標題: 單片機可調周期參數波形發生器源程序(dac0832、矩陣鍵盤、lcd12864、Proteus仿真) [打印本頁]
作者: wzh1787684166    時間: 2021-4-21 20:20
單片機設計—波形發生器,波形可選擇、幅值周期可編輯、含有lcd0832顯示屏、led數碼管、矩陣鍵盤輸入。通過lcd12864顯示屏顯示當前狀態,根據提示通過矩陣鍵盤輸入波形類型、波形幅值周期等參數,通過led顯示屏顯示實時電壓,通過dac0832輸出波形。
1.    輸出矩形波、梯形波、三角波、鋸齒波、正弦波五種波形;
2.    每種波形的周期可更改;
3.    每種波形的幅值可更改;
4.    采用lcd12864中文顯示屏顯示波形輸入輸出信息;
5.    采用數碼管顯示實時電壓。
  1. /**************************************************************************************
  2. * 設計一個能產生正弦、方波、三角波、梯形波等波形的波形發生器,周期頻率可調。
  3. * 其他附加功能:
  4. *
  5. 總得看一下有沒有重復定義的io口
  6. ***************************************************************************************/
  7. #include "reg52.h"    //此文件中定義了單片機的一些特殊功能寄存器
  8. #include "DAC0832.h"
  9. #include "lcd12864.h"
  10. #include "key.h"
  11. sbit test_led=P3^0;
  12. sbit test_led1=P3^1;
  13. sbit seg_k1=P3^3;
  14. sbit seg_k2=P3^4;
  15. int boxing=0;
  16. int zhouqi=0;
  17. float fuzhi=0;
  18. char code Hz_0[]=
  19. {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
  20. 0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,};
  21. char code Hz_1[]=
  22. {0x00,0x00,0x10,0x10,0xF8,0x00,0x00,0x00,
  23. 0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,};
  24. char code Hz_2[]=
  25. {0x00,0x70,0x08,0x08,0x08,0x08,0xF0,0x00,
  26. 0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,
  27. };
  28. char code Hz_3[]=
  29. {0x00,0x30,0x08,0x08,0x08,0x88,0x70,0x00,
  30. 0x00,0x18,0x20,0x21,0x21,0x22,0x1C,0x00,
  31. };
  32. char code Hz_4[]=
  33. {0x00,0x00,0x80,0x40,0x30,0xF8,0x00,0x00,
  34. 0x00,0x06,0x05,0x24,0x24,0x3F,0x24,0x24,
  35. };
  36. char code Hz_5[]=
  37. {0x00,0xF8,0x88,0x88,0x88,0x08,0x08,0x00,
  38. 0x00,0x19,0x20,0x20,0x20,0x11,0x0E,0x00,
  39. };
  40. char code Hz_6[]=
  41. {0x00,0xE0,0x10,0x88,0x88,0x90,0x00,0x00,
  42. 0x00,0x0F,0x11,0x20,0x20,0x20,0x1F,0x00,
  43. };
  44. char code Hz_7[]=
  45. {0x00,0x18,0x08,0x08,0x88,0x68,0x18,0x00,
  46. 0x00,0x00,0x00,0x3E,0x01,0x00,0x00,0x00,
  47. };
  48. char code Hz_8[]=
  49. {0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,
  50. 0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
  51. };
  52. char code Hz_9[]=
  53. {0x00,0xF0,0x08,0x08,0x08,0x10,0xE0,0x00,
  54. 0x00,0x01,0x12,0x22,0x22,0x11,0x0F,0x00,
  55. };
  56. char code Hz_dian[]=
  57. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  58. 0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,
  59. };
  60. extern u8 KeyValue;
  61. int flag=1;//推出while
  62. unsigned int key_time;//判斷輸入了幾個數
  63. unsigned int time_count=0;//幅值換算
  64. unsigned int time_loop=0;  //周期換算
  65. unsigned int time_count_h=0;  //周期換算H
  66. unsigned int time_count_l=0;  //周期換算L
  67. void main_delay(int x)
  68. {while(x--);}
  69. void Int0Init()
  70. {
  71. //設置 INT0
  72. IT0=1;//跳變沿出發方式(下降沿)
  73. EX0=1;//打開 INT0 的中斷允許。
  74. EA=1;//打開總中斷
  75. }
  76. /*******************************************************************************
  77. * 函 數 名       : main
  78. * 函數功能                 : 主函數
  79. * 輸    入       : 無
  80. * 輸    出             : 無
  81. *******************************************************************************/
  82. void main()
  83. {
  84.         Int0Init();
  85.         output_xinxi();//顯示姓名信息
  86.
  87.         while(flag);
  88.         test_led=1;
  89.         test_led1=1;
  90.         while(1)
  91.         {
  92.                 flag=1;
  93.                 switch (boxing)
  94.                         {case (0): //矩形波
  95.        time_loop=zhouqi*100/65;
  96.        time_count_l=(int)(fuzhi*10)%10;
  97.        time_count_h=fuzhi;
  98.        time_count=(51*time_count_h+5*time_count_l);
  99.        while (flag)
  100.        {P2=Rectangular_wave(time_loop,time_count_h,time_count_l,time_count);}
  101.        break;//
  102.                          case (1):time_count=fuzhi*52;    //幅值換算結果   //鋸齒波
  103.        time_loop=(zhouqi*1000/time_count-195)/20;
  104.        while(flag)
  105.        {P2=Sawtooth_wave(time_loop,time_count);}
  106.        break;
  107.
  108.                          case (2):time_count=zhouqi*10/30;
  109.        test_led=0;
  110.        while(flag)
  111.        {P2=Sine_wave(time_count,fuzhi);}
  112.        break;
  113.                         case (3):time_count=fuzhi*52;    //幅值換算結果   //三角波
  114.        time_loop=(zhouqi*1000/time_count-195)/20;
  115.        while(flag)
  116.        {P2=Triangle_wave(time_loop,time_count);}
  117.        break;
  118.                         case (4):time_count=fuzhi*104;    //幅值換算結果   //梯形波
  119.        time_loop=(zhouqi*1000/time_count-195)/20;
  120.        while(flag)
  121.        {P2=Trapezoidal_wave(time_loop,time_count);}
  122.        break;
  123.                   }
  124.                 }
  125. }
  126. void Int0() interrupt 0 //外部中斷 0 的中斷函數
  127. {
  128.         main_delay(1000); //延時消抖
  129.         Clr_Scr();
  130.         seg_k1=1;
  131.         seg_k2=1;
  132.         boxing=0;
  133.         zhouqi=0;
  134.         fuzhi=0;
  135.         main_delay(1000);
  136.         KeyValue=0;
  137.
  138.         output_shuru();
  139.         main_delay(100000);
  140.
  141.         //檢測波形
  142.         while((KeyValue!=11))
  143.                                 {KeyDown();}
  144.         output_boxing();
  145.         main_delay(100000);
  146.         KeyValue=0;
  147.         key_time=0;
  148.         while((KeyValue!=11))
  149.           {
  150.                         KeyValue=15;
  151.                                 while(KeyValue==15)
  152.                                         {KeyDown();}
  153.                                         main_delay(100000);
  154.                                 LCDMcs=1; //右屏開顯示
  155.                                 LCDScs=0;
  156.                         switch(KeyValue)
  157.                                 {
  158.                                  case(0):hz_LCDDisp8(2,key_time+0,Hz_0);key_time=key_time+8;break;
  159.                                  case(1):hz_LCDDisp8(2,key_time+0,Hz_1);key_time=key_time+8;break;
  160.                                  case(2):hz_LCDDisp8(2,key_time+0,Hz_2);key_time=key_time+8;break;
  161.                                  case(3):hz_LCDDisp8(2,key_time+0,Hz_3);key_time=key_time+8;break;
  162.                                  case(4):hz_LCDDisp8(2,key_time+0,Hz_4);key_time=key_time+8;break;
  163.                                  case(5):hz_LCDDisp8(2,key_time+0,Hz_5);key_time=key_time+8;break;
  164.                                  case(6):hz_LCDDisp8(2,key_time+0,Hz_6);key_time=key_time+8;break;
  165.                                  case(7):hz_LCDDisp8(2,key_time+0,Hz_7);key_time=key_time+8;break;
  166.                                  case(8):hz_LCDDisp8(2,key_time+0,Hz_8);key_time=key_time+8;break;
  167.                                  case(9):hz_LCDDisp8(2,key_time+0,Hz_9);key_time=key_time+8;break;
  168.                            case(10):hz_LCDDisp8(2,key_time+0,Hz_dian);key_time=key_time+8;break;
  169.                                  default:break;
  170.                     }
  171.                                 if (KeyValue!=11)
  172.                                 boxing=KeyValue;
  173.                         }
  174. //檢測周期
  175. while((KeyValue!=11))
  176.                                 {KeyDown();}
  177.         output_zhouqi();
  178.                         KeyValue=0;
  179.         key_time=0;
  180.         while((KeyValue!=11))
  181.           {
  182.                         KeyValue=15;
  183.                                 while(KeyValue==15)
  184.                                         {KeyDown();}
  185.                                         main_delay(100000);
  186.                                 LCDMcs=1; //右屏開顯示
  187.                                 LCDScs=0;
  188.                         switch(KeyValue)
  189.                                 {
  190.                                  case(0):hz_LCDDisp8(4,key_time+0,Hz_0);key_time=key_time+8;break;
  191.                                  case(1):hz_LCDDisp8(4,key_time+0,Hz_1);key_time=key_time+8;break;
  192.                                  case(2):hz_LCDDisp8(4,key_time+0,Hz_2);key_time=key_time+8;break;
  193.                                  case(3):hz_LCDDisp8(4,key_time+0,Hz_3);key_time=key_time+8;break;
  194.                                  case(4):hz_LCDDisp8(4,key_time+0,Hz_4);key_time=key_time+8;break;
  195.                                  case(5):hz_LCDDisp8(4,key_time+0,Hz_5);key_time=key_time+8;break;
  196.                                  case(6):hz_LCDDisp8(4,key_time+0,Hz_6);key_time=key_time+8;break;
  197.                                  case(7):hz_LCDDisp8(4,key_time+0,Hz_7);key_time=key_time+8;break;
  198.                                  case(8):hz_LCDDisp8(4,key_time+0,Hz_8);key_time=key_time+8;break;
  199.                                  case(9):hz_LCDDisp8(4,key_time+0,Hz_9);key_time=key_time+8;break;
  200.                            case(10):hz_LCDDisp8(4,key_time+0,Hz_dian);key_time=key_time+8;break;
  201.                                  default:break;
  202.                     }
  203.                                 if (KeyValue!=11)
  204.                                 zhouqi=KeyValue+zhouqi*10;
  205.                         }
  206.
  207.         //檢測幅值
  208. while((KeyValue!=11))
  209.                                 {KeyDown();}
  210.         output_fuzhi();
  211.                         KeyValue=0;
  212.         key_time=0;
  213.         while((KeyValue!=11))
  214.           {
  215.                         KeyValue=15;
  216.                                 while(KeyValue==15)
  217.                                         {KeyDown();}
  218. ……………………
  219. …………限于本文篇幅 余下代碼請從51黑下載附件…………
Keil代碼與Proteus8.8版本仿真下載:
波形發生器.7z (1.18 MB, 下載次數: 170)
作者: rrqxx    時間: 2021-4-22 19:31
生成方波頻率最高能到多少啊?
作者: heicad    時間: 2022-5-5 18:21
需要用Proteus8.8打開才可以,然后按圖1操作
作者: Mxd19991114    時間: 2022-5-5 22:46
學習了51的波形輸出,便于stm32的開發
