標題: 發一個基于STC12C5A60S2單片機的頻率計的代碼 [打印本頁]
作者: Mycool    時間: 2022-4-22 22:48
#include "STC12C5A60S2.h"
//#include <reg52.h>
#define Segment P0
#define sl P2
sbit clear=P1^3;
sbit fp2=P1^2;    //定義數據端口地址,0時分頻處理,1時不分頻
unsigned char count;      //定時 1s 計數
unsigned char d[4];       //對應數碼管的各位
unsigned char dangwei;    //檔位
unsigned int timeN;       //不同檔位計時值
unsigned int fCount;      //脈沖下降沿次數
unsigned int regCount;    //脈沖次數暫存
unsigned int pCount;      //頻率顯示
unsigned char Num[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
//七段數碼管代碼共陽極
void Delay(unsigned int DelayTime)
   while(DelayTime--);
void dispbuf()
  if(dangwei==0)     //檔位
     d[3]=0;
     d[2]=(pCount/100)%10;
     d[1]=(pCount/10)%10;
     d[0]=pCount%10;
     sl=0x01;Delay(1);Segment=Num[d[3]];Delay(200);
     sl=0x02;Delay(1);Segment=Num[d[2]];Delay(200);
     sl=0x04;Delay(1);Segment=Num[d[1]];Delay(200);
     sl=0x08;Delay(1);Segment=Num[d[0]];Delay(200);
   else if(dangwei==1)
       d[3]=pCount/1000;
       d[0]=pCount%1;
       sl=0x04;Delay(1);Segment=Num[d[1]]&0x7f;Delay(200); //帶小數點
    d[3]=0;
    d[2]=0;
    d[1]=0;
    d[0]=0;
void intial()
   clear=1;           //分頻器初始化
   fp2=1;
   timeN=20;          //檔位初始化為 Hz 檔
   dangwei=0;
   TMOD=0x61;       //定時器0,工作方式1,計數器1,工作方式1
   TH0= (65536-50000)/256;
   TL0= (65536-50000)%256;
                                                    //計數器1計數初值
   TH1=0xff;         // 256-1;
   TL1=0xff;         // 256-1;
   TR0=1;           //開定時器0中斷
   ET0=1;           //定時器0允許
   TR1=1;           //開計數器1中斷
   ET1=1;           //允許計數器1中斷
   EA=1;            //總中斷允許
        intial();
          dispbuf();
void timer0() interrupt 1
   count++;
   if(count==timeN)
     ET1=0;      //計時1s,暫停外部計數1
     TR1=0;
     count=0;
    regCount=fCount;        //更新顯示
     fCount=0;               //頻率計數清零
     clear=0;                //硬件分頻器清零
     clear=1;
  if(dangwei==0)          //檔位切換
    pCount=regCount;
   if(regCount>999)
      pCount=0;              //顯示清零
      dangwei=1;
      timeN=1;               //定時 50ms
      fp2=0;                 //硬件分頻處理
      TH1=0xfb;              //50分頻 256-5
      TL1=0xfb;              //256-5
      pCount=regCount*10;    //換算成相應的顯示:f=regCount*100
  else if(dangwei==1)
    if(regCount<1)
      dangwei=0;
      timeN=20;             //定時 1s
      fp2=1;                //不分頻
      TH1=0xff;             //256-1
      TL1=0xff;             //256-1
    else if(regCount<1000)       //KHz 檔
      dangwei=1;
      timeN=1;               //定時 50ms
      fp2=0;                 //硬件分頻處理
      TL1=0xfb;              //256-5
        dangwei=3;        //超出范圍
  ET1=1;               //恢復外部計數 1
  TR1=1;
   TH0=(65536-50000)/256;
   TL0=(65536-50000)%256;
void enterFre() interrupt 3       //外部頻率輸入
fCount++;
