STM32單片機(jī)+LCD12864顯示一個(gè)點(diǎn)的程序
zirencharles
時(shí)間:
2022-4-22 16:24
單片機(jī)源程序如下:
#include "delay.h"
#include "12864.h"
unsigned char x,y;
int main(void)
SystemInit(); //系統(tǒng)初始化
delay_init(72); //延時(shí)初始化
LCD12864_InitPort(); //端口初始化
LCD12864_Init(); //液晶初始化
for(x=0;x<4;x++)
for(y=0;y<16;y++)
LCD12864_Pos(x,y);
LCD12864_Wdat(0x2E);
delay_ms(1000);
LCD12864_Clr(); // 清屏
while(1);
#include "stm32f10x.h"
#include"12864.h"
#include"delay.h"
@f_name: void GPIO_Init(void)
@brief: 初始化硬件端口配置
@param: None
@return: None
void LCD12864_InitPort(void)
GPIO_InitTypeDef GPIO_InitStructure; //定義結(jié)構(gòu)體
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOG, ENABLE);
GPIO_InitStructure.GPIO_Pin = LCD_GPIO_CMD; // 指令口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出模式
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOD,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = LCD_GPIO_DAT; //數(shù)據(jù)口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //開漏輸出模式
GPIO_Init(GPIOG,&GPIO_InitStructure); //初始化IO口配置
GPIO_Write(GPIOG,0xff00); //該行指令似乎可以去掉
@f_name: LCD12864_busy()
@brief: 檢測忙狀態(tài)
@Function: 讀取引腳15的輸入數(shù)據(jù).
@annotation: 結(jié)合前文 RS=0、RW=1, 以及12864中文字庫說明書之基本指令表: 讀取忙碌標(biāo)志和地址,
可知:該行指令的實(shí)際作用是: 判斷12864是否處于(讀取數(shù)據(jù))忙狀態(tài).
@note: 因?yàn)榕袛嗟氖菙?shù)據(jù)位(DB0-DB7)忙狀態(tài), 所以忙狀態(tài)位必須與DB7位一致.
@param: None
@return: None
u8 LCD12864_busy(void)
u8 x;
LCD_RS(0);
LCD_RW(1);
LCD_EN(1);
NOP();
NOP();
x = Text_Busy; // 讀取引腳15的輸入數(shù)據(jù).
LCD_EN(0);
return x;
@f_name: void LCD12864_Wcmd(u8 dat)
@brief: 寫指令
@param: u8 dat 輸入指令
@return: None
void LCD12864_Wcmd(u8 dat) // 寫指令
while(LCD12864_busy()); //忙檢測
LCD_RS(0);
LCD_RW(0);
LCD_EN(0);
NOP();
NOP();
LCD_WriteData(dat);
NOP();
NOP();
LCD_EN(1);
NOP();
NOP();
LCD_EN(0);
@f_name: void LCD12864_Wdat(u8 dat)
@brief: 寫數(shù)據(jù)
@param: u8 dat 輸入數(shù)據(jù)
@return: None
void LCD12864_Wdat(u8 dat) //寫數(shù)據(jù)
LCD_RS(1);
LCD_RW(0);
LCD_EN(0);
NOP();
NOP();
LCD_WriteData(dat);
NOP();
NOP();
LCD_EN(1);
NOP();
NOP();
LCD_EN(0);
@f_name: void LCD12864_Init(void)
@brief: 液晶初始化
@param: None
@return: None
LCD_PSB(1); //并口方式
LCD_RST(0); //液晶復(fù)位
delay_ms(3);
LCD_RST(1); //置高電平等待復(fù)位
delay_ms(3);
// LCD12864_Wcmd(0x34); //擴(kuò)充指令操作
delay_ms(5);
LCD12864_Wcmd(0x30); //基本指令操作
delay_ms(5);
LCD12864_Wcmd(0x0C); //顯示開,關(guān)光標(biāo)
delay_ms(5);
LCD12864_Wcmd(0x01); //清屏
delay_ms(5);
@f_name: void LCD12864_Clr(void)
@brief: 清屏
@param: None
@return: None
LCD12864_Wcmd(0x34); //擴(kuò)充指令操作 “繪圖”
delay_ms(5);
delay_ms(5);
delay_ms(5);
@f_name: void LCD12864_Pos(u8 x,u8 y)
@brief: 設(shè)置顯示位置
@param: u8 x:X軸 u8 y:Y軸
@return: None
u8 pos;
if (x==1) {x=0x80;}
else if (x==2) {x=0x90;}
else if (x==3) {x=0x88;}
else if (x==4) {x=0x98;}
else x=0x80;
pos = x+y ;
LCD12864_Wcmd(pos); //顯示地址
@f_name: void LCD12864_PhotoDis(u8 *bmp)
@brief: 顯示圖形
@param: u8 *bmp 圖形數(shù)組
@return: None
u8 i,j;
LCD12864_Wcmd(0x34); //關(guān)閉圖形顯示
for(i=0;i<32;i++)
LCD12864_Wcmd(0x80+i); //先寫入水平坐標(biāo)值
LCD12864_Wcmd(0x80); //寫入垂直坐標(biāo)值
for(j=0;j<16;j++) //再寫入兩個(gè)8位元的數(shù)據(jù)
LCD12864_Wdat(*bmp++);
delay_ms(1);
for(i=0;i<32;i++)
LCD12864_Wcmd(0x88);
for(j=0;j<16;j++)
delay_ms(1);
LCD12864_Wcmd(0x36); //寫完數(shù)據(jù),開圖形顯示
@f_name: void LCD_ShowString(u8 x,u8 y,const u8 *p)
@brief: 顯示字符串
@return: None
u8 temp;
if(x>4) {x=1;}
if(y>4) {y=0;}
LCD12864_Pos(x,y);
temp=*p;
while(temp!='\0')
LCD12864_Wdat(temp);
temp=*(++p);
@f_name: void NOP(void)
@brief: 延時(shí)函數(shù)
@param: None
@return: None
void NOP(void)
{ u8 i; for(i=0; i<100; i++); }
Keil代碼下載:
12864_poi_display.7z
(190.16 KB, 下載次數(shù): 39)
2022-4-22 23:17 上傳
點(diǎn)擊文件名下載附件
liuyiyi
時(shí)間:
2022-5-6 16:36
stm32的仿真圖可以做一個(gè)比較好
