標題: 51單片機利用2組P口檢測8*8矩陣鍵盤程序Proteus仿真圖 [打印本頁]
作者: 405616736    時間: 2022-12-14 00:21
利用單片機兩組P口,共16個引腳檢測8*8矩陣鍵盤,附C語言程序。使用LCD2004作為顯示
鍵盤值:
  1. #include <intrins.h>                        //引用程序目錄的相對路徑中的頭文件
  2. #include <reg51.h>                        //引用編譯器的類庫路徑里面的頭文件
  3. #include "1.Delay.c"                        //引用編譯器的類庫路徑里面的頭文件
  4. #include "2.2004.c"                        //引用編譯器的類庫路徑里面的頭文件
  5. #include "3.Keyscan.c"                        //引用編譯器的類庫路徑里面的頭文件
  6. /******************************
  7.                 主程序
  8. ******************************/
  9. void Main()
  10.         {
  11.                 LCD_Init();                        //LCD初始化子程序
  12.                 while(1)                        //循環(huán)指令
  13.                         {
  14.                                 Keyscan();                        //鍵盤檢測
  15.                                 switch(num)
  16.                                         {
  17.                                                 case 1:LCD_PutString(1,2,"01");break;
  18.                                                 case 2:LCD_PutString(1,2,"02");break;
  19.                                                 case 3:LCD_PutString(1,2,"03");break;
  20.                                                 case 4:LCD_PutString(1,2,"04");break;
  21.                                                 case 5:LCD_PutString(1,2,"05");break;
  22.                                                 case 6:LCD_PutString(1,2,"06");break;
  23.                                                 case 7:LCD_PutString(1,2,"07");break;
  24.                                                 case 8:LCD_PutString(1,2,"08");break;
  25.                                                 case 9:LCD_PutString(1,2,"09");break;
  26.                                                 case 10:LCD_PutString(1,2,"10");break;
  27.                                                 case 11:LCD_PutString(1,2,"11");break;
  28.                                                 case 12:LCD_PutString(1,2,"12");break;
  29.                                                 case 13:LCD_PutString(1,2,"13");break;
  30.                                                 case 14:LCD_PutString(1,2,"14");break;
  31.                                                 case 15:LCD_PutString(1,2,"15");break;
  32.                                                 case 16:LCD_PutString(1,2,"16");break;
  33.                                                 case 17:LCD_PutString(1,2,"17");break;
  34.                                                 case 18:LCD_PutString(1,2,"18");break;
  35.                                                 case 19:LCD_PutString(1,2,"19");break;
  36.                                                 case 20:LCD_PutString(1,2,"20");break;
  37.                                                 case 21:LCD_PutString(1,2,"21");break;
  38.                                                 case 22:LCD_PutString(1,2,"22");break;
  39.                                                 case 23:LCD_PutString(1,2,"23");break;
  40.                                                 case 24:LCD_PutString(1,2,"24");break;
  41.                                                 case 25:LCD_PutString(1,2,"25");break;
  42.                                                 case 26:LCD_PutString(1,2,"26");break;
  43.                                                 case 27:LCD_PutString(1,2,"27");break;
  44.                                                 case 28:LCD_PutString(1,2,"28");break;
  45.                                                 case 29:LCD_PutString(1,2,"29");break;
  46.                                                 case 30:LCD_PutString(1,2,"30");break;
  47.                                                 case 31:LCD_PutString(1,2,"31");break;
  48.                                                 case 32:LCD_PutString(1,2,"32");break;
  49.                                                 case 33:LCD_PutString(1,2,"33");break;
  50.                                                 case 34:LCD_PutString(1,2,"34");break;
  51.                                                 case 35:LCD_PutString(1,2,"35");break;
  52.                                                 case 36:LCD_PutString(1,2,"36");break;
  53.                                                 case 37:LCD_PutString(1,2,"37");break;
  54.                                                 case 38:LCD_PutString(1,2,"38");break;
  55.                                                 case 39:LCD_PutString(1,2,"39");break;
  56.                                                 case 40:LCD_PutString(1,2,"40");break;
  57.                                                 case 41:LCD_PutString(1,2,"41");break;
  58.                                                 case 42:LCD_PutString(1,2,"42");break;
  59.                                                 case 43:LCD_PutString(1,2,"43");break;
  60.                                                 case 44:LCD_PutString(1,2,"44");break;
  61.                                                 case 45:LCD_PutString(1,2,"45");break;
  62.                                                 case 46:LCD_PutString(1,2,"46");break;
  63.                                                 case 47:LCD_PutString(1,2,"47");break;
  64.                                                 case 48:LCD_PutString(1,2,"48");break;
  65.                                                 case 49:LCD_PutString(1,2,"49");break;
  66.                                                 case 50:LCD_PutString(1,2,"50");break;
  67.                                                 case 51:LCD_PutString(1,2,"51");break;
  68.                                                 case 52:LCD_PutString(1,2,"52");break;
  69.                                                 case 53:LCD_PutString(1,2,"53");break;
  70.                                                 case 54:LCD_PutString(1,2,"54");break;
  71.                                                 case 55:LCD_PutString(1,2,"55");break;
  72.                                                 case 56:LCD_PutString(1,2,"56");break;
  73.                                                 case 57:LCD_PutString(1,2,"57");break;
  74.                                                 case 58:LCD_PutString(1,2,"58");break;
  75.                                                 case 59:LCD_PutString(1,2,"59");break;
  76.                                                 case 60:LCD_PutString(1,2,"60");break;
  77.                                                 case 61:LCD_PutString(1,2,"61");break;
  78.                                                 case 62:LCD_PutString(1,2,"62");break;
  79.                                                 case 63:LCD_PutString(1,2,"63");break;
  80.                                                 case 64:LCD_PutString(1,2,"64");break;
  81.                                                 default:LCD_PutString(1,2,"00");break;        //default就是如果沒有符合的case就執(zhí)行它,default并不是必須的.
  82.                                         }
  83.                         }
  84.         }
Keil代碼與Proteus8.13仿真下載:
8×8鍵盤模擬.7z (59.17 KB, 下載次數(shù): 25)
作者: YXXSGB010    時間: 2025-1-16 15:37
這不用兩片138簡化IO口
