STM32單片機NFC門禁系統程序
小鋇愛學
2023-10-20 12:20
STM32單片機NFC門禁系統程序
/* RFID_RC522門禁系統 */
/* 接線: RC522模塊:RST接PB11;MISO接PB10; MOSI接PB1;SCK接PB0;SDA接PA7;
0.96寸OLED:scl接PB8,sda接PB9
有源蜂鳴器:I/O接PA3
180度舵機:信號線接PA1(5V電源驅動)
按鍵1:PB12; 按鍵2:PB14;按鍵3:PA9;按鍵4:PA12;
具體功能描述:
讀模式: 上電后默認為讀模式,按下2鍵后進入寫模式,按下3鍵進入刪模式
寫模式: 在寫模式下將靠近感應區即可寫成功,已錄入的不能重復錄入,在寫模式下按下1鍵進入尋模式,按下3鍵進入刪模式
刪模式: 在刪`模式下按下1鍵或2鍵選擇要刪除的,按下3鍵確認刪除,按下4鍵返回到讀模式。
#include "stm32f10x.h" // Device header
#include "RC522.H"
uint8_t UID[4],Temp[4];
uint8_t UI0[4]={0xFF,0xFF,0xFF,0xFF}; //0ID號
uint8_t UI1[4]={0xFF,0xFF,0xFF,0xFF}; //1ID號
uint8_t UI2[4]={0xFF,0xFF,0xFF,0xFF}; //2ID號
uint8_t UI3[4]={0xFF,0xFF,0xFF,0xFF}; //3ID號
//RC522端口定義
void PcdInit()
/* Enable the GPIO Clock */
RCC_APB2PeriphClockCmd(MF522_RST_CLK, ENABLE);
/* Configure the GPIO pin */
GPIO_InitStructure.GPIO_Pin = MF522_RST_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Init(MF522_RST_PORT, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(MF522_MISO_CLK, ENABLE);
GPIO_InitStructure.GPIO_Pin = MF522_MISO_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(MF522_MISO_PORT, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(MF522_MOSI_CLK, ENABLE);
GPIO_InitStructure.GPIO_Pin = MF522_MOSI_PIN;
GPIO_Init(MF522_MOSI_PORT, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(MF522_SCK_CLK, ENABLE);
GPIO_InitStructure.GPIO_Pin = MF522_SCK_PIN;
GPIO_Init(MF522_SCK_PORT, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(MF522_NSS_CLK, ENABLE);
GPIO_InitStructure.GPIO_Pin = MF522_NSS_PIN;
GPIO_Init(MF522_NSS_PORT, &GPIO_InitStructure);
///////////////////////以下為RC522驅動函數/////////////////////////
//功 能:尋
//參數說明: req_code[IN]:尋方式
// 0x52 = 尋感應區內所有符合14443A標準的
// 0x26 = 尋未進入休眠狀態的
// pTagType[OUT]:片類型代碼
// 0x4400 = Mifare_UltraLight
// 0x0400 = Mifare_One(S50)
// 0x0200 = Mifare_One(S70)
// 0x0800 = Mifare_Pro(X)
// 0x4403 = Mifare_DESFire
//返 回: 成功返回MI_OK
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
char status;
unsigned int unLen;
unsigned char ucComMF522Buf[MAXRLEN];
// unsigned char xTest ;
ClearBitMask(Status2Reg,0x08);
WriteRawRC(BitFramingReg,0x07);
// xTest = ReadRawRC(BitFramingReg);
// if(xTest == 0x07 )
// { LED_GREEN =0 ;}
// else {LED_GREEN =1 ;while(1){}}
SetBitMask(TxControlReg,0x03);
ucComMF522Buf[0] = req_code;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
// if(status == MI_OK )
// else {LED_GREEN =1 ;}
if ((status == MI_OK) && (unLen == 0x10))
*pTagType = ucComMF522Buf[0];
*(pTagType+1) = ucComMF522Buf[1];
{ status = MI_ERR; }
return status;
//功 能:防沖撞
//參數說明: pSnr[OUT]:片序列號,4字節
//返 回: 成功返回MI_OK
char PcdAnticoll(unsigned char *pSnr)
char status;
unsigned char i,snr_check=0;
unsigned int unLen;
WriteRawRC(BitFramingReg,0x00);
ClearBitMask(CollReg,0x80);
ucComMF522Buf[0] = PICC_ANTICOLL1;
ucComMF522Buf[1] = 0x20;
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
if (status == MI_OK)
for (i=0; i<4; i++)
*(pSnr+i) = ucComMF522Buf[ i];
snr_check ^= ucComMF522Buf[ i];
if (snr_check != ucComMF522Buf[ i])
SetBitMask(CollReg,0x80);
return status;
//功 能:選定片
//參數說明: pSnr[IN]:片序列號,4字節
//返 回: 成功返回MI_OK
char PcdSelect(unsigned char *pSnr)
char status;
unsigned char i;
unsigned int unLen;
ucComMF522Buf[1] = 0x70;
ucComMF522Buf[6] = 0;
for (i=0; i<4; i++)
ucComMF522Buf[i+2] = *(pSnr+i);
ucComMF522Buf[6] ^= *(pSnr+i);
CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x18))
{ status = MI_OK; }
return status;
//功 能:驗證片密碼
//參數說明: auth_mode[IN]: 密碼驗證模式
// 0x60 = 驗證A密鑰
// 0x61 = 驗證B密鑰
// addr[IN]:塊地址
// pKey[IN]:密碼
// pSnr[IN]:片序列號,4字節
//返 回: 成功返回MI_OK
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
char status;
unsigned int unLen;
unsigned char i,ucComMF522Buf[MAXRLEN];
ucComMF522Buf[0] = auth_mode;
ucComMF522Buf[1] = addr;
for (i=0; i<6; i++)
{ ucComMF522Buf[i+2] = *(pKey+i); }
for (i=0; i<6; i++)
{ ucComMF522Buf[i+8] = *(pSnr+i); }
// memcpy(&ucComMF522Buf[2], pKey, 6);
// memcpy(&ucComMF522Buf[8], pSnr, 4);
status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
return status;
//功 能:讀取M1一塊數據
//參數說明: addr[IN]:塊地址
// pData[OUT]:讀出的數據,16字節
//返 回: 成功返回MI_OK
char PcdRead(unsigned char addr,unsigned char *pData)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_READ;
CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
if ((status == MI_OK) && (unLen == 0x90))
// { memcpy(pData, ucComMF522Buf, 16); }
for (i=0; i<16; i++)
{ *(pData+i) = ucComMF522Buf[ i]; }
return status;
//功 能:寫數據到M1一塊
// pData[IN]:寫入的數據,16字節
//返 回: 成功返回MI_OK
char PcdWrite(unsigned char addr,unsigned char *pData)
char status;
unsigned int unLen;
ucComMF522Buf[0] = PICC_WRITE;
if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
//memcpy(ucComMF522Buf, pData, 16);
{ ucComMF522Buf[ i] = *(pData+i); }
CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
return status;
//功 能:命令片進入休眠狀態
//返 回: 成功返回MI_OK
char PcdHalt(void)
unsigned int unLen;
ucComMF522Buf[0] = PICC_HALT;
ucComMF522Buf[1] = 0;
return MI_OK;
//用MF522計算CRC16函數
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
unsigned char i,n;
ClearBitMask(DivIrqReg,0x04);
WriteRawRC(CommandReg,PCD_IDLE);
SetBitMask(FIFOLevelReg,0x80);
for (i=0; i<len; i++)
{ WriteRawRC(FIFODataReg, *(pIndata+i)); }
WriteRawRC(CommandReg, PCD_CALCCRC);
i = 0xFF;
do
n = ReadRawRC(DivIrqReg);
i--;
while ((i!=0) && !(n&0x04));
pOutData[0] = ReadRawRC(CRCResultRegL);
pOutData[1] = ReadRawRC(CRCResultRegM);
//功 能:復位RC522
//返 回: 成功返回MI_OK
char PcdReset(void)
RST_H;
delay_10ms(1);
RST_L;
delay_10ms(1);
RST_H;
delay_10ms(10);
if(ReadRawRC(0x02) == 0x80)
WriteRawRC(CommandReg,PCD_RESETPHASE);
WriteRawRC(ModeReg,0x3D); //和Mifare通訊,CRC初始值0x6363
WriteRawRC(TReloadRegL,30);
WriteRawRC(TReloadRegH,0);
WriteRawRC(TModeReg,0x8D);
WriteRawRC(TPrescalerReg,0x3E);
WriteRawRC(TxAutoReg,0x40);
return MI_OK;
//設置RC632的工作方式
char M500PcdConfigISOType(unsigned char type)
if (type == 'A') //ISO14443_A
/* WriteRawRC(CommandReg,0x20); //as default
WriteRawRC(ComIEnReg,0x80); //as default
WriteRawRC(DivlEnReg,0x0); //as default
WriteRawRC(ComIrqReg,0x04); //as default
WriteRawRC(DivIrqReg,0x0); //as default
WriteRawRC(Status2Reg,0x0);//80 //trun off temperature sensor
WriteRawRC(WaterLevelReg,0x08); //as default
WriteRawRC(ControlReg,0x20); //as default
WriteRawRC(CollReg,0x80); //as default
WriteRawRC(ModeReg,0x3D);//3F
/* WriteRawRC(TxModeReg,0x0); //as default???
WriteRawRC(RxModeReg,0x0); //as default???
WriteRawRC(TxControlReg,0x80); //as default???
WriteRawRC(TxSelReg,0x10); //as default???
WriteRawRC(RxSelReg,0x86);//84
// WriteRawRC(RxThresholdReg,0x84);//as default
// WriteRawRC(DemodReg,0x4D); //as default
// WriteRawRC(ModWidthReg,0x13);//26
WriteRawRC(RFCfgReg,0x7F); //4F
/* WriteRawRC(GsNReg,0x88); //as default???
WriteRawRC(CWGsCfgReg,0x20); //as default???
WriteRawRC(ModGsCfgReg,0x20); //as default???
WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
// PcdSetTmo(106);
delay_10ms(1);
PcdAntennaOn();
else{ return (char)-1; }
return MI_OK;
//功 能:讀RC632寄存器
//參數說明:Address[IN]:寄存器地址
//返 回:讀出的值
unsigned char ReadRawRC(unsigned char Address)
unsigned char i, ucAddr;
unsigned char ucResult=0;
NSS_L;
ucAddr = ((Address<<1)&0x7E)|0x80;
for(i=8;i>0;i--)
SCK_L;
if(ucAddr&0x80)
MOSI_H;
MOSI_L;
SCK_H;
ucAddr <<= 1;
for(i=8;i>0;i--)
SCK_L;
ucResult <<= 1;
SCK_H;
if(READ_MISO == 1)
ucResult |= 1;
NSS_H;
SCK_H;
return ucResult;
//功 能:寫RC632寄存器
// value[IN]:寫入的值
void WriteRawRC(unsigned char Address, unsigned char value)
SCK_L;
NSS_L;
ucAddr = ((Address<<1)&0x7E);
for(i=8;i>0;i--)
if(ucAddr&0x80)
MOSI_H;
MOSI_L;
SCK_H;
ucAddr <<= 1;
SCK_L;
for(i=8;i>0;i--)
if(value&0x80)
MOSI_H;
MOSI_L;
SCK_H;
value <<= 1;
SCK_L;
NSS_H;
SCK_H;
//功 能:置RC522寄存器位
//參數說明:reg[IN]:寄存器地址
// mask[IN]:置位值
void SetBitMask(unsigned char reg,unsigned char mask)
char tmp = 0x0;
tmp = ReadRawRC(reg);
WriteRawRC(reg,tmp | mask); // set bit mask
//功 能:清RC522寄存器位
// mask[IN]:清位值
void ClearBitMask(unsigned char reg,unsigned char mask)
char tmp = 0x0;
WriteRawRC(reg, tmp & ~mask); // clear bit mask
//功 能:通過RC522和ISO14443通訊
//參數說明:Command[IN]:RC522命令字
// pInData[IN]:通過RC522發送到片的數據
// InLenByte[IN]:發送數據的字節長度
// pOutData[OUT]:接收到的片返回數據
// *pOutLenBit[OUT]:返回數據的位長度
char PcdComMF522(unsigned char Command,
unsigned char *pInData,
unsigned char InLenByte,
unsigned char *pOutData,
unsigned int *pOutLenBit)
char status = MI_ERR;
unsigned char irqEn = 0x00;
unsigned char waitFor = 0x00;
unsigned char lastBits;
unsigned char n;
unsigned int i;
switch (Command)
case PCD_AUTHENT:
irqEn = 0x12;
waitFor = 0x10;
break;
case PCD_TRANSCEIVE:
irqEn = 0x77;
waitFor = 0x30;
break;
default:
break;
WriteRawRC(ComIEnReg,irqEn|0x80);
ClearBitMask(ComIrqReg,0x80);
for (i=0; i<InLenByte; i++)
{ WriteRawRC(FIFODataReg, pInData[ i]); }
WriteRawRC(CommandReg, Command);
if (Command == PCD_TRANSCEIVE)
{ SetBitMask(BitFramingReg,0x80); }
// i = 600;//根據時鐘頻率調整,操作M1最大等待時間25ms
i = 2000;
do
n = ReadRawRC(ComIrqReg);
i--;
while ((i!=0) && !(n&0x01) && !(n&waitFor));
ClearBitMask(BitFramingReg,0x80);
if (i!=0)
if(!(ReadRawRC(ErrorReg)&0x1B))
status = MI_OK;
if (n & irqEn & 0x01)
{ status = MI_NOTAGERR; }
n = ReadRawRC(FIFOLevelReg);
lastBits = ReadRawRC(ControlReg) & 0x07;
if (lastBits)
{ *pOutLenBit = (n-1)*8 + lastBits; }
{ *pOutLenBit = n*8; }
if (n == 0)
{ n = 1; }
if (n > MAXRLEN)
{ n = MAXRLEN; }
for (i=0; i<n; i++)
{ pOutData[ i] = ReadRawRC(FIFODataReg); }
SetBitMask(ControlReg,0x80); // stop timer now
return status;
//開啟天線
//每次啟動或關閉天險發射之間應至少有1ms的間隔
void PcdAntennaOn()
unsigned char i;
i = ReadRawRC(TxControlReg);
if (!(i & 0x03))
SetBitMask(TxControlReg, 0x03);
//關閉天線
void PcdAntennaOff()
ClearBitMask(TxControlReg, 0x03);
//等待離開
void WaitCardOff(void)
char status;
unsigned char TagType[2];
status = PcdRequest(REQ_ALL, TagType);
if(status)
if(status)
if(status)
return;
delay_10ms(10);
// Delay 10ms
void delay_10ms(unsigned int _10ms)
unsigned int i, j;
for(i=0; i<_10ms; i++)
for(j=0; j<60000; j++);
///////////////////////以上為RC522驅動函數/////////////////////////
//RFID模塊初始化
void RFID_Init(void)
PcdInit(); //RC522端口定義
PcdReset(); //復位RC522
PcdAntennaOff(); //關天線
PcdAntennaOn(); //開天線
M500PcdConfigISOType('A');
//獲取編號函數,返回編號1-3,非系統錄入返回0,沒有識別到返回5或6
uint8_t Rc522Test(void)
uint8_t cardno;
if (PcdRequest(REQ_ALL, Temp) == MI_OK)//尋
if (PcdAnticoll(UID) == MI_OK)//防沖撞
cardno=0;
if(UID[0]==UI0[0]&&UID[1]==UI0[1]&&UID[2]==UI0[2]&&UID[3]==UI0[3])
cardno=1;
else if(UID[0]==UI1[0]&&UID[1]==UI1[1]&&UID[2]==UI1[2]&&UID[3]==UI1[3])
cardno=2;
else if(UID[0]==UI2[0]&&UID[1]==UI2[1]&&UID[2]==UI2[2]&&UID[3]==UI2[3])
cardno=3;
else if(UID[0]==UI3[0]&&UID[1]==UI3[1]&&UID[2]==UI3[2]&&UID[3]==UI3[3])
cardno=4;
else cardno = 0;
else cardno = 5;
else cardno = 6;
return cardno;
原理圖: 無
仿真: 無
代碼:
NFC門禁系統.zip
(332.47 KB, 下載次數: 19)
2023-10-20 12:19 上傳
