標題: 別人設計的簡單交通信號燈 [打印本頁]
作者: 2825mk256189    時間: 2022-5-28 08:50
標題: 別人設計的簡單交通信號燈
#include<reg51.h>
#define uint unsigned  int
sbit sw1=P3^0;
sbit sw2=P3^1;
sbit sw3=P3^2;
sbit key_ew=P3^3;
sbit key_sn=P3^4;
sbit BZ=P3^5;
uchar TH,TL;
uchar SN=30,EW=25,NN=60;
uint tt,ii,jj,kk;
uchar code DisCode[]
={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar Disbuff0[2];
uchar Disbuff1[2];
void Delay(uint x)//MS延時
        uchar i;
        while(x--)for(i=0;i<123;i++);
void init()
TMOD=0x01;
TH=(65536-4000)/256,
TL=(65536-4000)%256;
TH0=TH;
TL0=TL;
EA=1;
ET0=1;
TR0=1;
void fenli0()
Disbuff0[0]=SN/10;
Disbuff0[1]=SN%10;
void fenli1()
  Disbuff1[0]=EW/10;
  Disbuff1[1]=EW%10;
void Display()
   uchar ii;
   if(ii==0)
     P0=0x80;
         P2=0x80;
     P2=DisCode[Disbuff0[0]]|0x80;
         P0=DisCode[Disbuff1[0]]&0x7f;
          P0=0x80;
          P2=0x80;
          P2=DisCode[Disbuff0[1]]&0x7f;
          P0=DisCode[Disbuff1[1]]|0x80;
         ii=~ii;
void fuzhi()//賦值
  if(NN==60)
    SN=30;
        EW=25;
        P1=0x5E;
  if(EW==0&&NN==35)
    EW=5;
        P1=0x6E;
  if(NN==30)
    SN=25;
        EW=30;
        P1=0xB3;
   if(SN==0&&NN==5)
     SN=5;
         P1=0xB5;
void LED()//LED
  if(NN<=40&&NN>35)//
    if(kk)
      P1=0x5E;
        else P1=0xfE;
   if(NN<=35&&NN>30)
         if(kk)
          P1=0x6E;
         else P1=0xEE;
   if(NN<=10&&NN>5)
    if(kk)
      P1=0xB3;
        else P1=0xF7;
   if(NN<=5)
         if(kk)
          P1=0xB5;
         else P1=0xF5;
void qiangzhi_sw()//強制通行
    if(key_ew==0)
            TR0=0;
                P0=0x3f;
                P2=0x3f;
                P1=0x5e;
                while(!key_ew);
                  TR0=1;
         if(key_sn==0)
            TR0=0;
                P0=0x3f;
                P2=0x3f;
                P1=0xb3;
                while(!key_sn);
                  TR0=1;
void key1()//調時
   uchar m=0,num=0,n=0;
   uchar sw11,sw22=1,sw33=1;
        if(sw1==0)
           Delay(10);
           if(sw1==0)
                  while(!sw1);
                     num++;
                     TR0=0;
                  while(!m)
                      if(n==1)
                                   if(sw11==1&&sw1==0)
                                           Delay(10);
                                          if(sw11==1&&sw1==0)
                                                num++;
                                   if(num==3)
                                       while(!sw1);
                                   sw11=sw1;
                                n=1;
                                Delay(3);
                           switch (num)
                                  case 1:
        if(sw22==1&&sw2==0)
        SN++;
        EW++;
        if(EW==100)
        EW=5;
        SN=0;
        if(SN==100)
        SN=5;
        EW=0;
        fenli0();
        fenli1();
        sw22=sw2;
        if(sw33==1&&sw3==0)
        SN--;
        EW--;
        if(EW==255)
        EW=94;
        SN=99;
        if(SN==255)
        SN=94;
        EW=99;
        fenli0();
        fenli1();
        sw33=sw3;
        Display();
                                                  } break;
                                case 2:
                                                    TR0=1;
                                                    m=1;
                                                        while(!sw1);
                                                        Delay(5);
                                                        while(!sw1);
                                                 } break;
init();
fenli0();
fenli1();
  qiangzhi_sw();
  key1();
void timer0() interrupt 1
  TH0=TH;
  TL0=TL;
  tt++;
  jj++;
if(tt==250)
    tt=0;
         fuzhi();
         EW--;
     SN--;
         if(SN==30)
                NN=61;
         if(EW==30)
                NN=30;
   if(EW<30||SN<30)
     NN--;
         if(NN==0)
           NN=60;
   fenli0();
   fenli1();
  Display();
  LED();
  if(jj==50)
    jj=0;
    kk=~kk;
