STH30系列官方示例程序 STM8單片機
zjwhsm
2023-7-23 09:10
正在嘗試用STM08寫一個溫濕度的代碼,從官網下的,希望對大家有所幫助。
#include "system.h"
#include "sht3x.h"
//-- Static function prototypes -----------------------------------------------
static void EvalBoardPower_Init(void);
static void Led_Init(void);
static void UserButton_Init(void);
static void LedBlueOn(void);
static void LedBlueOff(void);
static void LedGreenOn(void);
static void LedGreenOff(void);
static u8t ReadUserButton(void);
int main(void)
etError error; // error code
u32t serialNumber;// serial number
regStatus status; // sensor status
ft temperature; // temperature [癈]
ft humidity; // relative humidity [%RH]
bt heater; // heater, false: off, true: on
SystemInit();
Led_Init();
UserButton_Init();
EvalBoardPower_Init();
SHT3X_Init(0x45); // Address: 0x44 = Sensor on EvalBoard connector
// 0x45 = Sensor on EvalBoard
// wait 50ms after power on
DelayMicroSeconds(50000);
error = SHT3x_ReadSerialNumber(&serialNumber);
if(error != NO_ERROR){} // do error handling here
// demonstrate a single shot measurement with clock-stretching
error = SHT3X_GetTempAndHumi(&temperature, &humidity, REPEATAB_HIGH, MODE_CLKSTRETCH, 50);
// demonstrate a single shot measurement with polling and 50ms timeout
error = SHT3X_GetTempAndHumi(&temperature, &humidity, REPEATAB_HIGH, MODE_POLLING, 50);
// loop forever
error = NO_ERROR;
// loop while no error
while(error == NO_ERROR)
// read status register
error |= SHT3X_ReadStatus(&status.u16);
if(error != NO_ERROR) break;
// check if the reset bit is set after a reset or power-up
if(status.bit.ResetDetected)
//override default temperature and humidity alert limits (red LED)
error = SHT3X_SetAlertLimits( 70.0f, 50.0f, // high set: RH [%], T [癈]
68.0f, 48.0f, // high clear: RH [%], T [癈]
32.0f, -2.0f, // low clear: RH [%], T [癈]
30.0f, -4.0f); // low set: RH [%], T [癈]
// clear reset and alert flags
error = SHT3X_ClearAllAlertFlags();
//start periodic measurement, with high repeatability and 1 measurements per second
error = SHT3X_StartPeriodicMeasurment(REPEATAB_HIGH, FREQUENCY_1HZ);
//switch green LED on
LedGreenOn();
// read measurment buffer
error = SHT3X_ReadMeasurementBuffer(&temperature, &humidity);
if(error == NO_ERROR)
// flash blue LED to signalise new temperature and humidity values
LedBlueOn();
DelayMicroSeconds(10000);
LedBlueOff();
else if (error == ACK_ERROR)
// there were no new values in the buffer -> ignore this error
error = NO_ERROR;
else break;
// read heater status
heater = status.bit.HeaterStatus ? TRUE : FALSE;
// if the user button is not pressed ...
if(ReadUserButton() == 0)
// ... and the heater is on
if(heater)
// switch off the sensor internal heater
error |= SHT3X_DisableHeater();
// if the user button is pressed ...
// ... and the heater is off
if(!heater)
// switch on the sensor internal heater
error |= SHT3X_EnableHeater();
// wait 100ms
DelayMicroSeconds(100000);
// in case of an error ...
// ... switch green and blue LED off
LedGreenOff();
LedBlueOff();
// ... try first a soft reset ...
error = SHT3X_SoftReset();
// ... if the soft reset fails, do a hard reset
SHT3X_HardReset();
// flash green LED to signalise an error
LedGreenOn();
LedGreenOff();
static void EvalBoardPower_Init(void) /* -- adapt this code for your platform -- */
RCC->APB2ENR |= 0x00000008; // I/O port B clock enabled
GPIOB->CRH &= 0x0FFF0FFF; // set push-pull output for Vdd & GND pins
GPIOB->CRH |= 0x10001000; //
GPIOB->BSRR = 0x08008000; // set Vdd to High, set GND to Low
static void Led_Init(void) /* -- adapt this code for your platform -- */
RCC->APB2ENR |= 0x00000010; // I/O port C clock enabled
GPIOC->CRH &= 0xFFFFFF00; // set general purpose output mode for LEDs
GPIOC->CRH |= 0x00000011; //
GPIOC->BSRR = 0x03000000; // LEDs off
static void UserButton_Init(void) /* -- adapt this code for your platform -- */
RCC->APB2ENR |= 0x00000004; // I/O port A clock enabled
GPIOA->CRH &= 0xFFFFFFF0; // set general purpose input mode for User Button
GPIOA->CRH |= 0x00000004; //
static void LedBlueOn(void) /* -- adapt this code for your platform -- */
GPIOC->BSRR = 0x00000100;
static void LedBlueOff(void) /* -- adapt this code for your platform -- */
GPIOC->BSRR = 0x01000000;
static void LedGreenOn(void) /* -- adapt this code for your platform -- */
GPIOC->BSRR = 0x00000200;
static void LedGreenOff(void) /* -- adapt this code for your platform -- */
GPIOC->BSRR = 0x02000000;
static u8t ReadUserButton(void) /* -- adapt this code for your platform -- */
return (GPIOA->IDR & 0x00000001);
代碼下載:
Sensirion_Humidity_Sensors_Software_SHT3x_Sample_Code.zip
(410.11 KB, 下載次數: 5)
2023-7-23 09:08 上傳
