單片機按鍵控制8x8點陣Proteus仿真程序
heilongbao
2021-12-6 11:30
簡易的8X8點陣,拿去
(132.71 KB, 下載次數: 64)
2021-12-6 16:45 上傳
#include <reg52.h>
#include <intrins.h>
void delayms(unsigned int n);
sbit KEY=P2^0;
sbit KEY1=P2^1;
sbit KEY2=P2^2;
//添加取模記得定義數組數量
uchar code M[11][8]=
{0x00,0x3e,0x41,0x41,0x41,0x3e,0x00,0x00},
{0x00,0x00,0x00,0x21,0x7f,0x01,0x00,0x00},
{0x00,0x27,0x45,0x45,0x45,0x39,0x00,0x00},
{0x00,0x22,0x49,0x49,0x49,0x36,0x00,0x00},
{0x00,0x0c,0x14,0x24,0x7f,0x04,0x00,0x00},
{0x00,0x72,0x51,0x51,0x51,0x4e,0x00,0x00},
{0x00,0x3e,0x49,0x49,0x49,0x26,0x00,0x00},
{0x00,0x40,0x40,0x40,0x4f,0x70,0x00,0x00},
{0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00},
{0x00,0x32,0x49,0x49,0x49,0x3e,0x00,0x00},
{0x00,0x20,0x30,0x38,0x3c,0x3e,0x00,0x00}
uchar i,j;
P0 = 0xff;
P1 = 0xff;
P2 = 0xff;
TMOD = 0x01;
TH0 = (65535-2000)/256;
TL0 = (65535-2000)%256;
IT0 = 1;
IE = 0x83;
i = 0xfc; //開頭修改這即可
if(!KEY)
delayms(100);
while(!KEY)
P0 = 0xff;
P1 = 0x80;
j = 0;
i = (i+1)%11;
if(!KEY1)
delayms(100);
while(!KEY1)
P0 = 0xff;
P1 = 0x80;
j = 0;
i = (i+1)%11;
if(!KEY2)
delayms(100);
while(!KEY2)
P0 = 0xff;
P1 = 0x80;
j = 0;
i = (i+1)%11;
void Key_Down() interrupt 0 //中斷
P0 = 0xff;
P1 = 0x80;
j = 0;
i = (i+1)%11;
TR0 = 1;
void Show_Dot_Matrix() interrupt 1
P1 = _crol_(P1,1); //循環左移
P0 = ~M[i][j];
j=(j+1)%8;
unsigned int i,j;
for(j=n;j>0;j--)
for(i=112;i>0;i--);
仿真代碼51hei附件下載:
8X8點陣.zip
(56.46 KB, 下載次數: 38)
2021-12-6 11:29 上傳
