標(biāo)題: 51單片機(jī)控制步進(jìn)電機(jī)Proteus仿真代碼 [打印本頁(yè)]
作者: 9527ddd    時(shí)間: 2022-10-2 16:46
步進(jìn)電機(jī)的控制程序,程序+仿真
單片機(jī)源程序如下:
  1. sfr P1 = 0x90;
  2. sfr TMOD = 0x89;
  3. sfr TH0 = 0x8C;
  4. sfr TL0 = 0x8A;
  5. sbit TR0 = 0x8C;
  6. sbit EA = 0xAF;
  7. sbit ET0 = 0xA9 ;
  8. unsigned char code BeatCode[8] = {0x01,0x03,0x02,0x06,0x04,0x0C,0x08,0x09};
  9. unsigned char i = 1;
  10. void main()
  11. {
  12.                 unsigned char tmp = 0;
  13.                 unsigned char index = 0;
  14.
  15.           EA = 1;
  16.                 TMOD = 0x01;
  17.                 TH0 = 0xA2;
  18.                 TL0 = 0x40;
  19.           ET0 = 1;
  20.                 TR0 = 1;
  21.
  22.
  23.                 while(1)
  24.                 {
  25.                                 tmp = P1;
  26.                                 tmp = tmp & 0xF0;
  27.                                 tmp = tmp | BeatCode[index];
  28.                                 P1 = ~tmp;
  29.                                 index++;
  30.                                 index =index & 0x07;
  31.                                 while(i);
  32.               i = 1;
  33.      }
  34. }
  35. void Timeinterrupt_0() interrupt 1  //定時(shí)0.0002ms
  36. {
  37.                 TH0 = 0xA2;
  38.                 TL0 = 0x40;
  39.                 i--;
  40. }
Keil代碼與Proteus8.8仿真下載:
步進(jìn)電機(jī).7z (96.16 KB, 下載次數(shù): 36)
