標題: 單片機LCR電橋程序 許老師多年前的作品 [打印本頁]
作者: lzc123456789    時間: 2021-10-21 08:33
該電橋,具有價格便宜,性能精度能滿足一般電子愛好者的使用,電路方面許老師的自述文件里都有介紹,現提供熱心網友提供的更新程序,最后聲明:所有文件的所有權益歸原作者許老師所有.
  1. //==========================================================================
  2. //  LCR表驅動程序 V2.0
  3. //  許劍偉 于莆田 2012.01
  4. //==========================================================================
  5. //==========================================================================
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. #define ulong  unsigned long
  9. #include <reg52.h>
  10. #include <math.h>
  11. //==========================================================================
  12. // 項目:LCD1602 四線驅動程序
  13. // 設計要點:
  14. //     LCD1602 的運行速度慢,而單片機運行的速度快,因此容易因為速度不
  15. //     匹配造成調試失敗。因此,調試之前應準確測試lcd_delay() 延時函數
  16. //     準確的延時量,如果不能滿足注釋中的要求,則應調整循次數。每步操
  17. //     作所需的延時量,按照數據手冊指標指行,同時留下足夠的時間余量。
  18. // 硬件連接:
  19. //     至少需要9條線,電源線2條,7條信號線。信號線詳見程序中的接口定義。
  20. //     清注意對LCD1602對比度的調節,否則無顯示。
  21. // 設計:許劍偉,于莆田,2010.12
  22. //==========================================================================
  23. sbit lcd_RS = P0^6; //數據命令控制位,0命令1數據
  24. sbit lcd_RW = P0^5; //讀寫位,0寫1讀
  25. sbit lcd_EN = P0^4; //使能位,下降沿觸發
  26. sbit lcd_D4 = P0^3; //數據端口D4
  27. sbit lcd_D5 = P0^2; //數據端口D5
  28. sbit lcd_D6 = P0^1; //數據端口D6
  29. sbit lcd_D7 = P0^0; //數據端口D7
  30. //==========================================================================
  31. code char path[32]={
  32. 0x00,0x00,0x0e,0x11,0x11,0x0a,0x1b,0x00,
  33. 0x00,0x11,0x11,0x13,0x1d,0x10,0x10,0x10,
  34. 0x0e,0x11,0x1f,0x11,0x11,0x0e,0x00,0x00,
  35. 0x1C,0x10,0x1B,0x12,0x1B,0x01,0x07,0x00
  36. };//自定義符號
  37. char binLian=0,ATA=0,ATB=1;
  38. char OX[8]={0,0,0,0,0,0,8,0};
  39. int DDS3=1, c3 = 0; //交替顯示變量
  40. char digW=4; //數字顯示位數宏
  41. code uchar abc[][5]={
  42. "  err","   40","  120","  360"," 1080","   1K","   3K","   9K","  27K","  10K",
  43. "  30K","  90K"," 270K"," 100K"," 300K"," 900K"," 2.7M","   13","  4.5","  1.5"
  44. };
  45. void lcd_delay(int n){ //LCD專用延時函數
  46.   //32MHz鐘頻下,約循環3000次延遲1毫秒
  47.   int i,j;
  48.   if(n<0)    { for(i=0;i< 30;i++); return; } //10us
  49.   if(n== 0)  { for(i=0;i<150;i++); return; } //50us
  50.   for(;n;n--){ for(j=0;j<3000;j++);        } //n毫秒
  51. }
  52. //==========================================================================
  53. void lcd_B(char f, uchar c, char t){ //控制四線式接口LCD的7個腳
  54.   //f=0寫命令字, f=1寫RAM數據, f=2讀地址(或讀忙), f=3讀RAM數據
  55.   lcd_EN = 0;
  56.   lcd_RS = f%2;
  57.   lcd_RW = f/2%2;
  58.   //移入高四位
  59.   lcd_D4 = c & 16;
  60.   lcd_D5 = c & 32;
  61.   lcd_D6 = c & 64;
  62.   lcd_D7 = c & 128;
  63.   lcd_EN = 1;  lcd_delay(-1);  lcd_EN = 0; //使能脈沖
  64.   if(f==4) { lcd_delay(t); return; }
  65.   //移入低四位
  66.   lcd_D4 = c & 1;
  67.   lcd_D5 = c & 2;
  68.   lcd_D6 = c & 4;
  69.   lcd_D7 = c & 8;
  70.   lcd_EN = 1;  lcd_delay(-1);  lcd_EN = 0; //使能脈沖
  71.   lcd_delay(t);  //不同的命令,響應時間不同,清零命令需要2ms
  72. }
  73. //==========================================================================
  74. void lcd_init(){ //LCD1602 初始化
  75.   //啟動四線模式須勢行9個步驟,初始化所須耗時較長,約65ms,時限不可減
  76.   lcd_delay(20); //啟動lcd之前須延時大于15ms,直到VDD大于4.5V
  77.   lcd_B(4, 0x30, 9); //置8線模式,須延時大于4.1ms
  78.   lcd_B(4, 0x30, 5); //置8線模式,須延時大于100us
  79.   lcd_B(4, 0x30, 5); //置8線模式,手冊中未指定延時
  80.   lcd_B(4, 0x20, 5); //進入四線模式
  81.   lcd_B(0, 0x28, 5); //四線模式雙行顯示
  82.   lcd_B(0, 0x0C, 5); //打開顯示器
  83.   lcd_B(0, 0x80, 5); //RAM指針定位
  84.   lcd_B(0, 0x01, 5); //啟動清屏命初始化LCD
  85. }
  86. //==========================================================================
  87. //=========================幾個功能常用函數=================================
  88. void lcd_cls()         { lcd_B(0, 0x01+0, 2);  } //清屏
  89. void lcd_cur0()        { lcd_B(0, 0x0C+0, 0);  } //隱藏光標
  90. void lcd_goto1(uchar x){if(ATB) lcd_B(0, 0x80+x, 0); else lcd_B(0, 0x94+x, 0);} //設置DDRAM地址,第1行x位
  91. void lcd_goto2(uchar x){if(ATB) lcd_B(0, 0xC0+x, 0); else lcd_B(0, 0xD4+x, 0);} //設置DDRAM地址,第2行x位
  92. void lcd_goto3(uchar x){if(ATB) lcd_B(0, 0x94+x, 0); else lcd_B(0, 0x80+x, 0);} //設置DDRAM地址,第3行x位
  93. void lcd_goto4(uchar x){if(ATB) lcd_B(0, 0xD4+x, 0); else lcd_B(0, 0xC0+x, 0);} //設置DDRAM地址,第4行x位
  94. void lcd_putc(uchar d) { lcd_B(1, 0x00+d, 0);  } //字符輸出
  95. void lcd_puts(uchar *s){ for(; *s; s++) lcd_B(1,*s,0); } //字串輸出
  96. //==============字符顯示函數====================
  97. void lcd_putp(float a,float b,char bo,char n, float qmin){ //帶單位顯示復數,n是單位下限,qmin是最小位權值(用于限定有效數字)
  98.   code uchar dwB[] = {'p','n','u','m',' ','k','M','G'}; //單位表
  99.   char i,j, c=0, h=digW-1, fh[2]={' ','+'};
  100.   long d,q,qm,Q=1; //最高位權
  101.   float f,g=1;
  102.   if(a<0) fh[0] = '-', a = -a;
  103.   if(b<0) fh[1] = '-', b = -b;
  104.   if(a>b) f = a; else f = b;
  105.   for(i=1;i<digW;i++) Q *= 10;
  106.   for(i=0;i<3;i++){ if(f*g >= 1000) g/=1000, c++; } //以3位為單位移動小數點,右移
  107.   for(i=0;i<n;i++){ if(f*g < 1)     g*=1000, c--; } //以3位為單位移動小數點,左移
  108. if ((n==1)&&(c==-1)){
  109.   for(i=1;i<2 && f*g<Q;i++) g*=10,h--;           //繼續移動小數點,使之滿字
  110. }else if ((n==2)&&(c==-2)){
  111.   for(i=1;i<3 && f*g<Q;i++) g*=10,h--;           //繼續移動小數點,使之滿字
  112. }else if ((n==4)&&(c==-4)){
  113.   for(i=1;i<2 && f*g<Q;i++) g*=10,h--;           //繼續移動小數點,使之滿字
  114. }else{
  115.   for(i=1;i<digW && f*g<Q;i++) g*=10,h--;        //繼續移動小數點,使之滿字
  116. }
  117.   qm = g*qmin;
  118.   for(i=0;i<2;i++){
  119.    if(i) d = b*g;      //取出實部
  120.    else  d = a*g;      //取出虛部
  121.    if(qm) d+=qm/2, d-=d%qm;//去除小于qmin的尾數
  122.    q = Q;
  123.    lcd_putc(fh[i]);        //顯示符號
  124.    for(j=0; j<digW; j++){  //數字輸出
  125.     lcd_putc(d/q+48);      //數字
  126.     if(j==h) lcd_putc('.');//小數點
  127.     d %= q, q /= 10;
  128.    }
  129.    if(!bo) break;     //不顯示虛部
  130.   }
  131.   //lcd_putc(dwB[c+4]); //單位
  132. if(dwB[c+4]=='u') { lcd_putc(9);} else {
  133. if(n==1){
  134. if(dwB[c+4]==' ') { lcd_putc(8); OX[6]=32; } else { lcd_putc(dwB[c+4]); OX[6]=8; } //自動單位
  135. }
  136. else { lcd_putc(dwB[c+4]); OX[6]=8; }
  137. } //符號
  138. }
  139. void lcd_putf(float a, char n, float qmin) //帶單位顯示浮點數,n是單位下限
  140.   { lcd_putp(a,0,0,n,qmin); }
  141. void lcd_int(int a,char w){ //定寬顯示正整數
  142.   char i=0, s[5] = {' ',' ',' ',' ',' '};
  143.   if(a<0) { a=-a; lcd_puts("-"); }
  144.   else    lcd_puts(" ");
  145.   do{
  146.    s[i++] = a%10+48;
  147.    a /= 10;
  148.   }while(a);
  149.   for(;w;w--) lcd_putc(s[w-1]);
  150. }
  151. //==========================================================================
  152. //===============================延時函數===================================
  153. void delay(uint loop) { uint i; for(i=0;i<loop;i++); } //延時函數
  154. void delay2(uint k)   { for(;k>0;k--) delay(10000);  } //長延時,k=100大約對應1秒
  155. //==========================================================================
  156. //=================================AD轉換===================================
  157. sfr P1ASF = 0x9D;     //將P1置為模擬口寄存器(使能),各位中為1的有效
  158. sfr ADC_CONTR = 0xBC; //A/D轉換控制寄存器
  159. sfr ADC_res   = 0xBD; //A/D轉換結果寄存器
  160. sfr ADC_resl  = 0xBE; //A/D轉換結果寄存器
  161. void set_channel(char channel){
  162. P1ASF = 1<<channel;
  163. ADC_CONTR = channel+128; //最高位是電源開關,低3位通道選擇
  164. delay(1); //首次打開電源應延遲,使輸入穩定
  165. }
  166. uint getAD2(){
  167. ADC_CONTR |= 0x08;             //00001000,置ADC_START=1啟動A/D 轉換
  168. while ( !(ADC_CONTR & 0x10) ); //等待A/D轉換結束(ADC_FLAG==0)
  169. ADC_CONTR &= 0xE7;             //11100111,置ADC_FLAG=0清除結束標記, 置ADC_START=0關閉A/D 轉換
  170. return ADC_res*4 + ADC_resl;
  171. }
  172. /*
  173. uchar get_AD(){
  174. ADC_CONTR |= 0x08;             //00001000,置ADC_START=1啟動A/D 轉換
  175. while( !(ADC_CONTR & 0x10) );  //等待A/D轉換結束(ADC_FLAG==0)
  176. ADC_CONTR &= 0xE7;             //11100111,置ADC_FLAG=0清除結束標記, 置ADC_START=0關閉A/D 轉換
  177. return ADC_res;
  178. }
  179. */
  180. //==========================================================================
  181. //==================================EEPROW偏程==============================
  182. sfr IAP_data  = 0xC2;
  183. sfr IAP_addrH = 0xC3;
  184. sfr IAP_addrL = 0xC4;
  185. sfr IAP_cmd   = 0xC5;
  186. sfr IAP_trig  = 0xC6;
  187. sfr IAP_contr = 0xC7;
  188. /********************
  189. 寫字節時,可以將原有數據中的1改為0,無法將0改為1,只能使用擦除命令將0改為1
  190. 應注意,擦除命令會將整個扇區擦除
  191. *********************/
  192. int eepEn = 0;
  193. void saEEP(){ //觸發并EEP保護
  194. if(eepEn==12345) IAP_trig = 0x5A;  //先送5A
  195. if(eepEn==12345) IAP_trig = 0xA5;  //先送5A再送A5立即觸發
  196. IAP_cmd = 0;      //關閉令,保護
  197. IAP_contr = 0;    //關EEPROM,保護
  198. IAP_trig = 0;
  199. IAP_addrL = 255; //設置讀取地址的低字節,地址改變才需要設置
  200. IAP_addrH = 255; //設置讀取地址的高字節,地址改變才需要設置
  201. }
  202. uchar readEEP(uint k){ //讀取
  203. IAP_addrL = k;    //設置讀取地址的低字節,地址改變才需要設置
  204. IAP_addrH = k>>8; //設置讀取地址的高字節,地址改變才需要設置
  205. IAP_contr = 0x81; //設置等待時間,1MHz以下取7,2M以下取6,3M取5,6M取4,12M取3,20M取2,24M取1,30M取0,前導1表示許檔IAP
  206. IAP_cmd = 1;      //讀取值1,寫取2,擦除取3,擦除時按所在字節整個扇區攛除
  207. saEEP(); //觸發并保護
  208. return IAP_data;
  209. }
  210. void writeEEP(uint k, uchar da){ //寫入
  211. IAP_data = da;    //傳入數據
  212. IAP_addrL = k;    //設置讀取地址的低字節,地址改變才需要設置
  213. IAP_addrH = k>>8; //設置讀取地址的高字節,地址改變才需要設置
  214. IAP_contr = 0x81; //設置等待時間,1MHz以下取7,2M以下取6,3M取5,6M取4,12M取3,20M取2,24M取1,30M取0,前導1表示許檔IAP
  215. IAP_cmd = 2;      //讀取值1,寫取2,擦除取3,擦除時按所在字節整個扇區攛除
  216. saEEP(); //觸發并保護
  217. }
  218. void eraseEEP(uint k){ //擦除
  219. IAP_addrL = k;    //設置讀取地址的低字節,地址改變才需要設置
  220. IAP_addrH = k>>8; //設置讀取地址的高字節,地址改變才需要設置
  221. IAP_contr = 0x81; //設置等待時間,1MHz以下取7,2M以下取6,3M取5,6M取4,12M取3,20M取2,24M取1,30M取0,前導1表示許檔IAP
  222. IAP_cmd = 3;      //讀取值1,寫取2,擦除取3,擦除時按所在字節整個扇區攛除
  223. saEEP(); //觸發并保護
  224. }
  225. xdata struct Ida{
  226. char zo[3];//三個頻率下的零點改正值
  227. char j1;   //相位補償(3倍檔)
  228. char j2;   //相位補償(10倍檔)
  229. char J[4];  //相位補償(V/I變換器)
  230. char R[4]; //下臂電阻修正(40,1k,10k,100k)
  231. char g1;   //增益修正(3倍檔)
  232. char g2;   //增益修正(10倍檔)
  233. char phx; //1kHz以下相位改正
  234. char R4b; //100k檔7.8kHz頻率下的幅度補償
  235. char G2b; //9倍檔7.8kHz頻率下的幅度補償
  236. char feq; //頻率修正
  237. char ak;  //AD斜率修正
  238. float QRs[3],QXs[3]; //短路清零數據
  239. float QRo[3],QXo[3]; //開路清零數據
  240. } cs;
  241. void cs_RW(char rw){
  242. uchar i,*p = &cs;
  243. const int offs=512;
  244. if(rw){
  245.   delay2(10); //等待(防止掉電誤識別鍵盤而調用本函數)
  246.   eraseEEP(offs);
  247.   for(i=0;i<sizeof(cs);i++) writeEEP(i+offs,p[i]);
  248. }else{
  249.   for(i=0;i<sizeof(cs);i++) p[i]=readEEP(i+offs);
  250. }
  251. }
  252. //==========================================================================
  253. //==================================LCR主程序===============================
  254. //==========================================================================
  255. sfr P1M1=0x91; //P1端口設置寄存器
  256. sfr P1M0=0x92; //P1端口設置寄存器
  257. sfr P0M1=0x93; //P0端口設置寄存器
  258. sfr P0M0=0x94; //P0端口設置寄存器
  259. sfr P2M1=0x95; //P2端口設置寄存器
  260. sfr P2M0=0x96; //P2端口設置寄存器
  261. sfr P3M1=0xB1; //P3端口設置寄存器
  262. sfr P3M0=0xB2; //P3端口設置寄存器
  263. sbit spk=P2^3; //蜂鳴器
  264. sbit Kb=P2^1;  //量程開關B
  265. sbit Ka=P2^2;  //量程開關A
  266. sbit DDS2=P1^2;//移相方波輸出口
  267. sbit K3=P1^7;
  268. sbit K4=P1^6;
  269. sbit K5=P1^5;  //7.8kHz濾波開關
  270. sbit K6=P1^4;
  271. sbit K8=P2^0;  //100Hz濾波開關
  272. sbit K32=P1^1; //32kHz發生器
  273. xdata uchar menu=1,menu2=0; //菜單變量
  274. //==============低頻信號DDS相關參數====================
  275. //PCA相關寄存器
  276. sfr CMOD = 0xD9;   //鐘源選擇控制等
  277. sfr CH = 0xF9;     //PCA的計數器
  278. sfr CL = 0xE9;     //PCA的計數器
  279. sfr CCON = 0xD8;   //PCA控制寄存器
  280. sfr CCPAM0 = 0xDA; //PCA模塊0工作模式寄存器
  281. sfr CCPAM1 = 0xDB; //PCA模塊1工作模式寄存器
  282. sfr CCAP0L = 0xEA; //模塊0捕獲寄存器低位
  283. sfr CCAP0H = 0xFA; //模塊0捕獲寄存器高位
  284. sfr IPH = 0xB7;
  285. sbit PPCA  = IP^7;   //PCA的中斷優先級設置
  286. sbit CCF0  = CCON^0; //PCA的模塊0中斷標志
  287. sbit CCF1  = CCON^1; //PCA的模塊1中斷標志
  288. sbit CR = CCON^6;    //PCA計數器使能
  289. uint ph=0, phM=256, feq=977; //相位,phM相位步進值
  290. uchar *ph8 = (char*)&ph;    //ph的高8位地址
  291. xdata float feqX=976.6; //實際輸出頻率
  292. uchar code sinB[256]={
  293. //查詢表中不可裝載零值,否則會造成無中斷產生
  294. 255,255,255,255,255,255,254,254,253,252,252,251,250,249,248,247,246,245,243,242,240,239,237,236,234,232,230,229,227,225,222,220,
  295. .......
  296. uchar chuX=0; //方波DDS初相
  297. //==============低頻信號DDS函數====================
  298. void PWM_init(){ //把PCA置為PWM
  299.   CMOD = 2;   //0000 0010 計數源選擇,鐘源取fosc/2
  300.   CL = CH = 0;
  301.   CCAP0L = CCAP0H = 192; //占空比為25%
  302.   //CCPAM0=0x42;//0100 0010,PCA的模塊0設置為PWM模式,無中斷
  303.   CCPAM0=0x53;//0101 0011,PCA的模塊0設置為PWM模式,有中斷,下降沿中斷
  304.   PPCA = 1;   //優先中斷
  305.   IPH |= 128;
  306.   //CR = 1;   //開始計數
  307.   EA = 1;     //開總中斷
  308. }
  309. void PCAinter(void) interrupt 7 {//PCA中斷
  310.   uchar x,y;
  311.   CCF0=0; //清除中斷請求,以免反復中斷
  312.   x = *ph8;        //截斷正弦相位累加器,取高8位
  313.   y = x + chuX;    //方波相位
  314.   CCAP0H = sinB[x];//正弦DDS輸出
  315. if(DDS3) {  DDS2 = fbB[y];   //方波DDS輸出
  316. }else {DDS2 = 0;}
  317.   ph += phM;       //相位累加
  318.   K32 = ~K32;
  319. }
  320. void setDDS(uint f){ //參考時鐘是c=(fosc/2)/256=32000000/2/256=62500,頻率f=c*phM/2^16
  321. feq = f;
  322. phM=f*65536.0/62500; //phM=f*2^16/62500
  323. feqX = 62500.0*phM/65536*(1+cs.feq/10000.0); //實際輸出頻率
  324. ph = 0;              //高頻時,使波形對稱
  325. if(!f) CR=0; else CR=1;
  326. }
  327. //相位控制函數
  328. xdata char xw=0; //相位
  329. void set90(char k){ //設置方波的相位差
  330.   k %= 4;
  331.   if(k<0) k += 4;
  332.   if(k==0) chuX=0;   //移相0度
  333.   if(k==1) chuX=64;  //移相90度
  334.   if(k==2) chuX=128; //移相180度
  335.   if(k==3) chuX=192; //移相270度
  336.   xw = k;
  337. }
  338. void set902() { set90(xw+1); } //相位步進
  339. //==============量程控制函數====================
  340. xdata char rng=1; //量程
  341. void setRng(char k){//切換量程
  342. if(k>3) k=3;
  343. if(k<0) k=0;
  344. if(k==0) Ka=0,Kb=0; //40歐
  345. if(k==1) Ka=0,Kb=1; //1k歐
  346. if(k==2) Ka=1,Kb=0; //10k歐
  347. if(k==3) Ka=1,Kb=1; //100k歐
  348. rng = k;
  349. }
  350. void setRng2(){ setRng( (rng+1)%4); } //量程步進
  351. //==============增益控制函數====================
  352. char curGain=1; //當前增益索引號
  353. void setGain(char k){ //設置電路增益
  354.   if(k>3) k=3;
  355.   if(k<0) k=0;
  356.   if(k==0) K4=0,K6=0; //1倍
  357.   if(k==1) K4=0,K6=1; //3倍
  358.   if(k==2) K4=1,K6=0; //9倍
  359.   if(k==3) K4=1,K6=1; //27倍
  360.   curGain = k;
  361. }
  362. void setGain2(){ setGain((curGain+1)%4); }
  363. //==============AD非線性改正與過采樣=================
  364. uint getAD10(){ //120次采樣,用reentrant申明,有的單片機無法運行
  365. int i;
  366. long c;
  367. for(i=0;i<250;i++) c += getAD2();
  368. return (c+12)/25;
  369. }
  370. uint getAD10b(){ //120次采樣,用reentrant申明,有的單片機無法運行
  371. xdata long c = 0, c2 = 0;
  372. int i;
  373. for(i=0;i<250;i++){
  374.   ADC_CONTR |= 0x08;             //00001000,置ADC_START=1啟動A/D 轉換
  375.   while ( !(ADC_CONTR & 0x10) ); //等待A/D轉換結束(ADC_FLAG==0)
  376.   ADC_CONTR &= 0xE7;             //11100111,置ADC_FLAG=0清除結束標記, 置ADC_START=0關閉A/D 轉換
  377.   c  += ADC_resl;
  378.   c2 += ADC_res;
  379. }
  380. c3 = c;
  381. c = ( c2*4L + c )/25;
  382. c3= ( c2*4L + c3 ) -c*25;
  383. return c;
  384. }
  385. //==============LCR測量====================
  386. code float ga[4] =  {  1,   3,   9,  27 }; //增益表
  387. code float dwR[4] = { 40, 1e3, 1e4, 1e5 }; //各檔電阻表
  388. xdata int Vxy[12]={0,0,0,0,1,1}; //Vxy[Vx1,Vy1,Vx2,Vy2,g1,g2]
  389. xdata char Sxw[4]={0,1,0,1};    //保存正確相位
  390. xdata int Vz[24];               //LCR測量結果隊
  391. xdata uchar tim=0,tims=0;
  392. xdata char pau=0; //暫停坐標自動旋轉
  393. xdata char isQ=1;
  394. #define Vfull 9600
  395. #define gad (9600/30)
  396. uchar mT = 6; //測量速度,mT取值為6或12或24時,可以消除數字噪聲,尾數不動,但不利于于取平均
  397. //==============設置頻率====================
  398. xdata char feqK=1; //頻率索引號
  399. void setF(char k){
  400.   if(k==-1) k = (feqK+1)%3; //步進
  401.   feqK = k;
  402.   if(k==0) { setDDS(100);   K5=0; K8=1; mT=12; } //置為100Hz
  403.   if(k==1) { setDDS(977);   K5=0; K8=0; mT=6;  } //置為1kHz
  404.   if(k==2) { setDDS(7813);  K5=1; K8=0; mT=6;  } //置為7.8125kHz
  405.   TH1 = 150, TL1 = 171; //置為20ms
  406.   tims = 0;
  407.   tim = 0;
  408.   ph = 0;
  409. }
  410. int absMax(int a,int b){ //取兩個數絕對值最大者
  411.   if(a<0) a = -a;
  412.   if(b<0) b = -b;
  413.   if(b>a) a = b;
  414.   return a;
  415. }
  416. char yc1=0,yc2=0; //溢出標識
  417. char slw = 1; //降速倍率
  418. char chg=0;   //量程切換標記
  419. void timerInter1(void) interrupt 3 {//T1中斷,LCR數據采集
  420. code int y[5]={0,-15,30,24,0}; //滿度用30
  421. code int x[5]={4900,5090,5140,5500,6120};
  422.   char g,gb,Rb,i; int c=0,cc=0;
  423.   tims++;
  424.   if(tims>=mT/slw) tims = 0, tim++, c = 1;
  425.   if(tim>=4) tim=0;
  426.   if(pau) return;
  427.   if(!c) return; //tim未進位觸發
  428.   c = getAD10b();   //讀取電壓值
  429.   cc= c3;
  430.   c -= cs.zo[feqK];
  431. if(cs.ak>0){
  432. for(i=0;i<4;i++){ //非線性改正
  433.   if(c<x[i]||c>=x[i+1]) continue;
  434.   c += cs.ak*( y[i] + (y[i+1]-y[i]) * ((int)(c-x[i])) / (x[i+1]-x[i]) ) / 30;
  435.   break;
  436. }
  437. }
  438.
  439.   Vxy[tim] = xw<2 ? c : -c;  //保存當前電壓
  440.   Vxy[tim+6] = xw<2 ? cc : -cc;  //保存當前電壓
  441.   Vxy[tim/2+4] = curGain;    //保存當前增益
  442.   Sxw[tim] = ( Sxw[tim]+(c<0 ? 2 : 0) )%4;  //相位翻轉(預測下次的相位采用值)
  443.   if(tim==1||tim==3){ //上下臂切換
  444.     if(tim==1) { K3=1, c = absMax(Vxy[2],Vxy[3]), g=Vxy[5]; yc2 = c>Vfull ? 1:0; }//切換到下臂
  445.     if(tim==3) { K3=0, c = absMax(Vxy[0],Vxy[1]), g=Vxy[4]; yc1 = c>Vfull ? 1:0; }//切換到上臂
  446.     gb=g, Rb=rng;
  447.     if(c>Vfull){ if(g==0&&rng>0&&K3&&isQ) Rb=rng-1; gb=0; }
  448.     else if(c<gad*1 ) gb = g+3; //增加27倍
  449.     else if(c<gad*3 ){ gb = g+2;if(c<gad*2&&rng>=1&&rng<=2&&K3&&isQ ) { gb=0; Rb=rng+1; }} //增加9倍
  450.     else if(c<gad*9)  gb = g+1; //增加3倍
  451.         if(gb>3) gb = 3;
  452.     if(g==3&&rng<3&&K3&&isQ) { gb=0; Rb=rng+1; }
  453.     if(g==0&&c<gad*1&&rng<3&&K3&&isQ) { gb=0; Rb=rng+1; }
  454.         setRng(Rb); setGain(gb); //置量程
  455.     if(gb!=g || Rb!=rng) slw = 2, chg++; //量程正在改變,則加速測量
  456.     if(tim==3){ if(!chg) slw=1; chg=0; }
  457.   }
  458.   set90( Sxw[ (tim+1)%4 ] ); //相位旋轉
  459.   if(tim==3){ for(i=0;i<12;i++) Vz[i+12]=Vz[i], Vz[i]=Vxy[i]; }
  460. }
  461. void showR(char binLian, char showk){ //顯示LCR
  462.   xdata float a=0,b=0,c=0,qq=0,dd=0,e,w,L,C;
  463.   xdata int gr=cs.R[rng], g1=cs.g1, g2=cs.g2;
  464.   xdata int g12 = g1 + g2;          //增益最大補償
  465.   xdata int j12 = (int)cs.j1+cs.j2; //相位最大補償
  466.   xdata float JD = 0, G = 0, cJD;   //補償變量
  467.   xdata float v[4];
  468.   xdata char ATC=0,d3=1;
  469.   //LCR計算
  470.   if(feqK<0||feqK>2) return;
  471.   if(feq==7813&&rng==3) gr += cs.R4b; //7.8kHz時下臂修正量
  472.   //可控增益單元的增益修正、相位補償量
  473.   if(feq==7813) g2 += cs.G2b;  //7.8kHz時9倍檔修正量
  474. ……………………
  475. …………限于本文篇幅 余下代碼請從51黑下載附件…………
所有資料51hei附件下載:
2004程序_3.0_全自動電橋V1.rar (28.53 KB, 下載次數: 470)
LCR數字電橋自制方案.pdf (1.39 MB, 下載次數: 412)
LCR數字電橋.docx (257.25 KB, 下載次數: 337)
作者: 雪玉寐影    時間: 2021-12-7 02:53
許老師把資料公開了?怪不得某寶多出來很多套件!
作者: jsh560    時間: 2021-12-11 09:18
吃透了嗎?可以一起討論學習下嗎
作者: dhbt2021    時間: 2021-12-11 19:02
置量程不懂!!!!!!
作者: tanguoyong    時間: 2022-1-1 20:58
置量程不懂!!!!!!
作者: luckzsh    時間: 2022-3-2 00:10
一起討論學習下
作者: n0si9na1    時間: 2022-3-3 17:15
感謝分享,過了這么多年,許老師這個電橋還是很給力啊,DIY者樂此不疲
作者: youlinys    時間: 2022-3-13 15:08
感謝許老師的無私奉獻。
作者: 18201700208    時間: 2022-4-8 15:43
high,供電不足
作者: lao4jiadian    時間: 2022-4-13 13:53
哪位壇友能把徐老師電橋的硬件資料發上來啊,學習一下
作者: 看看再說吧    時間: 2022-6-28 05:37
這個固件在2004屏幕上顯示不完整。
作者: xiaoyuxinke    時間: 2022-6-28 21:30
固件其實是LCD1602的,但寫的用2004的屏,會導致顯示不完整,
作者: angmall    時間: 2022-7-30 13:48
lao4jiadian 發表于 2022-4-13 13:53
XJW01許老師 LCR數字電橋板原理圖
作者: ywcffc    時間: 2022-9-8 11:07
有沒有全套2004LCD可以完全使用的固件和硬件,網上找的都不是很全
作者: 我欠你錢么    時間: 2023-4-18 16:50
研究研究代碼,看看能不能搞懂
作者: heizelalala    時間: 2023-8-5 02:55
太有用啦
作者: 1045964948    時間: 2023-9-7 16:59
我想問一下樓主能理解這個程序的意思嗎,我最近在搞電橋,想移植程序到stm32無奈看不懂許老師這個stc的程序,如果知道可以回復我一下我最近都在線
作者: mafeimafei_2012    時間: 2023-12-25 16:30
感謝老師的無私奉獻。
作者: zyfzyf007    時間: 2024-2-23 20:26
感謝老師的無私奉獻。
作者: Su_xin    時間: 2024-3-1 15:17
12864版嗎?
作者: 還沒想好名字啊    時間: 2024-3-2 09:47
1045964948 發表于 2023-9-7 16:59
我想問一下樓主能理解這個程序的意思嗎,我最近在搞電橋,想移植程序到stm32無奈看不懂許老師這個stc的程序 ...
我也學不會,期待許老師出山答疑。STC的程序,有幾個小伙伴在學習  STC官方也在折騰好像
作者: 1109    時間: 2024-3-8 21:07
哪里有這個電橋的PCB文件,我想去打個板子調試下效果。
作者: paladina    時間: 2024-5-7 17:12
好東西,學習。能有大拿解釋一下程序就更好了
作者: daxia7203    時間: 2024-11-30 17:53
不錯不錯
作者: STC莊偉    時間: 2024-12-4 09:21
LCR 電橋,移植,辛苦費RMB2000
===12C5A60S2實現,許老師
立創開源:LCR測量@8051U, 參考許老師原創
用管腳兼容的 8051USB 實現后開源許老師,公布了 LCR 電橋開源資料
歡迎學習許老師的大作 !
8H8K64U / 32G12K128片內的 ADC就是真12位ADC
===能準確的測量 0 ~ 4095 體現的外部真實模擬電壓
2024年,8051U推出, 管腳基本兼容 12C5A60S2
作者: lzxxx588    時間: 2025-1-1 20:20
雪玉寐影 發表于 2021-12-7 02:53
想自己搞一個玩玩不知道好搞不
作者: 1109    時間: 2025-1-2 09:41
STC莊偉 發表于 2024-12-4 09:21
===12C5A60S2實現,許老師
方便給個開源鏈接嗎?我在立創開源沒有搜到。
作者: 2048858214    時間: 2025-4-17 08:09
新版本stm32的 100Khz 不好弄啊 許老師聯系不到了
作者: 荒野ac    時間: 2025-4-18 12:34
置量程不懂!!!!
置量程不懂!!!!
作者: hu2018y    時間: 2025-4-20 08:29
我有片1604可以派上用場了,好像最新的STC8051U這芯片很牛逼的樣子,期待大神把它玩出花樣來。
作者: wkman    時間: 2025-4-21 17:05
  買成品套件,不折騰
作者: llflvleifeng    時間: 2025-7-6 13:39
感謝分享,學習下
作者: xyqahzw    時間: 2025-7-13 21:04
學習一下,看看能不能復制出來,大不了代碼自己重編
作者: 單片機重購    時間: 2025-7-14 22:21
像這種的呢我們之前也是經常去看呢我覺得這種單片機的東西呢也是比較簡單的呢。
作者: 盛世游龍    時間: 2025-7-16 10:13
有人復刻成功的嗎?
作者: 盛世游龍    時間: 2025-7-16 10:27
xyqahzw 發表于 2025-7-13 21:04
像這種,如果自己完全能編,就不用看別人的復刻了。單片機硬件和軟件一直都是相互配合的,能搞定軟件,必然也要懂硬件。硬件不了解,軟件就無從可編的。了解硬件,也就可以根據軟件特性設計硬件。如果說,你一定要借助別人設計的硬件才能編其程序。那么說你能適度修改原作者提供的源代碼,我信。說自己從頭編,我不太信。
作者: 盛世游龍    時間: 2025-7-16 10:32
單片機重購 發表于 2025-7-14 22:21
很多東西,看起來簡單。但真要自己動手去做,需要了解的東西,可真不少。很多東西,就算依葫蘆畫瓢,做出了,效果也不一定會好。很多細節如果對相關原理了解不足,問題出在哪里都不知道!
作者: wkman    時間: 2025-7-18 16:43
tb上有成品賣的吧
作者: logicha    時間: 2026-1-9 16:37
很好的資料,謝謝分享。。。
作者: logicha    時間: 2026-1-12 10:34
資料不錯,感謝分享。。。。。
作者: logicha    時間: 2026-1-16 09:23
資料不錯,謝謝分享。。。
作者: yellowsstar    時間: 2026-3-24 17:27
資料不錯,謝謝分享!!!!!
