標(biāo)題: 關(guān)于stm32單片機(jī)定時(shí)器1編碼器模式的問題 [打印本頁(yè)]
作者: 1106495953    時(shí)間: 2023-10-13 11:58
按照網(wǎng)上例程配置的編碼器,但只在有計(jì)數(shù),另一個(gè)方向計(jì)數(shù)一直為0,例程如下,求高人指點(diǎn)。
void TIM1_Initbm()
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_ICInitTypeDef TIM_ICInitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11|GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
    // TIM_OCInitTypeDef  TIM_OCInitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    // RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//
    TIM_DeInit(TIM1);
    TIM_TimeBaseStructure.TIM_Period = 0xffff; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值     80K
    TIM_TimeBaseStructure.TIM_Prescaler =1-1; //設(shè)置用來作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  不分頻
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
    TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
    TIM_EncoderInterfaceConfig(TIM1, TIM_EncoderMode_TI12, TIM_ICPolarity_Falling, TIM_ICPolarity_Falling);//使用編碼器模式3
    TIM_ICStructInit(&TIM_ICInitStructure);
    // TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
    // TIM_ICInitStructure.TIM_Channel = TIM_Channel_1 | TIM_Channel_2;
    TIM_ICInitStructure.TIM_ICFilter = 10;  //設(shè)置濾波器長(zhǎng)度
    TIM_ICInit(TIM1, &TIM_ICInitStructure);
    TIM_SetCounter(TIM1,0);
    NVIC_InitStructure.NVIC_IRQChannel=TIM1_UP_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x00;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x06;
    NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE );
    TIM_Cmd(TIM1, ENABLE);  //使能TIM1
void TIM1_UP_IRQHandler(void)
    if (TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET)//檢查指定的TIM中斷發(fā)生與否:TIM 中斷源
        TIM_ClearITPendingBit(TIM1, TIM_IT_Update);//清除TIMx的中斷待處理位:TIM 中斷源
        TIM_SetCounter(TIM1, 0);
int16_t Encoder_Get(void)
    int16_t Temp;
    Temp = TIM_GetCounter(TIM1);    // 這里TIM_GetCounter返回一個(gè)uint16_t類型的值,利用補(bǔ)碼很方便地將正數(shù)變?yōu)樨?fù)數(shù),例如65535變?yōu)?1
    // if(Temp != 0){
    //  CARD_MSx5 =1;
    return Temp;
作者: 1106495953    時(shí)間: 2023-10-13 11:59
int main(void)
        delay_init();                     //延時(shí)函數(shù)初始化
        smdGgpio_int_();
        smdEgpio_int_();
        smdFgpio_int_();
        smdDgpio_int_();
        smdCgpio_int_();
        smdBgpio_int_();
        smdAgpio_int_();
        uart_init(9600);
        // MYDMA_Config_TX(DMA1_Channel4,(u32)&USART1->DR,(u32)TXBuff,TX_MAX_LEN);
        // USART_DMACmd(USART1,USART_DMAReq_Tx|USART_DMAReq_Rx,ENABLE);
        // MYDMA_Config_RX(DMA1_Channel5,(u32)&USART1->DR,(u32)USART_RX_BUF,RX_MAX_LEN);
        // MYDMA_Enable_RX(DMA1_Channel5);
        LED_Init();
        GD_Init();
        KEY_Init();
        // EXTIX_Init();
        Adc_Init();
        SMDA_VALUE.PWM_V =0;SMDB_VALUE.PWM_V =0;SMDC_VALUE.PWM_V =0;
        SMDD_VALUE.PWM_V =0;SMDE_VALUE.PWM_V =0;SMDF_VALUE.PWM_V =0;SMDG_VALUE.PWM_V =0;
        // SMDA_VALUE.PWM_CNT =50000;SMDB_VALUE.PWM_CNT =50000;SMDC_VALUE.PWM_CNT =50000;SMDD_VALUE.PWM_CNT =50000;
        // SMDE_VALUE.PWM_CNT =50000;SMDF_VALUE.PWM_CNT =50000;SMDG_VALUE.PWM_CNT =50000;
        // TIM3_Int_Init(10-1,72-1);
        // TIM2_Int_Init(500-1,7200-1);
        // TIM4_Int_Init(500-1,7200-1);
        TIM1_Initbm();
        // TIM1_Init(499,7200-1);
        // star_clamp_rest();
        // smd_AG_rest(1,1);
        // SMD_Coturl(SMDD,STAR_SMDOE,OPEN_PWM,FORE_SMDDDIR,0);//D電機(jī)開始送牌
        // SMD_Coturl(SMDC,STAR_SMDOE,OPEN_PWM,FORE_SMDCDIR,0);//C電機(jī)開始送牌
        // get_rand();
        // open_check();
        printf("step:%d\r\n",ex);
                ex =Encoder_Get();
                LED1 =!LED1;
                // Wait_StarCard();
                // star_Card();
                // send_Card();
                delay_ms(5000);
作者: Hephaestus    時(shí)間: 2023-10-13 20:20
STM32的編碼器模式太糙了,但凡有這類應(yīng)用我都是直接換LPC17xx,里面的QEI太好用了。
