標題: 3路紡織斷線報警器電路設計程序分享 附件有原理圖和程序打包好的源碼 [打印本頁]
作者: zhangxinchun    時間: 2023-8-31 13:10
【聲明】此程序僅用于學習與參考,引用請注明版權和作者信息!
#include<STC15W408AS.h>
#include<math.h>                  //計算小數點的頭文件
#include <intrins.h>          //用nop函數延時的頭文件
#define uchar unsigned char//宏定義無符號字符型
#define uint unsigned int  //宏定義無符號整型
/*數據類型定義*/
typedef signed char        int8;
typedef signed int        int16;
typedef signed long        int32;
typedef unsigned char        uint8;
typedef unsigned int        uint16;
typedef unsigned long        uint32;
#define ENABLE_IAP 0x83 //系統工作時鐘<12MHz 時,對IAP_CONTR 寄存器設置此值
#define CMD_IDLE 0
#define CMD_READ 1
#define CMD_PROGRAM 2
#define CMD_ERASE 3
#define ENABLE_IAP 0x83//SYSCLK<12MH
#define IAP_ADDRESS 0x0000        //存儲地址
#define FOSC 11059200L
#define BAUD 9600
uint8 sendBuf[10];          //發送緩沖區
uint8 receBuf[10];    //接收緩沖區
sbit IN1 =  P1^0;                        /*單片機1.0引腳檢測IN1是否動作*/
sbit IN2 =  P1^1;                        /*單片機1.1引腳檢測IN2是否動作*/
sbit IN3 =  P1^2;                        /*單片機1.2引腳檢測IN4是否動作*/
sbit IN4 =  P1^3;                        /*單片機1.3引腳檢測IN2是否動作*/
sbit OUT1 = P3^5;                    /*單片機3.5引腳控制繼電器OUT1*/
sbit OUT2 = P3^4;                    /*單片機3.4引腳控制繼電器OUT2*/
sbit OUT3 = P3^3;                    /*單片機3.3引腳控制繼電器OUT3*/
sbit OUT4 = P3^2;                    /*單片機3.2引腳控制繼電器OUT4*/
sbit S1 = P5^4;                    /*單片機按鍵S1*/
sbit S2 = P5^5;                    /*單片機按鍵S2*/
sbit COM1 = P3^6;                    /*數碼管顯示位個位*/
sbit COM2 = P3^7;                    /*數碼管顯示位十位*/
//code uchar seg7code[16]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71}; //顯示段碼
code uchar seg7code[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //共陰數碼管顯示段碼
uchar date;
bit  bz1=0;
bit  bz2=0;
bit  bz3=0;
bit  bz4=0;
bit  bz5=0;
bit  bz6=0;
bit sjbz1=0;
bit sjbz2=0;
bit write=0;
uint sec1=0;
uint sec2=0;
uint sec3=0;
uint sec4=0;
uint tcnt=0;
uint sj1;
uint sj2;
uchar A1,B1,C1,D1;
uchar r;
bit flag_zx=0;
bit bjbz1=0;
bit bjbz2=0;
bit bjbz3=0;
bit bjbz4=0;
        定義 ISP/IAP/EEPROM 命令
void IapIdle();//禁用 ISP/IAP/EEPROM functionmake 單片機 在 一 安全 狀態
uint8 IapReadByte(uint16 addr);//讀數據
void IapProgramByte(uint16 addr, uint8 dat);//寫數據
void IapEraseSector(uint16 addr);//擦除數據
        延時函數
void delay(uchar dat)//延時程序
uchar m,n,s;
for(m=dat;m>0;m--)
for(n=2;n>0;n--)
for(s=248;s>0;s--);
/****************發送函數*********************/
void senduart1()
SBUF='R';while(!TI);TI=0;
SBUF='E';while(!TI);TI=0;
SBUF='A';while(!TI);TI=0;
SBUF='D';while(!TI);TI=0;
        定時中斷服務函數
void t0(void) interrupt 1 using 0 //定時中斷服務函數
tcnt++; //每過250ust tcnt 加一
if(tcnt==400) //計滿400 次(1/10 秒)時
tcnt=0; //重新再計
if(bjbz1==1){sec1++;if(sec1>=date){sec1=0;OUT1=0;bjbz1=0;}}
if(bjbz2==1){sec2++;if(sec2>=date){sec2=0;OUT2=0;bjbz2=0;}}
if(bjbz3==1){sec3++;if(sec3>=date){sec3=0;OUT3=0;bjbz3=0;}}
//if(bjbz4==1){sec4++;if(sec4>=date){sec4=0;OUT4=0;bjbz4=0;}}
        按鍵函數
void key()
if((S1==0)&&(bz1==0)){delay(1);if(S1==0){bz1=1;if(date<100){date++;}}}if((S1==1)&&(bz1==1)){delay(1);if(S1==1){write=1;bz1=0;}}
if((S2==0)&&(bz2==0)){delay(1);if(S2==0){bz2=1;if(date>=1){date--;}}} if((S2==1)&&(bz2==1)){delay(1);if(S2==1){write=1;bz2=0;}}
//if((IN4==0)&&(bz6==0)){delay(1);if(IN4==0){bz6=1;OUT1=1;OUT2=1;OUT3=1;OUT4=1;bjbz1=0;sec1=0;bjbz2=0;sec2=0;bjbz3=0;sec3=0;}}
//if((IN4==1)&&(bz6==1)){delay(1);if(IN4==1){bz6=0;}}
if(IN1==0){bjbz1=1;} else {OUT1=1;sec1=0;}
if(IN2==0){bjbz2=1;} else {OUT2=1;sec2=0;}
if(IN3==0){bjbz3=1;} else {OUT3=1;sec3=0;}
if((OUT1==0)||(OUT2==0)||(OUT3==0)){delay(1);if((OUT1==0)||(OUT2==0)||(OUT3==0)){OUT4=0;}} else {OUT4=1;}
        顯示函數
void xianshi()
A1=date/10;
B1=date%10;
COM1=1;COM2=1;P2=seg7code[A1];COM1=0;COM2=1;delay(1);//十位顯示
COM1=1;COM2=1;P2=seg7code[B1];COM1=1;COM2=0;delay(1);//個位顯示
/*****************清空發送緩沖區*************************/
void clear_receBuf()
uchar i;
for(i=0;i<5;i++)
receBuf=0;
        主函數
P2M0=0Xff;P2M1=0X00;
P5M0=0X00;P5M1=0X00;
SCON = 0x50;
T2L = (65536 - (FOSC/4/BAUD));
T2H = (65536 - (FOSC/4/BAUD))>>8;
AUXR = 0x14;
AUXR |= 0x01;
ES = 1;
EA = 1;
date= IapReadByte(0x01);//讀取存儲的值
if(date>=100){date=2;write=1;}
TMOD=0x02; //定時器工作在方式2
TH0=0x06; //對TH0 TL0 賦值
TL0=0x06;
TR0=1; //開始定時
ET0=1;
EA=1;
sec1=0;sec2=0;sec3=0;sec4=0;
COM1=1;COM2=1;
key();//調用按鍵函數
xianshi();//調用顯示函數
if(write==1)  //存儲數據
write=0;
IapEraseSector(0);  //擦除扇區
IapProgramByte(0x01,date);//寫入新的地址
        串口中斷函數
void Uart() interrupt 4 using 1
if (RI)
RI=0; //接收標志清零
receBuf[r++&0x0F]=SBUF;     //把接受的數據存儲到BUT數組中
if(receBuf[0]!=0xaa){r=0;}
if(r>=5)
{        r=0;
flag_zx=1;
if(flag_zx==1)
flag_zx=0;
//0         1     2      3     4
//起始位   千位  百位   十位  個位
if(receBuf[0]==0xaa)          //如果開始位和結束位,還有地址都正確,進行下一步判斷
A1=receBuf[1];
B1=receBuf[2];
C1=receBuf[3];
D1=receBuf[4];
write=1;
clear_receBuf();
        結束
void IapIdle(){//禁用 ISP/IAP/EEPROM functionmake 單片機 在 一 安全 狀態
IAP_CONTR = 0;           //
IAP_CMD = 0;           //
IAP_TRIG = 0;           //
IAP_ADDRH = 0x80;  //
IAP_ADDRL = 0;           //
uint8 IapReadByte(uint16 addr){//讀數據
uint8 dat;
IAP_CONTR = ENABLE_IAP;
IAP_CMD = CMD_READ;
IAP_ADDRL = addr;
IAP_ADDRH = addr >> 8;
IAP_TRIG = 0x5A;
IAP_TRIG = 0xA5;
_nop_();
dat = IAP_DATA;
IapIdle();
return dat;
void IapProgramByte(uint16 addr, uint8 dat){//寫數據
IAP_CMD = CMD_PROGRAM;
IAP_ADDRL = addr;
IAP_DATA = dat;
IAP_TRIG = 0x5A;
IAP_TRIG = 0xA5;
_nop_();
IapIdle();
void IapEraseSector(uint16 addr){//擦除數據
IAP_CMD = CMD_ERASE;
IAP_ADDRL = addr;
IAP_TRIG = 0x5A;
IAP_TRIG = 0xA5;
_nop_();
IapIdle();
        結束
GYJ-0095-B_四路輸入輸出繼電器帶數碼管顯示.pdf
633.29 KB, 下載次數: 6, 下載積分: 黑幣 -5
GYJ-0095-B_紡織斷線報警器配套程序.zip
1.34 KB, 下載次數: 7, 下載積分: 黑幣 -5
