf[4])//校驗成功
humidity = ReadBuf[0];
temperature = ReadBuf[2];
return 1;
return 0;
(4.35 KB, 下載次數(shù): 11)
2023-10-22 22:20 上傳
下載:
DHT11.zip
(2 MB, 下載次數(shù): 0)
2023-10-22 21:29 上傳
