分享一個(gè)74HC595驅(qū)動(dòng)數(shù)碼管,亮度可調(diào)的單片機(jī)代碼
[打印本頁(yè)]
非凡科技
時(shí)間:
2022-11-14 20:22
利用的類(lèi)似占空比調(diào)整方式實(shí)現(xiàn),整體程序采用框架編程方式,移植方便,新手作品歡迎指正.
單片機(jī)源程序如下:
#include "all.H"
u8 data HC595_Write_Buffer[2];
void HC595_Init()
P5M1 = 0x00;
P5M0 = 0x30; // P5(雙雙推推雙雙雙雙)
P3M1 = 0x00;
P3M0 = 0x08; // P3(雙雙雙雙推雙雙雙)
HC595_DS = 1;
HC595_SH = 0;
HC595_ST = 0;
void HC595_Write_Data_Drive()
u8 data i;
HC595_DS = 1;
HC595_SH = 0;
HC595_ST = 0;
for (i = 0; i < 8; i++)
HC595_SH = 0;
HC595_DS = HC595_Write_Buffer[1] & 0x80;
HC595_Write_Buffer[1] <<= 1;
HC595_SH = 1;
HC595_SH = 0;
HC595_DS = HC595_Write_Buffer[0] & 0x80;
HC595_Write_Buffer[0] <<= 1;
HC595_SH = 1;
HC595_ST = 1;
HC595_SH = 0;
HC595_DS = 1;
HC595_ST = 0;
#include "all.H"
u8 data SMG_Write_Buffer[8];
bit blink_flag;
u8 code SMG_SEG[24] = {
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F, //"9"
0x77, //"A"
0x7C, //"B"
0x39, //"C"
0x5E, //"D"
0x79, //"E"
0x71, //"F"
0x76, //"H"
0x38, //"L"
0x37, //"n"
0x3E, //"u"
0x73, //"P"
0x5C, //"o"
0x40, //"-"
0x00, //熄滅
u8 code SMG_GRID[9] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0x00};
void SMG_Display_Ser()
static u8 count = 0;
static bit places_Display_flag = 0;
count++;
if (count > 7)
count = 0;
switch (count) //判斷count的值,
case 0: //如果是0顯示第1位數(shù)碼管
case 1: //如果是1顯示第2位數(shù)碼管
case 2: //如果是2顯示第3位數(shù)碼管
case 3: //如果是3顯示第4位數(shù)碼管
case 4: //如果是4顯示第5位數(shù)碼管
case 5: //如果是5顯示第6位數(shù)碼管
case 6: //如果是6顯示第7位數(shù)碼管
case 7: //如果是7顯示第8位數(shù)碼管
if (SMG_Write_Buffer[count] != 0 && !places_Display_flag)
places_Display_flag = 1;
if (!blink_flag || !places_Display_flag)
HC595_Write_Buffer[0] = 0x00;
HC595_Write_Buffer[1] = 0x00;
if ((blink_flag) && (places_Display_flag || count == 7))
HC595_Write_Buffer[0] = SMG_SEG[SMG_Write_Buffer[count]];
//根據(jù)count順序,從SMG_Write_Buffer中輪流提取數(shù)據(jù),再找到該數(shù)據(jù)的模型段碼
HC595_Write_Buffer[1] = SMG_GRID[count]; //根據(jù)count的順序 找到對(duì)應(yīng)的位選碼
HC595_Write_Data_Drive(); //緩存數(shù)據(jù)傳輸?shù)?95芯片中去
if (count == 7)
break;
Keil代碼下載:
Keil代碼.7z
(17.85 KB, 下載次數(shù): 23)
2022-11-14 23:20 上傳
點(diǎn)擊文件名下載附件
heicad
時(shí)間:
2022-11-14 23:25
電路是如何連接的呢?
xiaoshan7748
時(shí)間:
2022-11-15 08:48
挺好的驅(qū)動(dòng)方式,只需要三根口線就可以了,顯示效果還能得到保證。程序?qū)懙囊脖容^簡(jiǎn)練。
wkman
時(shí)間:
2022-11-15 17:01
heicad 發(fā)表于 2022-11-14 23:25
電路是如何連接的呢?
估計(jì)是:一片 595 ->接8個(gè) seg段, 另外一片595 接 8個(gè) 位
