STC12C單片機(jī) 雙串口通訊9600波特率完整實(shí)現(xiàn)程序
[打印本頁(yè)]
watsonbu
時(shí)間:
2023-2-19 15:26
名稱:STC12C5A60S2雙串口通信(已經(jīng)成功測(cè)試)
編寫:WatsonBu
日期:2022.01
修改:無(wú)
內(nèi)容:9600波特率 雙串口收發(fā)
接線:串口1 發(fā)送P3.1,接收P3.0
串口2 發(fā)送P1.3,接收P1.2
#include "stc12c5a60s2.h"
#include <stdio.h>
#include <stdarg.h>
#include <intrins.h>
#include <string.h>
#define S2RI 0x01 //串口2接收中斷中斷請(qǐng)求標(biāo)志位
#define S2TI 0x02 //串口2發(fā)送中斷請(qǐng)求標(biāo)志位
unsigned char flag1,flag2,temp2;
unsigned char uart2Receive[100];
unsigned char uart1Receive[100];
unsigned int point1=0,point2=0;
unsigned char i;
uchar RecDate[9]={0}; //串口接收 數(shù)據(jù)
uchar recnum2=0; //串口接收長(zhǎng)度
bit recfinish=0; //串口接收完成
uchar flag=0;
sbit TEST_OK = P0^1;
sbit TEST_NG = P2^2;
sbit V5_off = P2^3;
函數(shù)聲明
void UART_1SendOneByte(unsigned char c);
void UART_2SendOneByte(unsigned char c);
void uart1SendStr(unsigned char *s);
void uart2SendStr(unsigned char *s);
void send_char_com(uchar ch) //串口發(fā)送字節(jié)
SBUF=ch;
while(TI==0);
TI=0;
雙串口初始化
void InitUART (void)
SCON = 0x50; // SCON: 模式 1, 8-bit UART, 使能接收
TMOD |= 0x20; // TMOD: timer 1, mode 2, 8-bit 重裝
TH1 = 0xFD; // TH1: 重裝值 9600 波特率 晶振 11.0592MHz
TR1 = 1; // TR1: timer 1 打開(kāi)
EA = 1; //打開(kāi)總中斷
ES = 1; //打開(kāi)串口中斷
S2CON = 0x50;
BRT = 0xFD;
AUXR = 0x10;
IE2 =0x01;
void DelayMs(uint n)
uchar i=112;
while(n--)
while(i--);
主函數(shù)
void main (void)
InitUART();
DelayMs(10);
uart1SendStr("COMTOPC");//用于發(fā)送給上位機(jī)
DelayMs(10);
uart2SendStr(">>GetVal");//去讀取電流測(cè)試數(shù)據(jù),“GetVal” 是電流測(cè)試板的請(qǐng)求協(xié)議。
DelayMs(10);
if(flag1==1)
flag1=0;
for(i=0;i<9;i++)
send_char_com(RecDate[i]);
recnum2=0;// 接收數(shù)據(jù)長(zhǎng)度清零
DelayMs(100);
uchar i=0;
uchar temp[9]={0};
sprintf((char*)temp,"%8s",RecDate);
if(strcmp(temp,">>TDTEST") == 0)//這是自己任意設(shè)定的約定字 "TDTEST",以下照此
V5_off=0;
DelayMs(100);
else if(strcmp(temp,">>TDT=OK") == 0)
TEST_NG=1;
DelayMs(10);
TEST_OK=0;
DelayMs(100);
else if(strcmp(temp,">>TDT=NG") == 0)
TEST_OK=1;
DelayMs(10);
TEST_NG=0;
DelayMs(100);
DelayMs(5);
for(i=0;i<9;i++)
RecDate[i]=0;
//如果串口2接收到數(shù)據(jù),將此數(shù)據(jù)由串口1發(fā)送
if(flag2==1)
flag2=0;
UART_1SendOneByte(temp2);
1發(fā)送字符串
while(*s!='\0')// \0 表示字符串結(jié)束標(biāo)志,
//通過(guò)檢測(cè)是否字符串末尾
UART_1SendOneByte(*s);
s++;
2發(fā)送字符串
UART_2SendOneByte(*s);
s++;
SBUF = c;
while(!TI); //若TI=0,在此等待
TI = 0;
/****************串口2發(fā)送一個(gè)字符****************/
S2BUF = c;
while(!(S2CON&S2TI)); //若S2TI=0,在此等待
S2CON&=~S2TI; //S2TI=0
/************串行口1中斷處理函數(shù)*************/
void UART_1Interrupt(void) interrupt 4
if(RI==1)
RI=0; //標(biāo)志位清零
flag1=1;
if(recnum2<9)
RecDate[recnum2]=SBUF;
recnum2++;
/************串行口2中斷處理函數(shù)*************/
void UART_2Interrupt(void) interrupt 8
if(S2CON&S2RI)
S2CON&=~S2RI;
flag2=1;
temp2=S2BUF;
