51單片機(jī)計(jì)數(shù)器程序
蘇沐秋
時(shí)間:
2022-11-30 22:09
(75.54 KB, 下載次數(shù): 31)
2022-11-30 22:07 上傳
#include<reg51.h>
unsigned char code table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char count;
int time_count;
sbit clk = P1^0;
sbit set = P3^4;
sbit start = P3^5;
char start_flag = 0;
void delay(unsigned int time)
unsigned int j = 0;
for(; time>0; time--)
for(j=0; j<125; j++);
key0() interrupt 0
delay(10);
count++;
if(count==20)
count=0;
void display_mode()
P2 = 0x00;
delay(500);
P2 = 0x3f;
delay(500);
void time_init()
TMOD=0x10; //工作于方式1
//0 0 方式0 13位計(jì)數(shù)器 TMOD=0x00
//0 1 方式1 16位計(jì)數(shù)器 TMOD=0x01
//1 0 方式2 自動(dòng)重裝8位計(jì)數(shù)器 TMOD=0x02
//1 1 方式3 T0分為2個(gè)8位獨(dú)立計(jì)數(shù)器,T1為無中斷重裝8位計(jì)數(shù)器 TMOD=0x03
EA=1; // 中斷允許
ET1=1; // 中斷1打開
TH1=(65536-50000)/256; // (65536-50000)/256=60.6875
TL1=(65536-50000)%256;
// TR1=1;
void timer1(void) interrupt 3
time_count++;
if (time_count==20) //達(dá)到1s
time_count = 0;
clk = ~clk;
void main(void)
EA = 1;
EX0 = 1;
IT0 = 1;
time_init();
P0 = table[0];
P2 = table[0];
display_mode();
if(set == 0)
delay(200);
if(set == 0)
count++;
if(count == 20)
count = 0;
if(start == 0)
delay(200);
if(start == 0)
if(start_flag == 0)
start_flag = 1;
TR1=1;
else if(start_flag == 1)
start_flag = 0;
TR1=0;
P0=table[count/10];
P2=table[count%10];
