單片機+DS1302寫入年月日程序與Proteus仿真
com456
2022-5-28 15:06
萌新程序,大佬門見諒。
(84.42 KB, 下載次數: 28)
2022-5-29 22:26 上傳
#include<reg51.h>
#include<intrins.h>
sbit rs=P1^0;
sbit rw=P1^1;
sbit e=P1^2;
sbit RST=P1^6;
sbit SCK=P1^4;
sbit IO=P1^5;
uint m,f,h,t,a;
uchar shu1[8]={6,5,4,3,2,7,1};
uchar shu2[8];
void delay_LCD(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void com(uchar com)
rs=0;
e=0;
rw=0;
P0=com;
delay_LCD(1);
e=1;
delay_LCD(1);
e=0;
void shu(uchar shu)
rs=1;
e=0;
rw=0;
P0=shu;
delay_LCD(1);
e=1;
delay_LCD(1);
e=0;
void chu( )
com(0x38);
com(0x0c);
com(0x01);
com(0x06);
ds1302_read(uchar add)
uint i,m1,m;
RST=0; _nop_();
SCK=0; _nop_();
RST=1;
for(i=0;i<8;i++)
IO=add&0x01;
add=add>>1;
SCK=1;_nop_();
SCK=0;_nop_();
for(i=0;i<8;i++)
m1=IO;
m=(m>>1)|(m1<<7);
SCK=1;_nop_();
SCK=0;_nop_();
RST=0;_nop_();
SCK=1;
_nop_();IO = 0;
_nop_();IO = 1;
_nop_();
return m;
void ds1302_write(uchar add,uchar m)
uchar i;
RST=0;
_nop_();
SCK=0;
_nop_();
RST=1;
for(i=0;i<8;i++)
IO=add&0x01;
add=add>>1;
SCK=1;
_nop_();
SCK=0;
_nop_();
for(i=0;i<8;i++)
IO=m&0x01;
m=m>>1;
SCK=1;
_nop_();
SCK=0;
_nop_();
RST=0;
_nop_();
read_ds1302()
uchar i;
shu1[6]=ds1302_read(0x81)&0x7f;
shu1[5]=ds1302_read(0x83);
shu1[4]=ds1302_read(0x85);
shu1[3]=ds1302_read(0x87);
shu1[2]=ds1302_read(0x89);
shu1[7]=ds1302_read(0x8b);
shu1[1]=ds1302_read(0x8d);
for(i=1;i<8;i++)
shu2[i]=(shu1[i]>>4)*10+(shu1[i]&0x0f);
void ds1302_init()
RST=0;
SCK=0;
ds1302_write(0x8e,0x00);
ds1302_write(0x80,0x14);
ds1302_write(0x82,0x13);
ds1302_write(0x84,0x12);
ds1302_write(0x8a,0x04);
ds1302_write(0x86,0x22);
ds1302_write(0x88,0x02);
ds1302_write(0x8c,0x22);
ds1302_write(0x8e,0x80);
//lcd_riqi(uchar ddd1,uchar dat1)
//uchar gw,sw;
//gw=dat1%10;
//sw=dat1/10;
//com(0x80+ddd1);
//shu(0x30+sw);
//shu(0x30+gw);
//lcd_shijian(uchar ddd2,uchar dat2)
//uchar gw,sw;
//gw=dat2%10;
//sw=dat2/10;
//com(0x80+0x40+ddd2);
//shu(0x30+sw);
//shu(0x30+gw);
//lcd_write(uchar *shuju)
//lcd_riqi(0,shuju[0]);
//lcd_riqi(2,shuju[1]);
//lcd_riqi(5,shuju[2]);
//lcd_riqi(8,shuju[3]);
//lcd_shijian(0,shuju[4]);
//lcd_shijian(3,shuju[5]) ;
//lcd_shijian(6,shuju[6]);
chu();
ds1302_init();
read_ds1302();
com(0x82);
shu(shu2[1]/10+0x30);
shu(shu2[0]%10+0x30);
shu(shu2[1]%10+0x30);
shu('-');
shu(shu2[2]/10+0x30);
shu(shu2[2]%10+0x30);
shu('-');
shu(shu2[3]/10+0x30);
shu(shu2[3]%10+0x30);
com(0xc2);
shu(shu2[4]/10+0x30);
shu(shu2[4]%10+0x30);
shu(':');
shu(shu2[5]/10+0x30);
shu(shu2[5]%10+0x30);
shu(':');
shu(shu2[6]/10+0x30);
shu(shu2[6]%10+0x30);
Keil代碼與Proteus8.8仿真下載:
寫入年月日.zip
(71.92 KB, 下載次數: 18)
2022-5-28 15:04 上傳
萌新大佬門多多包涵
