基于51單片機的簡易數字鐘
zyl淋雨一直走
2021-10-27 16:29
基于51單片機的簡易數字鐘
[attach]283378[/attach]
#include<at89x52.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit S1=P3^2;
sbit S2=P3^3;
sbit S3=P3^4;
uchar data hour=23,minute=59,second=50;
uchar count=0;
bit flag1s=0;
unsigned char v_time[9];
unsigned char disp[]="2021-09-07";
unsigned char v_key=0;
//函數聲明
void LCD_init();
void Set_xy(unsigned char line,unsigned char col);
void Write_dat(unsigned char data_d);
void delay_nms(unsigned char t);
void Write_com(unsigned char com_d);
void Display(unsigned char line,unsigned char col,unsigned char *dlcd);
/*------------LCD初始化函數-------------*/
void LCD_init()
delay_nms(15);
Write_com(0x38);
delay_nms(5);
Write_com(0x0c);
delay_nms(5);
Write_com(0x06);
/*------------LCD寫命令函數-------------*/
RS=0;
RW=0;
E=1;
P0=com_d;
E=0;
/*------------LCD設置顯示位置函數-------------*/
unsigned char address;
if(line==0)
address=0x80+col;
address=0xc0+col;
delay_nms(5);
Write_com(address);
/*------------LCD寫數據函數------------*/
RS=1;
RW=0;
E=1;
P0=data_d;
E=0;
/*------------LCD固定字符串顯示函數------------*/
Set_xy(line,col);
while(*dlcd)
delay_nms(5);
Write_dat(*dlcd);
dlcd++;
unsigned int i, j;
for (i = t; i > 0; i--)
for (j = 110; j > 0; j--);
/*--------T0初始化函數---------*/
void T0_Init()
EA=1;
ET0=1;
TMOD=0x01;
TH0=0x3c;
TL0=0xb0;
TR0=1;
/*-------時鐘函數--------*/
void timer_init()
if(flag1s)
flag1s=0;
if(++second==60)
second=0;
if(++minute==60)
minute=0;
if(++hour==24)
hour=0;
/*--------拆分處理函數---------*/
void convert()
v_time[0]=hour/10+0x30;
v_time[1]=hour%10+0x30;
v_time[2]=':';
v_time[3]=minute/10+0x30;
v_time[4]=minute%10+0x30;
v_time[5]=':';
v_time[6]=second/10+0x30;
v_time[7]=second%10+0x30;
v_time[8]=0;
/*---------按鍵掃描函數----------*/
void key_scan()
if(S1==0)
delay_nms(10);
if(S1==0)
v_key++; TR0=0;
if(v_key>=3)
v_key=0;
TR0=1;
while(S1==0);//按鍵S1按下處理函數
/*----------調分函數------------*/
void adjust_minute()
if(S2==0)
delay_nms(10);
if(S2==0)
minute++;
if(minute==60) minute=0;
while(S2==0);
if(S3==0)
delay_nms(10);
if(S3==0)
minute--;
if(minute==255) minute=59;
/*----------調時函數------------*/
void adjust_hour()
if(S2==0)
delay_nms(10);
if(S2==0)
hour++;
if(hour==24) hour=0;
while(S2==0);
if(S3==0)
delay_nms(10);
if(S3==0)
hour--;
if(hour==255) hour=23;
//主函數
main()
T0_Init();
LCD_init();
EA=1;
key_scan();
switch(v_key)
case 0:timer_init();break;
case 1:adjust_minute();break;
case 2:adjust_hour();
convert();
Display(1,3,v_time);
Display(0,3,disp);
/*--------T0中斷服務函數---------*/
void T0_ser() interrupt 1
TH0=0X3c;
TL0=0xb0;
if(++count==20)
flag1s=1;
count=0;
[attach]283380[/attach]
(57.5 KB, 下載次數: 90)
2021-10-27 16:29 上傳
(55.61 KB, 下載次數: 88)
2021-10-27 16:20 上傳
452345453
2021-12-29 09:37
請問一下如果要把按鍵3改成在調節功能下切換位置怎么改?
52255
2022-12-18 14:42
你好 那個功能鍵我把他們換到P1口了 改完后按下去沒反應 是怎么回事?
52255
2022-12-18 14:57
你好 那個減的按鍵為什么一次減兩下 需要怎么改
