藍橋杯第七屆省賽單片機代碼,歡迎各位指教
看我像羅斯嗎
2021-3-9 16:33
本人大二菜雞一枚,今年參加藍橋杯,感覺陪跑,這是我參考寫的第七屆代碼,請大家指教。
#include<reg52.h>
#include<onewire.h>
#include<intrins.h>
sfr AUXR=0X8e;
sbit pwm_out=P3^4;
code unsigned char t_display[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x40,0x00};
code unsigned char t_com[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
unsigned char work1[8]={0xbf,0xff,0xbf,0xff,0xff,0xff,0xff,0xff};
unsigned char cont,count,work_mode,timing,T_dat,trg,temp;
unsigned char start_flag=1,PWM_count=20,temp_flag=0,work_mode=0,timing_flag,dismode;
void KEY()
unsigned char readdata=P3^0xff;
trg=readdata&(readdata^cont);
cont=readdata;
void delay(unsigned int i)
while(i--);
void smg()
{ int i;
P2=0xc0;P0=0;P2=0;//二極管全滅
P2=0xe0;P0=work1[i];P2=0;//數碼管選擇
P2=0xc0;P0=t_com[i];P2=0;//二極管點亮
i++;if(i==8)i=0;
void Timer0Init(void) //100??@11.0592MHz
AUXR |= 0x80; //?????1T??
TMOD &= 0xF0; //???????
TL0 = (65535-100)/255; //??????
TH0 = (65535-100)%255; //??????
TF0 = 0; //??TF0??
TR0 = 1; //???0????
ET0 = 1;
EA = 1;
void InterruptTimer0() interrupt 1
unsigned char count1,count2;
if(start_flag==1)
count++;
if((count==PWM_count/10)&&(timing!=0))
if(work_mode==1){P2=0x80;P0=0xfe;P2=0;}
else if(work_mode==2){P2=0x80;P0=0xfd;P2=0;}
else if(work_mode==3){P2=0x80;P0=0xfb;P2=0;}//二極管工作模式點亮
if(count==10)
count=0;
P2=0x80;P0=0xff;P2=0;
if(count2>300)
count2=0;
temp_flag=1;
if(count1>=1000)
count1=0;
if(timing!=0)
timing--;
void keyaction()
switch(trg)
/*S4*/ case 0x80:
if(work_mode==0)
{work_mode=1;PWM_count=30;}
else if(work_mode==2){work_mode=3;PWM_count=70;}
else if(work_mode==3){work_mode=1;PWM_count=20;}
break;
/*S5*/case 0x40:
start_flag=1;if(timing_flag==3)timing_flag=1;
else if(timing_flag==4)timing_flag=2;
else if(timing_flag==5)timing_flag=0;
/*S8*/case 0x08: timing=0;start_flag=0; break;
/*S9*/ case 0x04:if(dismode==0)dismode=1;else dismode=0; break;
P2=0xa0;P0=0;P2=0;
temp=rd_temperature();
Timer0Init();
KEY();
keyaction();
if(timing==0)
if((dismode==1)&&(temp_flag==1))
temp_flag=0;
// ET0=0;
// ET0=1;
if(dismode==0)
work1[0]=0xbf;work1[1]=~t_display[work_mode];work1[2]=0xbf;work1[3]=0xff;
work1[4]=~t_display[timing/1000%10];work1[5]=~t_display[timing/100%10];work1[6]=~t_display[timing/10%10];work1[7]=~t_display[timing%10];
else if(dismode==1)
work1[0]=0xbf;work1[1]=~t_display[4];work1[2]=0xbf;work1[3]=0xff;
work1[4]=0xff;work1[5]=0xff;work1[6]=~t_display[temp/10%10];work1[7]=~t_display[temp%10];
if(timing_flag==0){timing=timing_flag*60;timing_flag=3;}
else if(timing_flag==1){timing=timing_flag*60;timing_flag=4;}
else if(timing_flag==2){timing=timing_flag*60;timing_flag=5;}
hex文件:
藍橋杯第七屆.zip
(5.88 KB, 下載次數: 4)
2021-3-9 16:31 上傳
